    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 329.2k Views 41 Watching
      You need to trap for the case when the X-axis is parallel with the palne and then use another axis - i.e. offset the y instead of the x value of p1...
      To do this get the n=face.normal and then use the alternative vector [offset in y] if n.x.abs==1 or n.z.abs==1
      etc...
      • jolranJ
        jolran
        Hmm I will try..
        Where do you learn all these commands?? πŸ˜„ It feels like I'm missing some information source(exept from this forum).
        BTW won't there be a conflict of axes if one for ex. have a face rotated 45 degrees?
          No.
          The problem arises if you try to project a p1 onto a face with a plane that is square to the x-axis or flat to it, as that p1 is then back on p0 and the vector can't have a zero length!
          • jolranJ
            jolran
            That I can understand. Alright, I will have a go at it. I'm not sure a fully grasp this 😳
            This is more and more your plugin, it's starting to be too complicated for me. My level is more icons and stuff.
            Maybe one day I can contribute more.
            Thanks for your invaluable help TIG πŸ‘
            • K
              kyyu
              @jolran said:
              Hmm I will try..
              You have to learn the ruby language itself. I'm lacking in this area, too.
              • jolranJ
                jolran
                Yeah, you are right. Working on that.
                Good news is the code seams to be working for sorting irregular faces and hatching.
                      p1=pt.clone
                      p1.x=p1.x+1 # X value = x axis needs to be replaced if using another axis
                      p1=p1.project_to_plane(face.plane)
                      ve=pt.vector_to(p1)
                      bb=face.bounds
                      di
                So something like this does not do the trick yet. Will work on it..
                 p1.each {|e|e.z+1 if face.normal.z.abs==1
                      e.x+1 if face.normal.x.abs==1
                      e.y+1 if face.normal.y.abs==1}
                  Read this and try to understand...
                  p0=face.vertices[0].position
                  p1=p0.clone
                  if face.normal.x.abs>0.9999
                    p1.y=p1.y+1
                  else
                    p1.x=p1.x+1
                  end#if
                  ve=p0.vector_to(p1)
                  ### etc
                  This should always result in a 've'ctor with a non=zero length.
                  To test it set up a cube and test add temporary 'puts' into the code after ve=
                  puts face.normal puts ve.length πŸ€“
                  • jolranJ
                    jolran
                    Wow, thanks! So if I understand it correctly one do only need to compare x to y to get the required results. Where if>0,9999 switches to other axis-comparison=under1? Clever.
                    It works for faces without holes if I switch values p0 to pt, with your last posted code.
                    Or do you mean p0 to be po, (typo)? Cause that is a whole different thing. That does not makes sence though, wonder why I think that...
                    I will try that meanwhile..Se if holes get fixed.
                    po=pt.clone:
                    ps=pt.offset(vp)
                            pe=pt.offset(vp.reverse)
                            gents.add_line(ps,pe)
                            pt.offset!(vs,spacing)
                            ps=po.offset(vp)
                    etc
                    • jolranJ
                      jolran
                      Anyway heres how I implemented your code, between ents erase(facestogo) and intersection. It does not work on faces with holes, as mentioned.
                      Is there a clash with 2 pt.clones? Maybe I HAVE put your code in wrong places. I will continue..
                      bb=face.bounds
                            di=bb.diagonal
                             pt=face.vertices[0].position
                              p1=pt.clone
                            p1.y=p1.y+1
                           else
                            p1.x=p1.x+1
                           end#if
                             ve=pt.vector_to(p1)
                              po=pt.clone
                            tr=Geom;;Transformation.rotation(pt,face.normal,@angle.degrees)
                             vp=ve.transform(tr)
                              vp.length=di*2
                               vs=face.normal.cross(vp) #spacing vector perpendicular to hatch line
                               tot=0
                            until tot>=di*2
                              ps=pt.offset(vp)
                                  ps=po.offset(vp)
                                 pe=po.offset(vp.reverse)
                               po.offset!(vs.reverse,spacing)
                              tot=
                      • jolranJ
                        jolran
                        May have found something? Commented out the last parts. Line hatching and intersection.
