    Bike Badge for 3D Printing
    10 Posts 7 Posters 1.0k Views 7 Watching
      d12dozr
      Here is a project I finished this week...the request was to turn a logo image into a model that could be 3D printed and used as a badge attached to the 31.6mm head-tube on a bike. I was able to get 2D DWG's from the original Illustrator file, but in the end (because of extra/uneven line segment headaches) I would have been better off drawing all but the lion rampant in SU.
      Edit: Changed griffin to lion rampant...thanks TIG
      Placement shown on a random bike from the 3D warehouse
      http://goo.gl/f7ooYh
      • Bryan KB Offline
        Nice!
          Very impressive.
          Did you model larger and scale down to avoid the problem of creating very small faces.
          By the way it's not a 'griffin' it's a 'lion rampant' - symbolizing 'fierce courage' in heraldry πŸ˜‰
            d12dozr
            Thanks, guys. Yes TIG, I modeled at 100x scale and still had problems with missing faces after running Shape Bender (BTW, getting the correct arc was kinda hard πŸ‘Ώ ). Strangely, if I tried running Shape Bender at 1000x scale, SU crashed every time, but 100x scale was OK πŸ˜•
            Thanks for the lion rampant correction πŸ˜„
              What'd make this pop even more is if you had an embossed image to run BitmaptoMesh on. Just on the griffin. Especially if it's getting printed in 3D.
              Other than that it's some lovely modeling Marcus πŸ‘
                pixelmonkey380
                πŸ‘
                chris<pixelmonkey>:D
                • bmikeB Offline
                  bmike
                  nicely done!
                  i had to bend an entire house (client wanted to see 2 versions...)
                  i modeled the 'straight' version first, then used FredoScale to bend the house.
                  windows, doors, stairs, trim, etc. i broke the house into pieces, and bent each piece with the same reference points and angles to match a radius that i pre-tested. time consuming to get the setup right - but once that was done - it saved me from re-drawings the entire thing on and arc.
                  i'll have to look at shapebender...!
                    d12dozr
                    Thanks, guys. Rich, I agree, and although it didn't work out on this project, I am planning on trying that method soon.
                    Mike, I think you'll find Shapebender to work nicely, you may need to explode any nested components down. It takes a looong time for complex models, ~1 hour for this model (38,782 triangles), but the results are excellent. Thanks, Chris!
                    • RichardR Offline
                      Richard
                      WOW Marcus - What a funky little job! And well donw to boot!
                      I always think it weird the stuff that pops up here and there that people are requested to do!
                      Who would have thought something like that would land on your lap!!
                      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                        d12dozr
                        Thanks, Richard! I really went looking for it (in a different forum), I've been interested in 3D printing and related opportunities lately.
