    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.4m Views 345 Watching
    • GaieusG
      Aha, yes, I can see. Those are the toolbar "inner" separators. Those can be removed I am sure (only not sure where in the script...)
        You can read/edit a .rb script with a plain-text editor [like Notepad[++].exe]... do NOT use a wordprocessor as that can add special characters that will break the script's functions!
        There is a file 'FredoScale_Box.rb' [inside the subfolder 'FREDOSCALE_Dir_21' - or a similar name depending on the current version!] - you should make a backup copy of it to use to revert to if you mess up!...
        In the file there are 4 lines that add 'separators' - using the code:-
        menu.add_separator
        • you can find these in lines 700, 705, 719 and 732.
          If you add a ' #' to the start of these lines it will disable them...
          Test how the tool works after making these adjustments, saving the file and restarting Sketchup... if it works πŸ˜„ ... but if it messes up simply remove a ' #'... OR revert to the original saved file... πŸ€“
        • fredo6F
          Gaieus,
          You are right. There is the option in Default Parameters
          PS @TIG : All menus and toolbars are managed by LibFredo6. So it is not easy to tweak the code locally.
          • N
            narayan
            Hi all,
            Thanks for the replies.
            I am using v3.7b (confirmed by using the Window>LibFredo6 settings...>About menu). Yet I do not see the Active options at statup section at all. It only has four sections: Plugin configuration, inference for lines, Check for update and Palette configuration. It does not have the two sections shown in Fredo6's screenshot.
            I tried to "Reset factory" button, but it did not change anything.
            There is another problem, which may be related: When I restart SletchUp, the FredoScale6 toolbar on its own folds into a 3-column toolbar, as shown here:
            http://db.tt/QXJ3PsH
            This does not happen always, but very often. I have to drag the toolbar in the "canvas" area, fold it into a two-column toolbar and place it back.
            %(#0040FF)[I am not sure whether this is a problem in FredoScale toolbar or a problem with SU8; because twice all the toolbars became flat horizontal bars, and escaped their positions, and lined up vertically (one below the other).
            While looking for solution, I read that SU has a bug which makes it forget the toolbar positions. While SU8 has improved, the problem is not resolved entirely.]
              Narayan
              You are in charge of the toolbars - not the other way around!
              The default for the FredoScale toolbar is perhaps three columns... BUT if you drag it by its top-bar so that it's no longer docked at the side, but now 'floating' you can simply grab a corner with your mouse and resize it by dragging... to be whatever number of columns you want - from one column with multiple rows, up to one row with multiple columns. You want two columns so make it have two columns. Then re-dock it by dragging it back into the side bar by its top-bar - it now has the two columns when docked ??
              This is my usual settings for that toolbar - located very near where you have yours...Capture.PNG The second is with 'no-separator' set in the options dialogCapture1.PNG
              • fredo6F
                The default parameter is in FredoScale, not LibFredo6. So menu Fredo6 Collection > FredoScale > Default Parameters...
                • GaieusG
                  Fredo, it is excellent! Thanks! I did not even know that (true my toolbars are horizontal).
                  I know you always build in many customizable parameters - maybe too much sometimes so we cannot always remember (but of course, the "too much" here does not mean any critics - just my own opinion on my own laziness and superficial reading the manuals).
                  πŸ˜„
                  • massimoM
                    massimo Moderator
                    Also with horizontal toolbar it takes less space. πŸ˜‰
                    • fredo6F
                      πŸ˜„
                      Actually this was a request from a user!
                      It's always a good idea to have a look at the Default Parameters section, as this is very often how I customize things which are undecidable.
                      • N
                        narayan
                        Thanks Fredo!
                        That solution worked well. I hope SU8 does not let the toolbars escape once again (the Fredo6 collection toolbar seems to play truant often.)
                        BTW it is confusing to have window settings in two different menus:
                        • Tools>Fredo6 collection>plugInName>Default parameters and
                        • Windows>LibFredo6 settings > Default parameters
                        TIG, thanks for the tip; but I already follow what you described (that is what I posted earlier: I undock the toolbar; fold it in a two-column configuration, and dock it again.)