                        The results of faces with holes is a group(clone) with reversed face? Faces without holes is created as expected.
                        Since using face.normal that might (in my theory logic) pose some trouble?
                        Updated Hmmm, no. Grr. Did not matter if faces was reversed or not. Problem remains..
                        This code reverses the faces anyway.
                        Could be useful later on, but it will reverse ALL faces, wich is not useful right now. Faces without holes do not need reversing.
                        faces2=[]
                              gents.each{|e|faces2 << e.reverse! if e.class==Sketchup;;Face
                          Perhaps instead of pt=face.vertices[0].position it might be better to use pt=face.outer_loop.vertices[0].position
                          • jolranJ
                            jolran
                            It does not work 😞
                            However i noticed that "face" entity gets erased after erase(facestogo) if it has holes in it. Not if it's a square for ex!
                            I used puts face after loop face erasing..
                            So do face.plane have something to refere to when there are holes? Or is the variabel set earlier?
                              Erase the faces after you've set the points/vector etc - you can't get the plane or normal of an erased face!
                              • jolranJ
                                jolran
                                AHA!!
                                So even if I am stupid enough to make that misstake, I noticed that in fact that was the error going on?
                                I'm making progress!! πŸ˜„
                                Thanks TIG. I will try to fix it.
                                • jolranJ
                                  jolran
                                  The "earliest" place where I can insert gents.erase_entities(faces2go) without erasing the access to face.plane is:
                                         vp=ve.transform(tr)
                                          vp.length=di*2
                                  The result is not correct. Missing edges and too short.
                                  Is face.plane or any command referring to "face" using the inner-hole faces, perhaps?
                                  Should one use gents.entities.face(or something to retrieve the face.entity in gents) instead of just face?
                                    You can set variables plane=face.plane and normal=face.normal and pt=face.outer_loop.vertices[0].position, then face.erase! - the variables are still remembered... then use them later as needed ?
                                    • jolranJ
                                      jolran
                                      Ok. You mean before faces2go << face? After erase.faces2goI was going to define the
                                      linehatching as a method for crosshatching, as we discussed earlier. They will have to be instance.variables then or do I pass all of them into the argument-list when calling the method?
                                      That's why I was wondering if one could use face from gents.entities, since gents will be passed into the args-list anyway.
                                      Or did you originaly mean I should put the whole operation into a method for crosshatching?
                                      I'm sorry if I sound confused. 😳 But I am.
                                        All this part is trying to do is set the vector from which you will set the angle for the hatching.
                                        At the moment it's set from the vertices [0] to [1] vector which varies, so to fix it I suggested a way of projecting the x-axis onto the face.plane and getting a vector from that to use instead [with changes for a plane that doesn't play nicely with the x-axis to give a valid vector...
                                        You get all of this from the original face NOT the temporary face ??
                                        • jolranJ
                                          jolran
                                          You get all of this from the original face NOT the temporary face!
                                          Yes, that part I understand(hopefully) what it was about to fix for problems.
                                          However when you said I can't get the plane or normal of an erased face, I thought
                                          order matters. I think my english is a bit bad, I don't understand everything right away. Apologize for that.
                                          Lets say I use ORIGINAL "face" for face plane, I still must pass "face" on in the argument-list if I am going to
                                          have following script setup, wich will be needed for crosshatching later on, no?
                                          Feels like I'm doing some fundamential misstake here.
                                          (edited)It should be "face" in the argument list. NOT faces.
                                          • jolranJ
                                            jolran
                                            Think I got! @face=gents.add_face etc..in tha Face creating-part And use @ varibles in the code below seams to do the trick!
                                            It works on holes anyway. Don't know how kosher that is TIG? It would get into the linehatching method.
                                            • 17
                                            • 18
                                            • 6 / 18
