    [Plugin] Architect Tools
    119 Posts 32 Posters 176.9k Views 32 Watching
      rv1974: I've installed XP Mode and tried it out on a virtual PC with IE7 and I see the error. Seems to be an issue with IE7 and older. Will look into it next week.
      • B
        blajnov
        @thomthom said:
        @blajnov: I really have no idea why you get those errors. Though your SketchUp folder looks odd. lots of other plugins folders. (but that might not mean much..)
        I can't read the language your OS is in, but is there anything in the Explorer window that says something like "Compatibility Files" when you're in the plugins folder?
        At work, set your plugins, everything runs fine, no problems ...
        In the evening, I will seek a solution on a home computer.
          Maybe try with an empty plugin folder. Rename your old and install just Plan Tools to see if it works isolated?
            rv1974
            I updated to IE8- no more runtime errors- thank you! (wouldn't it be neat to warn in red about this at the beginning of the thread?).
            Still have problems with grid dividing. The result is random (posted the pic before).Do I have wrong expectations?
            And at the end I got this:
            undefined method `on_line?' for nil:NilClass
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/point3d.rb:26:in between?' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:358:in intersect_plane_edges'
            C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:354:in each' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:354:in intersect_plane_edges'
            C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:334:in grid_divide' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:330:in times'
            C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:330:in grid_divide' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_plan_tools.rb:311:in grid_divide_ui'
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb:160:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb:160:in initialize'
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb:143:in call' C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb:143:in close'
            C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb:143:in `initialize'
            What it could mean?
              I'll be looking into fixing it for IE7. I installed a virtual PC to test it on last night.
              Problems are likely to be due to the errors. Can you upload your sample scene?
                rv1974
                catch it:
                gr.skp
                  Cheers! I'll look at it when I get home today.
                    Version 1.2.1
                    • Fixes Grid Divide bug
                      (There might be another bug in there. But I don't have much time for this function right now.)
                    Also: IE7 users should update TT_Lib2 to 2.5.1 which addresses IE7 error messages with the webdialogs.
                      DIEGO-RODRIGUEZ
                      as usual. excellent work. very professional.
                      thank you very much
                        Important!
                        Update TT_Lib2 to version 2.5.2 which fixes a bug affecting repair edges.
                          Important!
                          Update TT_Lib2 to version 2.5.3 which re-fixes a bug affecting repair edges.
                            dedmin
                            2.5.2 or 2.5.3?
                              whoops! 😳
                              the latest. always the latest. 😄
                                arjunmax09
                                I'm having problem in using plan tools...i have latest version of tt_lib installed. plan tools just flattens the faces but doesn't extrude them. I've attached a video
                                clip0002.rar
                                when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                  That's because you're using a flat plan tool. If you look at my demo video, I use 3D plan data to generate the buildings. The faces are extruded up to the lines above it. The tolerance is not the extrude height - but the tolerance for closing open gaps in the lines.
                                  • C
                                    cobb89
                                    I'm also having the same problem as arjun ..how can one create a 3d plan data??...Isn't there any way to automatically generated extruded faces out of such plans??
                                      We get such data from surveyors.
                                      From 2d plans? No - how would you expect it to work?
                                      What are you trying to do? Make a set of generic boxes at various heights? In which case you want to look at the Random Push-Pull plugin.
                                      Plan Tools is intended to be used to help generate volumes based on accurate real world 3d data.
                                        shoeb_cars
                                        amazing...i wonder what more surprises are in store from you (the great ruby wizards 👍 )
                                          jorge2011
                                          Sr thomthom.
                                          Thanks for this plugin.
                                          Would it be possible to cut smooth lines?
                                          Please see this post
                                          404 Not Found
                                          (forums.sketchucation.com)
                                            Version 1.2.2
                                            Minor Bugfixes
                                            • 2 / 6
