    [Plugin] RandomPushPull v2.5 20110709
    28 Posts 8 Posters 28.6k Views 8 Watching
    • dereiD Offline
      derei
      There is a "judgement" error in the plugin code. That is why did not respect max/min.
      The original plugin makes push-pull for this distance:
      selection.each{|s|s.pushpull((@ppmax-@ppmin) * rand)}
      So, if I input Min(400); Max(600) it will make pushPull for a random value of 200.
      In order to make pushPull for a random value between 400 and 600 i think, the code should look like this:
      selection.each{ |s| s.pushpull(@ppmin + (@ppmax-@ppmin) * rand) }
      In this way, you set the minimum value (@ppmin) to pushpull, then add the random value of 200 (up to 600).
      But, as rand method doesn't provide 0 or 1, there will not be pieces equal with 400 or 600.
      DESIGNER AND ARTIST DEREI.UK
        rand does return 0
        • dereiD Offline
          derei
          rand does return 0
          I stand corrected ๐Ÿ˜„ , but surely it does not return 1, so max value of push-pull will be never returned, right?
            Correct
              Here's v2.1 http://forums.sketchucation.com/viewtopic.php?p=340452#p340452
              It now uses the min/max range 'properly'... AND if the random value is actually ==min or ==max then it is used; the accuracy for using the actual max value is set at 1/1000001. On the incredibly rare times it matches exactly or it is exceeded very slightly then 'max' is used, as is 'min' when it's met exactly [rarely].
              • dereiD Offline
                derei
                Maybe you could add option in input box for push-pulling on negative values too, or force positive.
                EDIT: - i'm not sure (as I'm not a programmer), but this code doesn't pushpull between min and max.
                mx can have values much less than @ppmin, so pp can have very easy a negative value (if rn=10, mx = @ppmax * 0.0001; so what are the odds that between max and min to be a difference of 4 zeroes? In consequence pp = mx(very small) - @ppmin(highly probable much larger) ==> negative value for pp ).
                rn=rand(1000001)
                	  if rn!=0
                	    mx=@ppmax*(rn/1000000.0)
                		if mx > @ppmax
                	      mx=@ppmax
                      else
                	    mx=0
                	  pp=mx-@ppmin
                	  face.pushpull(pp) if pp!=0
                  Here's v2.2 http://forums.sketchucation.com/viewtopic.php?p=340452#p340452
                  I think I've sorted the range AND allowed negative values too...
                  • dereiD Offline
                    derei
                    ๐Ÿ˜• I'm not sure what you are trying to do there, but wouldn't be easier to force the pp value in v.2.1 to .abs? ๐Ÿ˜„ And...it still doesn't limit between max/min ๐Ÿ˜ž
                      Here's v2.3 http://forums.sketchucation.com/viewtopic.php?p=340452#p340452
                      It now works properly between the max/min range and allows +/-ve values... ๐Ÿ˜•
                      I hope!
                      • dereiD Offline
                        derei
                        Well, good news! It works like a charm ๐Ÿ˜‰
                        Thank you very much!
                          My brain really hurt with the logic of it... but now it's too obvious ๐Ÿ˜’
                          • dereiD Offline
                            derei
                            My brain hurt too trying to "discover" the reason why you tried such complicated ways to do it. Especially because my programming skills are like the result of rand method (yes, between 0 and almost 1 ๐Ÿ˜† ) and I try to learn something from what you do.
                              So it was a true random result! ๐Ÿ’š
                                Always funny and robust! ๐Ÿ˜Ž
                                re-apply on result with the all faces (top and lateral) ๐Ÿ˜‰
                                result is not too regular? (I took 1 and .1)
                                Does it possible to keep the first selection? (top faces)
                                  Unfortunately when you PushPull a face it disappears - the face that is at the new location isn't the same face - that's been deleted by Sketchup...
                                  So... it's not easy to get a reference to the new face...
                                  BUT you could do it... you know the plane of the picked face, you know its pt0=vertices[0].position, you know the pushpull vector, so you can offset the pt0 and then test for the new faces added since the pushpull was done and find the one with the same/reversed normal, parallel plane and coincident vertex at the offset pt0 location...
                                  BUT I'm not going to code it ๐Ÿ˜’
                                    In this particular case same "top square"
                                    I can use the Selected by aera by Sdmitch ๐Ÿ˜‰
                                      Except there might be faces with the same area that were not the ones you want - so then things like face.normal / plane becomes relevant too - BUT comparing areas IS a good 'outside-of-the-box' test idea ๐Ÿ˜‰
                                        As I had started from a sphere and took a minimum measure more large than the big edges on the surface's sphere ๐Ÿค“
                                        that can't be arrived ๐Ÿ˜‰
                                        It was a very particular case ๐Ÿ˜„
                                          Here's v2.4 http://forums.sketchucation.com/viewtopic.php?p=340452#p340452
                                          The selection now passes to the newly pushpulled faces even though the original faces have been deleted by Sketchup...
                                            Seems selection are not keeping all the initial faces selected! ๐Ÿ˜ฎ
                                            (tryed with some adjacents facets on a thick sphere )
                                            Does exist a Scale multiple ? (for each facets selected)