                        I actually described three possibly related problems.
                        One of them is resolved thanks to the settings.
                        The other two problems which are not yet resolved are-
                        1. The Fredo6 toolbar snaps back to a three-column configuration on its own.
                        2. ALL the toolbars escape their docking positions and pile up vertically (each toolbar takes up one line on its own). Then I have to drag each toolbar back to the top or left of the screen. This is a huge time-waster.
                        In fact, I face the toolbar problem even without restarting SU8 OR restarting the PC: It simply happens even while I am working SU8. All of a sudden the toolbars escape and occupy the top of the screen, leaving very small space for the canvas area.
                        I mentioned all three problems here because I am not sure whether the problem lies in SU8 or Fredo's plugin system. I somehow feel they are related.
                        Thanks.
                        • COSEDIMARCOC
                          COSEDIMARCO
                          Updated version of the Italian Translation
                          Italian Translation Updated version
                          [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                          • dereiD
                            derei
                            @narayan said:
                            Excuse me, I noticed some "strange looking buttons on the toolbar image posted by narayan.
                            I marked them with red in the image, please tell me what are they and where I can find them?
                            Thank you.
                            DESIGNER AND ARTIST DEREI.UK
                            • GaieusG
                              The top left one is Pen tools by Rich:
                              http://forums.sketchucation.com/viewtopic.php?t=37359
                              (I don't know the others either)
                              Rather messy toolbars however. πŸ˜’
                              • L
                                Lorelalala
                                Thank you, Fredo!
                                • T
                                  Tinygrasshopper
                                  Hi!!
                                  First of all : Muchas gracias! Super plugin!
                                  Now... I have somme trouble with the plugin. Almost everything works fine, but "PlanarShear" and "Radial Bend" give me a bugsplat immediately, no matter the size or the form of the component, even with a single line ❓
                                  I tryed everything i found on the forum, i updated the plugin, i updated de Fredo Lybrary, etc.
                                  The bugsplat gives me : SketchUpP2JD3HV5.dmp, OG5T2D56.xml, SketchupUndo0.log
                                  I work on Windows XP, SU 7.0.11018, 3Go of Ram, Intel Dual-Core E5300 (I know my PC s***ks, but is not mine, is my firm's).
                                  Any ideas? Thanks in advance!
                                  • fredo6F
                                    @tinygrasshopper said:
                                    Hi!!
                                    When do you get the blug splat
                                    • when you select and start FredoScale
                                    • When you generate the transformation.
                                      Also, could you open the Ruby console, to see if you see something displayed just before you get the bug splat.
                                      Thanks to be more accurate on the conditions
                                      Thanks Fredo πŸ‘
                                        That is a really nice feature addon. πŸ‘
                                          jorge2011
                                          Thank you very much Mr. Fred for this new update. It is very good.
                                          If possible, the next update adds the option to change the color and size of the nodes in the boxes?
                                          and switch on or off the visualization of the axes
                                          thank you very much
                                          • fredo6F
                                            NEW RELEASE: FredoScale 2.2a- 24 Jul 11
                                            This release integrate a feature of Collapsing handles when dimensions are small on screen.
                                            This was suggested in a request by Cunningham.
                                            Kyyu also produced a plugin "Simple Scale Tool Handles" for the standard Scale tool.
                                            The principle is to hide the handles on corners and edges when the dimension of a side appears too small on the screen (like this is usually the case for boards or for timbers). However, when you zoom in, all handles will progressively reappear.
                                            By default a dimension is considered "small on screen" if its size appears to be under 30 pixels in the current view. You can change this value in the Default Parameters dialog box. Note that entering a value of 0 will disable the feature, i.e. all handles will always appear.
                                            Note also that as of this release, the Dice option (activated by F4) is active by default
                                            Please see main post for download
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 58
                                            • 59
                                            • 30 / 59
