    DR Spawner issue
    scheduled pinned locked moved V-Ray
    renderpluginsextensions
    6 Posts 4 Posters 2.3k Views 4 Watching
    loading-more-posts
    • oldest-to-newest
    • newest-to-oldest
    • most-votes
    reply
    • reply-as-topic
    guest-login-reply
    deleted-message
    • V Offline
      Viztecture
      Hey all,
      Having trouble getting the DR Spawner to work on my network at work. So far i've only installed the spawner on one slave and im getting nothing, i have a few error messages and ready for render message. Im not getting any buckets on my main machine. My version is the latest 1.49.1, i've checked firewalls and everything seems ok. Attached is a screenshot of the spawner. Anyone got any ideas?
      Cheers
      http://www.viztecture.mfbiz.com
      one-reply-to-this-post last-reply-time reply quote 0
      • rodrigonotorR Offline
        rodrigonotor
        Hi, you try to make a DR render? check with a DOS ping if you are connect with the slave.
        http://img862.imageshack.us/img862/8208/19062011012744pm.jpg
        I have the same errors, but still can make DR.
        http://img90.imageshack.us/img90/6324/19062011011421pm.jpg
        http://img263.imageshack.us/img263/2395/10072011054201pm.jpg
        • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
        • V Offline
          Viztecture
          sorry to be a pain but how do I do that?
          Thanks for replying
            pepa
            Hi I try connect my pc.. I use IP adres (for imagine) e.g. (first pc) 192.258.100.60 (second pc) 192.258.100.61 when I use ping everything seems good, but it not working..(DR Spawner) when I use same adress to both pc e.g. 192.258.100.60 it seems that working but time of renderig is longer..😄 is it possible..?
            http://jsvizualizace.daportfolio.com/
              rodrigonotor
              I don't think so, the same IP address make conflicts on your LAN.
              Take a look at this, a made a Tutorial: http://forums.sketchucation.com/viewtopic.php?f=322&t=38908#p343511
              Regards
              • V Offline
                valerostudio
                I have had those error messages and the DR has worked. As long as it says waiting for jobs, I think it will work. If the machines you are sending the render to are slow and the file is large, then they will take a while before they start rendering buckets.
                My understanding is that the DR spawner is still rather buggy. I gave up on it because it would take forever to start, buckets would be rendering the wrong view, or darker, just weird stuff. It worked sometimes and then others it just did weird stuff. I got a workstation with an i7 multithreaded processor and my render times were cut in half. Thats my best advice for now.
                • first-post
                  last-post
