    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.7k Views 172 Watching
    • EarthMoverE
      EarthMover
      Have any of you checked out the Ivy texture pack that is on the Lutz Ivy generator page? - http://graphics.uni-konstanz.de/~luft/ivy_generator/ There are some great Ivy textures there with bump and spec maps, even a few premade maxwell ivy textures that could be used to replace the ones that come with Sketchup Ivy.
      Content Creator at Skapeup
      • kaluK
        kalu
        Hi to all:
        I try the IVY plugin is awesome what I see but I don't understand what are the steps to make it grow. Can someone place here the shortcut keys to make it work and grow and show leaves and menu for some reason I cant see the menu I have sketchup pro 8 and Windows 7 64.
        Thanks.
        THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
        • L
          lapx
          Hello all,
          Installed yesterday and was working now i cant get leaves to grow with final shift click 😢
          • V
            vidy
            @kalu said:
            Hi to all:
            Thanks.
            try this kalu:
            ALT-Click : Make the ivy grow towards the mouse position (Mac: Cmd)
            Mouse-Click : Grow Ivy stem
            CTRL-Click : Grow Ivy leafs (Mac: Alt)
            SHIFT-Click : Finish Ivy
            Keyboard 'i' : Start over
            still so much to learn..
            • V
              vidy
              @lapx said:
              Hello all,
              maybe you can check on page 17 for this issue..
              regards,
              • L
                lapx
                Vidy , yes! Thank you! Change the default values of the Spread from "0" to "1" and it works like a charm.
                • L
                  lapx
                  Spoke to soon. Was working fine. Now it's back to its old bad behavoir 😞 Shift click to make leafs is where I end up with a problem. It appears to make several duplicate copies of just 1 ivy branch and thats it. Leaves are not drawn. What can be going wrong? Using SU 804811.
                  Thanks,
                  • G
                    gianpier1
                    HI Boys.
                    I have a problem. I can´t never see the leafs!!!!!
                    Help me please! 🎉
                    • G
                      gianpier1
                      Hello guys again!!!
                      I can not see how the leaves are drawn? 😲 😲
                      I don´t understand it!!!
                      • romboutR
                        rombout
                        @gianpier1 said:
                        Hello guys again!!!
                        all depends on which version of SU you use...
                        try searching this forum post for updates and working version! for me a custom revised version 6.05 something does the job... try to look for it!
                        • G
                          gianpier1
                          i´m using ivy 0.6.3 to SU 8.0. but i didn´t find ivy 0.6.5. Neve i can´t see the leafs man
                          not understand because the leaves do not work when I press SHIFT, the vines are also up.
                          Thanks man
                          • L
                            lapx
                            For me its sometime works and sometimes not. Cant put my finger on it. Mostly stops working when using shift click. If it means anything, I can see the google and standard tool bar ghosting when I hit shift click 😕 using ivy 0.6.3
                            • L
                              lapx
                              Any developement? This is such a wonderful program to let go. Does anyone have it working consistently in sketchup 8?
                              Shift click seams to be the problem. Its not making the leaves.
                              • L
                                lapx
                                Anyone else have consistent success with the plugin? Might it be in conflict with other scripts?
                                Would love to use it on this current project...
                                http://forums.sketchucation.com/viewtopic.php?f=333&t=38590
                                • V
                                  vidy
                                  still working at mine, i know i dont make it so dense.. but still work... 😉
                                  here is the screen shot
                                  • P
                                    penniner
                                    cool !
                                    • L
                                      lapx
                                      Its working now. If I can just find out why its not working in some cases. The only thing done differently that I can think of is shutting down the computer and reactitvating sketchup_ivy.
                                      • N
                                        niks
                                        hi.. i've used both Ivy version 0.6 and .5, its working if im on a new scene but once i usethe plugin on my saved sketchup model it does not work. im using sketchup v.8 pro,windows....here's the result of the plugin when i apply it to my saved file. when i shift-click, it only add a single black vine line.. i also tried different suggestion posted on this thread but no luck.
                                        • C
                                          carmelo
                                          hi...
                                          i have this problem: "Errore di caricamento del file LiveIvy.rb
                                          no such file to load -- LiveIvy/LiveVector_core"
                                          Why?
                                          tanks
                                            hi...
                                            Why?
                                            tanks
                                            When you extract the files/folders from SketchupIvy.0.6.3.beta.rar you should have a file called LiveIvy.rb and a folder called LiveIvy [which contains several files and sub-folders].
                                            Put the LiveIvy.rb file and the LiveIvy folder into the Plugins folder.
                                            Do NOT move files from the LiveIvy sub-folder into the Plugins folder - if you have done that, then move them - it will probably break otherwise.
                                            This is what should be in this LiveIvy sub-folder... Capture.PNG IT: Quando si estraggono i file/cartelle da SketchupIvy.0.6.3.beta.rar si dovrebbe avere un file chiamato LiveIvy.rb e una cartella chiamata LiveIvy [che contiene diversi file e sottocartelle].
                                            Inserire il file LiveIvy.rb e la cartella LiveIvy nella cartella Plugins.
                                            NON spostare i file dal LiveIvy sottocartella nella cartella Plugins - se avete fatto questo, poi spostarli - sarà probabilmente rompere il contrario.
                                            Questo è ciò che dovrebbe essere in questo LiveIvy sottocartella...
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 36
                                            • 37
                                            • 15 / 37
