    Looking for Plugin
    9 Posts 6 Posters 723 Views 6 Watching
    • kenK Offline
      ken
      Question:
      Is there a plugin that will make scenes for each layer? So if I have 5 layer, run the plugin, the plugin will create 5 scenes with the name of the layer. Seems I have seen a plugin that did this, however, I can not find it, or I am using the wrong search text.
      Thank you in advance
      Ken
        Copy+Paste this code into a file called layer2scene.rb in the Plugins folder
        module TIG
          def self.layer2scene()
            model.start_operation('layer2scene')
            layers=[];model.layers.each{|layer|layers<<layer.name}
            layers.sort.each{|name|model.pages.add(name)}
        Restart Sketchup.
        Type TIG.layer2scene in the Ruby Console to make a set of Scene tabs named after every Layer name... Making new scene tabs is not 'undo-able'... so save first and use with care!
        EDIT: use the corrected code in the post three on - this one has a typo 😳
        • kenK Offline
          ken
          Thank you for your quick reply. I added the line as indicated below as it did not work with the code you provided. So, I get two for the price of one. Some code that I will try to add to a toolbar and a learning exercise in Ruby. It is a good day when you have corrected TIG's code.
          module TIG
          model=Sketchup.active_model # Added by Ken
          Ken
            At times I wonder if he does this intentionally?
              Of course I did !
              The correct code is
              module TIG
              There is no point in adding a start/commit block as adding scenes is not undo-able! I edit the code at the last minute when I realized that BUT removed the wrong line... I was rushing because my dinner was ready πŸ˜’ even I have to eat πŸ€“
              Sorry for the balls-up - congrats on fixing it yourself... πŸ˜‰
                What?! You eat?!? 😲
                  I eat and drink... like mere mortals πŸ˜‰
                    But you don't sleep πŸ˜‰
                    • 3 Offline
                      3dsmax9
                      is it possible to hide the other layer excepte the one that hade the scene name? so you will have every layer in separate scene.
