    [Plugin] Architect Tools
    119 Posts 32 Posters 173.2k Views 32 Watching
      That's the same Windows and SU version I use. I do not comprehend at all why you get that error.
      Can you post a screenshot of your plugins folder? and thre TT_Lib2 folder?
        blajnov
          @rv1974 said:
          If I take some vanilla line and try to 'grid dividing' I get a runtime error in line:29 (expected identifier,string or number).
          Is that the full error message?
          @rv1974 said:
          P.S. + Error in line 9 (UI is undefined)
          From SketchUp or the Webdialog? Again, is it the full error message?
            Oh, it's the same error Dave reported in CleanUp. Gotcha.
              What version of IE do you have installed?
                @blajnov: I really have no idea why you get those errors. Though your SketchUp folder looks odd. lots of other plugins folders. (but that might not mean much..)
                I can't read the language your OS is in, but is there anything in the Explorer window that says something like "Compatibility Files" when you're in the plugins folder?
                  rv1974: I've installed XP Mode and tried it out on a virtual PC with IE7 and I see the error. Seems to be an issue with IE7 and older. Will look into it next week.
                    blajnov
                    At work, set your plugins, everything runs fine, no problems ...
                    In the evening, I will seek a solution on a home computer.
                      Maybe try with an empty plugin folder. Rename your old and install just Plan Tools to see if it works isolated?
                        rv1974
                        I updated to IE8- no more runtime errors- thank you! (wouldn't it be neat to warn in red about this at the beginning of the thread?).
                        Still have problems with grid dividing. The result is random (posted the pic before).Do I have wrong expectations?
                        And at the end I got this:
                        undefined method `on_line?' for nil:NilClass
                        C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/point3d.rb:26:in between?' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:358:in intersect_plane_edges'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:354:in each' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:354:in intersect_plane_edges'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:334:in grid_divide' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:330:in times'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:330:in grid_divide' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:311:in grid_divide_ui'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb:160:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb:160:in initialize'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb:143:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb:143:in close'
                        C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb:143:in `initialize'
                        What it could mean?
                          I'll be looking into fixing it for IE7. I installed a virtual PC to test it on last night.
                          Problems are likely to be due to the errors. Can you upload your sample scene?
                            rv1974
                            catch it:
                            gr.skp
                              Cheers! I'll look at it when I get home today.
                                Version 1.2.1
                                • Fixes Grid Divide bug
                                  (There might be another bug in there. But I don't have much time for this function right now.)
                                Also: IE7 users should update TT_Lib2 to 2.5.1 which addresses IE7 error messages with the webdialogs.
                                  DIEGO-RODRIGUEZ
                                  as usual. excellent work. very professional.
                                  thank you very much
                                    Important!
                                    Update TT_Lib2 to version 2.5.2 which fixes a bug affecting repair edges.
                                      Important!
                                      Update TT_Lib2 to version 2.5.3 which re-fixes a bug affecting repair edges.
                                        dedmin
                                        2.5.2 or 2.5.3?
                                          whoops! 😳
                                          the latest. always the latest. 😄
                                            arjunmax09
                                            I'm having problem in using plan tools...i have latest version of tt_lib installed. plan tools just flattens the faces but doesn't extrude them. I've attached a video
                                            clip0002.rar
                                            when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                            • 2 / 6
