    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.1k Views 172 Watching
      matidami14
      ok, thankyou!
      i will try.
      someone have one work finished to share? (skp file and jpg image)
        Matidami14
        Why can't you edit the three files yourself they are inside the Plugin's subfolder ?
          matidami14
          i already do that, look this files:
          http://www.sendspace.com/file/7b8f80
          when i render the skb, the rectangles apears again! i guess its vray.. the ocult geometry shows in the process
            Make sure that the texture's image file has a totally transparent background with ALL pixels completely transparent etc...
            • rodrigonotorR Offline
              rodrigonotor
              matidami14, take a look of this, maybe work for you.
              http://img803.imageshack.us/img803/6654/20052011075532pm.jpg
              the files are in here:
              http://www.sketchando.net/descargas/ivy_leaf_enavas_ver6.0.rar
              Regards
              • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
              • romboutR Offline
                rombout
                o bad the script doesn't have rotation for the leaves. Something like a min and max, now it always looks really flat and evenly
                • KrisidiousK Offline
                  Krisidious
                  following...
                  By: Kristoff Rand
                  • N Offline
                    neonro2003
                    It works fine
                    http://www.mypicx.com/06072011/Ivye/
                      matidami14
                      Regards
                      ok.. this is frustrating 😞
                      i have check all the probabilities and nothing happens...
                      i think it's my SU (sketchup 8 pro)
                      any one can please tell me step by step (yes, i'm diot!) how to intall, run and render ivy?
                      i really need this..
                        jokewalker
                        Noobie to posting and to Ruby so I'm not sure if I'm missing something basic. I'm having similar issues to others in 0.6.3beta. The only error I see is:
                        "Error: #<ArgumentError: Cannot find material named ivy_stem>"
                        I've checked my Textures folder (the properly saved one for SU7.1) and all the filenames are consistent. Is this an issue that needs to be solved in the console???
                        Any insight will help...Thx
                          Try making a new material called "ivy_stem" and rerunning it.........
                            jokewalker
                            TIG,
                            That fixed it! I figured it was something simple. Now to play around with this thing and see what it's made of.
                              There's certainly an error in the tool's code that's NOT making the material named 'ivy_stem'... BUT if you make it before using the tool it will work...
                              Hopefully an update will fix this glitch...
                              • romboutR Offline
                                rombout
                                how come for a lot of peeps the 0.6.3 versiion does work?
                                on the mac i doesnt do anything, no feedback no nothing?! 😲
                                  I don't know.
                                  The scripts form a complex web methods etc.
                                  There are clearly issues like some variables defaulting to 'nil' when they should be 1 or 0, and now this 'ivy_stem' material not getting made...
                                  It needs something of an overhaul... 😕
                                  • OxerO Offline
                                    Oxer
                                    Hi Rombout,
                                    Try this version, works for me on Mac OSX 10.6.7 and SU 8.
                                    Keys on Mac:
                                    Click where you want the Ivy to start grow.
                                    Cmd+Click : Make the ivy grow towards the mouse position.
                                    Alt+Click : Grow Ivy leafs.
                                    SHIFT+Click : Finish Ivy.
                                    Keyboard 'i' : Start over.
                                    SU Ivy works on Mac
                                    • romboutR Offline
                                      rombout
                                      Hi Rombout,
                                      Keys on Mac:
                                      [attachment=0:3k2xek9g]<!-- ia0 -->SketchupIvy.0.6.beta.zip<!-- ia0 -->[/attachment:3k2xek9g]
                                      Hahaha you already gave it me! Thanks anyway this one does workl indeed.
                                      Petty that the last revision doesn't work and doesn't give any feedback in the ruby console. Think we simply need to be patience
                                        driven
                                        @ Oxer and rombout,
                                        if you swap the html file out of 0.6.3 it's better formated for the mac [and shouldn't ruin anything]
                                        I only get one or 2 leaves with Oxers 0.6, and 0.6.3 has stopped working since I upgraded Safari to 5.0.6.
                                        what Safari versions are you both using?
                                          The latest version of Safari broke one of my commercial plugins dialogs on MAC!
                                          Now fixed... BUT it's very unforgiving of even minor syntax foibles that used to work anyway - unlike it's precursors and IE [dare I say!]... 🤓
                                          • romboutR Offline
                                            rombout
                                            @driven said:
                                            @ Oxer and rombout,
                                            oww...
                                            i fixed it myself by adjusting the dimensions of the popup window in SU. i edited one of the *.rb files.
                                            I also think it doesnt have something to do with safari i use firefox as a standard and a have edited it so that all files will be opened through FF
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 36
                                            • 37
                                            • 29 / 37
