    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 329.2k Views 41 Watching
    • jolranJ
      jolran
      You have to learn the ruby language itself
      Yeah, you are right. Working on that.
      Good news is the code seams to be working for sorting irregular faces and hatching.
            p1=pt.clone
            p1.x=p1.x+1 # X value = x axis needs to be replaced if using another axis
            p1=p1.project_to_plane(face.plane)
            ve=pt.vector_to(p1)
            bb=face.bounds
            di
      So something like this does not do the trick yet. Will work on it..
       p1.each {|e|e.z+1 if face.normal.z.abs==1
            e.x+1 if face.normal.x.abs==1
            e.y+1 if face.normal.y.abs==1}
        Read this and try to understand...
        p0=face.vertices[0].position
        p1=p0.clone
        if face.normal.x.abs>0.9999
          p1.y=p1.y+1
        else
          p1.x=p1.x+1
        end#if
        ve=p0.vector_to(p1)
        ### etc
        This should always result in a 've'ctor with a non=zero length.
        To test it set up a cube and test add temporary 'puts' into the code after ve=
        puts face.normal puts ve.length πŸ€“
        • jolranJ
          jolran
          Wow, thanks! So if I understand it correctly one do only need to compare x to y to get the required results. Where if>0,9999 switches to other axis-comparison=under1? Clever.
          It works for faces without holes if I switch values p0 to pt, with your last posted code.
          Or do you mean p0 to be po, (typo)? Cause that is a whole different thing. That does not makes sence though, wonder why I think that...
          I will try that meanwhile..Se if holes get fixed.
          po=pt.clone:
          ps=pt.offset(vp)
                  pe=pt.offset(vp.reverse)
                  gents.add_line(ps,pe)
                  pt.offset!(vs,spacing)
                  ps=po.offset(vp)
          etc
          • jolranJ
            jolran
            Anyway heres how I implemented your code, between ents erase(facestogo) and intersection. It does not work on faces with holes, as mentioned.
            Is there a clash with 2 pt.clones? Maybe I HAVE put your code in wrong places. I will continue..
            bb=face.bounds
                  di=bb.diagonal
                   pt=face.vertices[0].position
                    p1=pt.clone
                  p1.y=p1.y+1
                 else
                  p1.x=p1.x+1
                 end#if
                   ve=pt.vector_to(p1)
                    po=pt.clone
                  tr=Geom;;Transformation.rotation(pt,face.normal,@angle.degrees)
                   vp=ve.transform(tr)
                    vp.length=di*2
                     vs=face.normal.cross(vp) #spacing vector perpendicular to hatch line
                     tot=0
                  until tot>=di*2
                    ps=pt.offset(vp)
                        ps=po.offset(vp)
                       pe=po.offset(vp.reverse)
                     po.offset!(vs.reverse,spacing)
                    tot=
            • jolranJ
              jolran
              May have found something? Commented out the last parts. Line hatching and intersection.
              The results of faces with holes is a group(clone) with reversed face? Faces without holes is created as expected.
              Since using face.normal that might (in my theory logic) pose some trouble?
              Updated Hmmm, no. Grr. Did not matter if faces was reversed or not. Problem remains..
              This code reverses the faces anyway.
              Could be useful later on, but it will reverse ALL faces, wich is not useful right now. Faces without holes do not need reversing.
              faces2=[]
                    gents.each{|e|faces2 << e.reverse! if e.class==Sketchup;;Face
                Perhaps instead of pt=face.vertices[0].position it might be better to use pt=face.outer_loop.vertices[0].position
                • jolranJ
                  jolran
                  It does not work 😞
                  However i noticed that "face" entity gets erased after erase(facestogo) if it has holes in it. Not if it's a square for ex!
                  I used puts face after loop face erasing..
                  So do face.plane have something to refere to when there are holes? Or is the variabel set earlier?
                    Erase the faces after you've set the points/vector etc - you can't get the plane or normal of an erased face!
                    • jolranJ
                      jolran
                      AHA!!
                      So even if I am stupid enough to make that misstake, I noticed that in fact that was the error going on?
                      I'm making progress!! πŸ˜„
                      Thanks TIG. I will try to fix it.
