    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.1k Views 172 Watching
    • romboutR Offline
      rombout
      nothing in su8 mac...
      even nil change to 1 doesnt do anything, also no errors or feedback from the rubyconsole
      • rodrigonotorR Offline
        rodrigonotor
        Translation version 0.6.3 beta to spanish
        Traducción de la versión 0.6.3 beta al español
        SketchupIvy.0.6.3.esp_beta.rar
        • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
        • sadyoS Offline
          sadyo
          Perhaps this could be useful,
          http://photoserver.ws/images/3AOt4de66fdea6ebb.jpg
          I am following what TIG says, about better test if the variable is NOT 'nil', then i try to fill a variable on the Branch Detail,...and voilaaa.... the Ivy appearing like it should and the SketchUpIvy0.6.3 can work very well now .
          Thanks TIG...Thanks Piereden
            matidami14
            i have the same problem. the leaf image its not right.
            it apears a rectangle in the limits of the image area, and someones have this white area.
            may be ther ins't some details in the instructions
            please answer me
              There are some problems with the three ivy leaf skp files pre-provided...
              The files are quite large because tif images were used; smaller png images with transparent backgrounds would suffice - these could be edited to fix this.
              The other issue is that these skp files currently have the four sides of the rectangular face as regular edges, which will inevitably show up when imported as a component. If the original skp is edited and the four edges selected and made 'hidden' then the imported leaves will no longer shown them [unless of course view>hidden-geometry is 'on' when they'll look like dotted lines]... If you've already got some such leaves imported you can edit them in situ and make their edges hidden - as they are instances, editing one should edit all of its siblings...
                matidami14
                ok, thankyou!
                i will try.
                someone have one work finished to share? (skp file and jpg image)
                  Matidami14
                  Why can't you edit the three files yourself they are inside the Plugin's subfolder ?
                    matidami14
                    i already do that, look this files:
                    http://www.sendspace.com/file/7b8f80
                    when i render the skb, the rectangles apears again! i guess its vray.. the ocult geometry shows in the process
                      Make sure that the texture's image file has a totally transparent background with ALL pixels completely transparent etc...
                        rodrigonotor
                        matidami14, take a look of this, maybe work for you.
                        http://img803.imageshack.us/img803/6654/20052011075532pm.jpg
                        the files are in here:
                        http://www.sketchando.net/descargas/ivy_leaf_enavas_ver6.0.rar
                        Regards
                        • romboutR Offline
                          rombout
                          o bad the script doesn't have rotation for the leaves. Something like a min and max, now it always looks really flat and evenly
                          • KrisidiousK Offline
                            Krisidious
                            following...
                            By: Kristoff Rand
                            • N Offline
                              neonro2003
                              It works fine
                              http://www.mypicx.com/06072011/Ivye/
                                matidami14
                                Regards
                                ok.. this is frustrating šŸ˜ž
                                i have check all the probabilities and nothing happens...
                                i think it's my SU (sketchup 8 pro)
                                any one can please tell me step by step (yes, i'm diot!) how to intall, run and render ivy?
                                i really need this..
                                  jokewalker
                                  Noobie to posting and to Ruby so I'm not sure if I'm missing something basic. I'm having similar issues to others in 0.6.3beta. The only error I see is:
                                  "Error: #<ArgumentError: Cannot find material named ivy_stem>"
                                  I've checked my Textures folder (the properly saved one for SU7.1) and all the filenames are consistent. Is this an issue that needs to be solved in the console???
                                  Any insight will help...Thx
                                    Try making a new material called "ivy_stem" and rerunning it.........
                                      jokewalker
                                      TIG,
                                      That fixed it! I figured it was something simple. Now to play around with this thing and see what it's made of.
                                        There's certainly an error in the tool's code that's NOT making the material named 'ivy_stem'... BUT if you make it before using the tool it will work...
                                        Hopefully an update will fix this glitch...
                                        • romboutR Offline
                                          rombout
                                          how come for a lot of peeps the 0.6.3 versiion does work?
                                          on the mac i doesnt do anything, no feedback no nothing?! 😲
                                            I don't know.
                                            The scripts form a complex web methods etc.
                                            There are clearly issues like some variables defaulting to 'nil' when they should be 1 or 0, and now this 'ivy_stem' material not getting made...
                                            It needs something of an overhaul... šŸ˜•
                                            • 36
                                            • 37
                                            • 4 / 37
