    Who changed extensions.rb?
    22 Posts 11 Posters 3.1k Views 11 Watching
    • jeff hammondJ
      i suspect your user has come across a .zip for download that i've seen on the interweave and they actually installed it..
      the zip contains a 90MB plugins & a 35MB tools folder and they're filled with various plugins.. file mgmt is very poor-- for instance, there's freescale & fredoscale and on top of that, there are all the various updated files that need to be replace upon updating certain scripts.
      some of the files in the plugins folder are also in the tools folder etc..
      the tools folder contains the extensions.rb that's dated 2005-2008 while the plugins folder contains the extensions.rb file dated simply 2005.
      i'd love to post the link here so you all could have a laugh at this mess but unfortunately, the folders also contain a few premium plugins.
      [but yeah, i'm just listing one possibility and am in no way accusing your user of pirating.. (well, maybe in a small way i am doing just that but i'm just someone on the internet so my opinion doesn't matter πŸ˜„)]
      [edit] see.. ken had the double extensions file so maybe your guy didn't come across this zip i'm talking about afterall
        As a 'health-check' can I suggest that anyone who thinks they have a mess up looks in their ../Plugins folder for the following .rb files that ought to appear only in their ../Tools folder.
        If they are in the wrong folder move them [back] into ../Tools; if they are duplicated then remove the Plugins folder's version.
        Depending on your SUp version, and what optional tools you might have, you could have these .rb files...
        Which should be in ../Tools if you have them at all...
        The bold ones are the base-set for most setups and have been around for several versions...
        advancedcameratools
        date
        dynamiccomponents
        extensions
        filmandstage
        langhandler
        make_pano_pm
        rational
        sandboxtools
        shadowstringsfix
        SolarNorth
        webtextures
        Several of these have matching subfolders - e.g. 'Sandbox' within ../Tools too...
        If you are in any doubt ask.
        Don't delete any duplicated files you find but rather move them into a [new name='disabled'] subfolder so they don't auto-load - then you can always restore them when you've gone wrong πŸ˜’
          spring.freediver
          TIG,
          Yes , I had actually intended for GeoSketchFreeLoader not to be scrambled. That is the reason it is so small. When the installer was made, it inadvertantly got scrambled. But it should have worked anyway, and does with the Google version of extensions.rb.
          Regarding InstantRoof, I was only reporting the symptom reported to me. I don't know why InstantRoof would crash when the modified extensions.rb was removed, unless something else was changed accidently.
          Jeff
            Jim
            THe plugin SCF Power toolbar by CadFather is the one that may distribute extensions as well as sketchup.rb. Possibly his other toolbars do as as well.
            Nice idea - bad implementation.
              Has someone told him to stop ???
                Jim
                I mentioned it here:
                404 Not Found
                (forums.sketchucation.com)
                • Chris FullmerC
                  There is a plugin out there that changes some base classes that has been known to crash many plugins:
                  sunposition.rb
                  If they have that in their plugins folder, instant roof will break, so will thea exporter, surface gen, and many others. If they have that script, they should burn it like the plague and never use it again.
                  It does not, however, mess with the extensions.rb file. I tend to think that they copied that from previous plugins folders, back when that file used to be put by default in the plugins folder in version 5 (or maybe it was 4). Anyhow, just have them delete it, they won't need it. And delete sunposition.rb as well, if they have that.
                  • AdamBA
                    AdamB
                    Its incredibly annoying when people put out these crappy plugins like this.
                    I still have to check for that ****ing "Matchbox" plugin which totally screws the Sketchup 'class' system.
                    But you know, the headlong rush to these highly introspective/reflective languages which offer little in the way of "sealing" code is such a problem.
                    A Class definition once defined should be sealed and immutable. If you wish to specialize then derive from the super class and specialize-away, but being able to post something and walk away is pretty dangerous.
                    Can we hunt him down and have him shot? Thats reasonable isn't it? πŸ˜„
                    Adam
                    • fredo6F
                      I don't know if it is Sunposition tha removes or add the extension.rb, but, as said by Adam, it is for sure the source of conflicts because it overrides basic Ruby classes (and strangely for no special reason).
                      I came across this conflict between Sunposition and Curviloft.
                      I tried to contact the author, but still no answer
                      See that post, where I posted a modified version of sunposition.rb which is clean vis-avis Ruby and Sketchup
                        I did something similar with someones 'VirtualWind' script that messed with progressbar... πŸ˜’
                          I also contacted the developer of Sunposition - twice - still no response... πŸ‘Ž πŸ‘Ž
                          • AdamBA
                            AdamB
                            Hey, here's a thought.
                            Given we can't enforce a 'developer quality threshold', there is always going to dodgy code out there.
                            Can we use Ruby namespaces to sandbox each plugins view of the SketchUp classes? So if a plugin chooses to redefine true to be false and false to be SketchUp::Face etc. Well, it will just die in their plugin. Not mine. πŸ˜„
                            So something like alias the Sketchup:: namespace to be unique for each plugin.
                            How hard can it be? I'll leave the easy bit to others..
                            have a good one.
                            • KrisidiousK
                              Krisidious
                              you developers here on SCF could institute a rating system that told we layman if a plugin met certain standards. and that would give incentive to developers to meet that minimum standard if they wanted the SCF audience.
                              By: Kristoff Rand
                              • Chris FullmerC
                                Could we just re-write the sunposition plugin and send him an updated copy? It does not re-write that much. I started doing it yesterday, but in the end got in a little bit over my head. Anyone wanna give it a go?
                                • Dan RathbunD
                                  Dan Rathbun
                                  @adamb said:
                                  A Class definition once defined should be sealed and immutable. If you wish to specialize then derive from the super class and specialize-away, ...
                                  The augmentation of Ruby objects at runtime is a very powerful (and one of my favorite,) features of the Ruby language. This is what is called a Dynamic Language.
                                  Without it, Ruby would be as mundane as Pascal, etc.
                                  I'm not here much anymore.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    Sometimes this works.. many times not.
                                    The major problems are with the Sketchup::Drawingelement subclasses. All the API add entity methods (as well as the Dynamic Components extension,) are hardcoded to only accept exact class names (such as Sketchup::Face,) instead of accepting arg.kind_of?(Sketchup::Face)
                                    So cloning the toplevel Sketchup module into another namespace may not work.
                                    EDIT: But don't let my thots keep you from experimenting ... (I'd be happy to be proved wrong on this.)
                                    • fredo6F
                                      Chris,
                                      I did it actually. See this post, which contains the modified version
                                      May be we should publish it in a place which is more accessible
