    [Plugin] Architect Tools
    119 Posts 32 Posters 173.2k Views 32 Watching
      Important!
      Update TT_Lib2 to version 2.5.2 which fixes a bug affecting repair edges.
        Important!
        Update TT_Lib2 to version 2.5.3 which re-fixes a bug affecting repair edges.
          dedmin
          2.5.2 or 2.5.3?
            whoops! 😳
            the latest. always the latest. 😄
              arjunmax09
              I'm having problem in using plan tools...i have latest version of tt_lib installed. plan tools just flattens the faces but doesn't extrude them. I've attached a video
              clip0002.rar
              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                That's because you're using a flat plan tool. If you look at my demo video, I use 3D plan data to generate the buildings. The faces are extruded up to the lines above it. The tolerance is not the extrude height - but the tolerance for closing open gaps in the lines.
                  cobb89
                  I'm also having the same problem as arjun ..how can one create a 3d plan data??...Isn't there any way to automatically generated extruded faces out of such plans??
                    We get such data from surveyors.
                    From 2d plans? No - how would you expect it to work?
                    What are you trying to do? Make a set of generic boxes at various heights? In which case you want to look at the Random Push-Pull plugin.
                    Plan Tools is intended to be used to help generate volumes based on accurate real world 3d data.
                      shoeb_cars
                      amazing...i wonder what more surprises are in store from you (the great ruby wizards 👍 )
                        jorge2011
                        Sr thomthom.
                        Thanks for this plugin.
                        Would it be possible to cut smooth lines?
                        Please see this post
                        404 Not Found
                        (forums.sketchucation.com)
                          Version 1.2.2
                          Minor Bugfixes
                          • N Offline
                            nektares
                            This is such a great plug-in, it should be on the must have visual index, it´s fantastic!
                              Anyone got a better suggestion for a name that might describe the plugin better?
                              • KrisidiousK Offline
                                Krisidious
                                Urban Importer? Urban Planner?
                                By: Kristoff Rand
                                • mitcorbM Offline
                                  mitcorb
                                  Here are a few words: 3d Site Plan Context Modeler Surround(s) Neighborhood Zone Focus Local. Feel free to Slice and Dice as you please.
                                  EDIT: I forgot Lifter Extruder AutoExtruder
                                  • utilerU Offline
                                    utiler
                                    How about 'Urban Morph tools'...?
                                    Just Curious...
                                    • mitcorbM Offline
                                      mitcorb
                                      Whoa, that just might be sinister enough 💚
                                      • utilerU Offline
                                        utiler
                                        Only for those with a twisted mind, Tim..... 😎
                                        Just Curious...
                                          Maybe I'm looking at it the wrong way. Maybe this plugin needs to be split into different plugins.
                                          • utilerU Offline
                                            utiler
                                            I think you right, Thom. Your plan tools are a little different from the urban forms tool..... Maybe expand city gen and incorporate the morph thingy....?
                                            Just Curious...
                                            • 2 / 6