                      • jolranJ
                        jolran
                        The "earliest" place where I can insert gents.erase_entities(faces2go) without erasing the access to face.plane is:
                               vp=ve.transform(tr)
                                vp.length=di*2
                        The result is not correct. Missing edges and too short.
                        Is face.plane or any command referring to "face" using the inner-hole faces, perhaps?
                        Should one use gents.entities.face(or something to retrieve the face.entity in gents) instead of just face?
                          You can set variables plane=face.plane and normal=face.normal and pt=face.outer_loop.vertices[0].position, then face.erase! - the variables are still remembered... then use them later as needed ?
                          • jolranJ
                            jolran
                            Ok. You mean before faces2go << face? After erase.faces2goI was going to define the
                            linehatching as a method for crosshatching, as we discussed earlier. They will have to be instance.variables then or do I pass all of them into the argument-list when calling the method?
                            That's why I was wondering if one could use face from gents.entities, since gents will be passed into the args-list anyway.
                            Or did you originaly mean I should put the whole operation into a method for crosshatching?
                            I'm sorry if I sound confused. 😳 But I am.
                              All this part is trying to do is set the vector from which you will set the angle for the hatching.
                              At the moment it's set from the vertices [0] to [1] vector which varies, so to fix it I suggested a way of projecting the x-axis onto the face.plane and getting a vector from that to use instead [with changes for a plane that doesn't play nicely with the x-axis to give a valid vector...
                              You get all of this from the original face NOT the temporary face ??
                              • jolranJ
                                jolran
                                You get all of this from the original face NOT the temporary face!
                                Yes, that part I understand(hopefully) what it was about to fix for problems.
                                However when you said I can't get the plane or normal of an erased face, I thought
                                order matters. I think my english is a bit bad, I don't understand everything right away. Apologize for that.
                                Lets say I use ORIGINAL "face" for face plane, I still must pass "face" on in the argument-list if I am going to
                                have following script setup, wich will be needed for crosshatching later on, no?
                                Feels like I'm doing some fundamential misstake here.
                                (edited)It should be "face" in the argument list. NOT faces.
                                • jolranJ
                                  jolran
                                  Think I got! @face=gents.add_face etc..in tha Face creating-part And use @ varibles in the code below seams to do the trick!
                                  It works on holes anyway. Don't know how kosher that is TIG? It would get into the linehatching method.
                                  • jolranJ
                                    jolran
                                    Works with holes..
                                      It seems to work now πŸ˜„ - is the angle always more logically oriented to an axis rather than an edge of the face ??
                                      As @face is a reference to a face before you run hatch and you erase it afterwards you don't really need to pass [@]face as an argument because @face is an instance variable read across methods, but if you do it'll probably still work... πŸ˜‰
                                      Also you [mistakenly] show a space in the def name AND started it with CAPITAL letter - use 'linehatch' or 'lineHatch' or simply 'hatch' or even 'make_hatching' etc which are all just fine... call it with self.hatch(aa, bb, cc) or whatever it's called...
                                      Use a @xxx variable where you want to use it across several methods [def's]
                                      Pass arguments to a method when you want to reuse the method with changes to arguments without using @xxx as you want to keep that for later - e.g. the @angle etc IS reused next time you use the dialog so when you pass angle again you use @cangle for the crosshatching angle but want to use the same method again... πŸ€“
                                      • jolranJ
                                        jolran
                                        Thanks for all your help and advice TIG!
                                        I will follow them.
                                        Don't know πŸ˜„
                                        So I'll update the plugin then? All OK?
                                        Will work on the crosshatching later. I think it is a good idea to get this fix out, so people can use this plugin
                                        more properly.
                                        This coding-testing burns more calories than a 2hours jogging in the forest πŸ˜„
                                          Test it on a cube's faces and a copy/copies of that cube rotated oddly in 3d to see what the hatching angles look like ??
                                          • jolranJ
                                            jolran
                                            Crap! It always hatches in the axis. Doesent matter if the cube is rotated or not.
                                            OK. for tomorrow then... sigh... I hope you will come to the rescue again πŸ˜„
                                            I'm guessing -transformation to axis something?
                                            I will never get to experiment with NEW features!!!
                                            It put the ver 1.4 update up anyway. Think it's better than it was before.
                                            • 17
                                            • 18
                                            • 6 / 18
