    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.1k Views 172 Watching
    • rodrigonotorR Offline
      rodrigonotor
      @vidy said:
      @sadyo said:
      I am following what TIG says, about better test if the variable is NOT 'nil', then i try to fill a variable on the Branch Detail,...and voilaaa.... the Ivy appearing like it should and the SketchUpIvy0.6.3 can work very well now.
      regards,
      Shame on me 😳 I don't understood what TIG says until now. The plugin works like charm.
      Thankyou guys.
      Sketchup 8.0.3117
      Sketchup Ivy 0.6.3
      Win 7 Ult
      • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
      • romboutR Offline
        rombout
        nothing in su8 mac...
        even nil change to 1 doesnt do anything, also no errors or feedback from the rubyconsole
          rodrigonotor
          Translation version 0.6.3 beta to spanish
          Traducción de la versión 0.6.3 beta al español
          SketchupIvy.0.6.3.esp_beta.rar
          • sadyoS Offline
            sadyo
            Perhaps this could be useful,
            http://photoserver.ws/images/3AOt4de66fdea6ebb.jpg
            I am following what TIG says, about better test if the variable is NOT 'nil', then i try to fill a variable on the Branch Detail,...and voilaaa.... the Ivy appearing like it should and the SketchUpIvy0.6.3 can work very well now .
            Thanks TIG...Thanks Piereden
              matidami14
              i have the same problem. the leaf image its not right.
              it apears a rectangle in the limits of the image area, and someones have this white area.
              may be ther ins't some details in the instructions
              please answer me
                There are some problems with the three ivy leaf skp files pre-provided...
                The files are quite large because tif images were used; smaller png images with transparent backgrounds would suffice - these could be edited to fix this.
                The other issue is that these skp files currently have the four sides of the rectangular face as regular edges, which will inevitably show up when imported as a component. If the original skp is edited and the four edges selected and made 'hidden' then the imported leaves will no longer shown them [unless of course view>hidden-geometry is 'on' when they'll look like dotted lines]... If you've already got some such leaves imported you can edit them in situ and make their edges hidden - as they are instances, editing one should edit all of its siblings...
                  matidami14
                  ok, thankyou!
                  i will try.
                  someone have one work finished to share? (skp file and jpg image)
                    Matidami14
                    Why can't you edit the three files yourself they are inside the Plugin's subfolder ?
                      matidami14
                      i already do that, look this files:
                      http://www.sendspace.com/file/7b8f80
                      when i render the skb, the rectangles apears again! i guess its vray.. the ocult geometry shows in the process
                        Make sure that the texture's image file has a totally transparent background with ALL pixels completely transparent etc...
                          rodrigonotor
                          matidami14, take a look of this, maybe work for you.
                          http://img803.imageshack.us/img803/6654/20052011075532pm.jpg
                          the files are in here:
                          http://www.sketchando.net/descargas/ivy_leaf_enavas_ver6.0.rar
                          Regards
                          • romboutR Offline
                            rombout
                            o bad the script doesn't have rotation for the leaves. Something like a min and max, now it always looks really flat and evenly
                            • KrisidiousK Offline
                              Krisidious
                              following...
                              By: Kristoff Rand
                              • N Offline
                                neonro2003
                                It works fine
                                http://www.mypicx.com/06072011/Ivye/
                                  matidami14
                                  Regards
                                  ok.. this is frustrating šŸ˜ž
                                  i have check all the probabilities and nothing happens...
                                  i think it's my SU (sketchup 8 pro)
                                  any one can please tell me step by step (yes, i'm diot!) how to intall, run and render ivy?
                                  i really need this..
                                    jokewalker
                                    Noobie to posting and to Ruby so I'm not sure if I'm missing something basic. I'm having similar issues to others in 0.6.3beta. The only error I see is:
                                    "Error: #<ArgumentError: Cannot find material named ivy_stem>"
                                    I've checked my Textures folder (the properly saved one for SU7.1) and all the filenames are consistent. Is this an issue that needs to be solved in the console???
                                    Any insight will help...Thx
                                      Try making a new material called "ivy_stem" and rerunning it.........
                                        jokewalker
                                        TIG,
                                        That fixed it! I figured it was something simple. Now to play around with this thing and see what it's made of.
                                          There's certainly an error in the tool's code that's NOT making the material named 'ivy_stem'... BUT if you make it before using the tool it will work...
                                          Hopefully an update will fix this glitch...
                                          • romboutR Offline
                                            rombout
                                            how come for a lot of peeps the 0.6.3 versiion does work?
                                            on the mac i doesnt do anything, no feedback no nothing?! 😲
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 33 / 37
