    [Plugin] Component Edit Window v1.3 12072011
    46 Posts 18 Posters 56.3k Views 18 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Pc only version posted above.
      Edited component.
      Saving closes second window, and update is applied to the model.
        honoluludesktop
        Fixed "open component file" bug.
        • dereiD Offline
          derei
          I noticed different toolbars in Component Editing Window. Is that a feature included in plugin? will have just custom selected toolbars in new opened window?
          DESIGNER AND ARTIST DEREI.UK
            honoluludesktop
            The component window will inherit the menus from the parent. I changed the menus in my presentation of the edit window to illustrate how the plugin functioned, in a small picture.
            • EdsonE Offline
              Edson
              for your information, the makers of Podium have released a commercial plugin called EditinPlace that does exactly what yours does.
              http://www.mahfuz.arq.br
              • EarthMoverE Offline
                EarthMover
                Great idea! I always keep a 2nd SU open for this reason. This should streamline it quite a bit. Thanks! πŸ‘
                Content Creator at Skapeup
                  Ghalko
                  Definitely dabbling in the code to use existing components, or make them if they don't exist. First foray into ruby, I already dislike that it doesn't do much with curly braces and semicolons. I usually program C and PERL. πŸ’š
                  I just thought that it could be setup to save in a tree of folders, might make the code quite a bit longer, but might make saving components easy and finding them individually. Now to figure out how to only save the geometry in the components file and still load it into the trunk of the tree. 😲 My ideas are getting far beyond my grasp of ruby and the API. I should keep it simple for a bit.
                  When I get somewhere with it would you like me to post it or send you the code for perusal/editing?
                  Arrrggghhh! Why won't it make a face!!! Stupid, no good piece of... Oh look! The line went to the wrong point. Whew... moving on. (My fights with sketchup.)
                    honoluludesktop
                    Post it in the Developers section, there you can get help from those who are truly gifted in SketchUp ruby, and the Api. Everything I have written, was with their help.
                      artofseeing
                      hi,
                      the plugin is missing in my index menu.
                      also, when i try to load the plugin via ruby console,
                      my ruby console puts the following:
                      load component_edit_window_v1.0.rb
                      Error; #<SyntaxError; (eval);48; compile error
                      (eval);48; no .<digit> floating literal anymore; put 0 before dot
                      (eval);48; syntax error, unexpected tINTEGER
                      (eval);48
                      i have su8 installed in the default location.
                      and i put the plugin into Plugins.
                      thanks for any help.
                      πŸ‘
                      as long as there is a voyage away, there's always a journey back...
                      http://artofseeing.carbonmade.com
                        You need to pass a string to 'load' πŸ€“
                        It's NOT load component_edit_window_v1.0.rb
                        BUT load 'component_edit_window_v1.0.rb'
                        πŸ˜’
                        To check the file really exists use this in the Ruby Console
                        File.exist?(File.join(Sketchup.find_support_file('Plugins'),'component_edit_window_v1.0.rb')) if 'false' then 'there's a rabbit away'!
                        If you have Vista or Win7 and don't have full permission to the subfolders within the Sketchup folder weird things can happen - you think you've added a file but the OS has actually put it into a side-folder - the 'Compatibility Files' issue... If this is the case look to see if there's a button of that name in the top window bars... Fix your permissions for all folders within the Sketchup folder so it doesn't recur...
                          artofseeing
                          twas indeed the permission issue.
                          both code snippets (load and file exist) put TRUE,
                          so now it works.πŸ˜„
                          thanks alot!
                          thats what i too call STREAMLINING!!
                          thanks a lot
                            you can now use this cool plugin by Sdmitch
                            Replace randomly components πŸ˜‰
                            (or not random if there is only one as source πŸ˜‰
                              pitrak
                              I've just tested the plugin on SU8 (win7 32bit) and it only works for groups, not components - the new SU window just doesn't load.
                              Any suggestions?
                              • dereiD Offline
                                derei
                                It doesn't work for me 😞
                                I tried to use it, but I get this error in console:
                                Error: #<NoMethodError: undefined methoddefinition' for #Sketchup::Group:0xe7a4c58>
                                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/component_edit_window_v1.0.rb:61:in atelier_edit_instance' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/component_edit_window_v1.0.rb:60:in each'
                                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/component_edit_window_v1.0.rb:60:in atelier_edit_instance' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/component_edit_window_v1.0.rb:124 (eval):3:in call'
                                (eval):3:in call' (eval):1:in get_New_Commands'
                                C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/component_edit_window_v1.0.rb:61:in call' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/component_edit_window_v1.0.rb:61
                                  dereeei
                                  Edit the .rb file at lines #55-56 using Notepad or similar plain text editor
                                  Change
                                  all_instances=componentdefinition.instances if all_instances[0]==nil
                                  to read
                                  all_instances=**cnt_instance.definition**.instances if all_instances**.length==1**
                                  this will avoid the potential glitch, which wrongly looks at the "model.defintions[0]" instances rather than the selected instance's definition's instances - and which might inadvertently throw up a 'group', which then won't have a ".definition" method in the API...
                                  • dereiD Offline
                                    derei
                                    @tig said:
                                    dereeei
                                    Thank you very much. All is fine.
                                      We've decided to post an updated version of this useful tool.
                                      It corrects a rare glitch reported the the recent post.
                                      Get the updated version from here http://forums.sketchucation.com/viewtopic.php?p=296715#p296715
                                      As you probably know, sadly the script's author died a few weeks ago, he would have done it if he could 😞
                                        Here's a version that attempts to fix a glitch on the MAC, deleting temp files
                                        Please remember to name components without characters that mess with system like NO /:<>?* or accented characters etc...
                                        As you probably know, sadly the script's author died a few weeks ago, he would have done fixed this if he could 😞
                                        • jeff hammondJ Offline
                                          tested new version on mac. (v1.2)
                                          there's no ruby message this time (re: that other thread discussing this)
                                          i named a component 'test'
                                          context menu -> component edit window
                                          popup "insert instance: test" -> OK (in the previous version, after clicking OK is when the error message appeared in the ruby console)
                                          nada
                                            Sorry Jeff... It's not my baby and I have a zillion other things to do... I think we stick here for now 😒
                                            • 1 / 3
