    [Plugin] Architect Tools
    119 Posts 32 Posters 176.9k Views 32 Watching
      Version 1.2.1
      • Fixes Grid Divide bug
        (There might be another bug in there. But I don't have much time for this function right now.)
      Also: IE7 users should update TT_Lib2 to 2.5.1 which addresses IE7 error messages with the webdialogs.
        DIEGO-RODRIGUEZ
        as usual. excellent work. very professional.
        thank you very much
          Important!
          Update TT_Lib2 to version 2.5.2 which fixes a bug affecting repair edges.
            Important!
            Update TT_Lib2 to version 2.5.3 which re-fixes a bug affecting repair edges.
              dedmin
              2.5.2 or 2.5.3?
                whoops! 😳
                the latest. always the latest. 😄
                  arjunmax09
                  I'm having problem in using plan tools...i have latest version of tt_lib installed. plan tools just flattens the faces but doesn't extrude them. I've attached a video
                  clip0002.rar
                  when you fail at something....you haven't really failed...you've found one way the thing will not work out
                    That's because you're using a flat plan tool. If you look at my demo video, I use 3D plan data to generate the buildings. The faces are extruded up to the lines above it. The tolerance is not the extrude height - but the tolerance for closing open gaps in the lines.
                    • C
                      cobb89
                      I'm also having the same problem as arjun ..how can one create a 3d plan data??...Isn't there any way to automatically generated extruded faces out of such plans??
                        We get such data from surveyors.
                        From 2d plans? No - how would you expect it to work?
                        What are you trying to do? Make a set of generic boxes at various heights? In which case you want to look at the Random Push-Pull plugin.
                        Plan Tools is intended to be used to help generate volumes based on accurate real world 3d data.
                          shoeb_cars
                          amazing...i wonder what more surprises are in store from you (the great ruby wizards 👍 )
                            jorge2011
                            Sr thomthom.
                            Thanks for this plugin.
                            Would it be possible to cut smooth lines?
                            Please see this post
                            404 Not Found
                            (forums.sketchucation.com)
                              Version 1.2.2
                              Minor Bugfixes
                              • N
                                nektares
                                This is such a great plug-in, it should be on the must have visual index, it´s fantastic!
                                  Anyone got a better suggestion for a name that might describe the plugin better?
                                  • KrisidiousK
                                    Krisidious
                                    Urban Importer? Urban Planner?
                                    By: Kristoff Rand
                                    • mitcorbM
                                      mitcorb
                                      Here are a few words: 3d Site Plan Context Modeler Surround(s) Neighborhood Zone Focus Local. Feel free to Slice and Dice as you please.
                                      EDIT: I forgot Lifter Extruder AutoExtruder
                                      • utilerU
                                        utiler
                                        How about 'Urban Morph tools'...?
                                        Just Curious...
                                        • mitcorbM
                                          mitcorb
                                          Whoa, that just might be sinister enough 💚
                                          • utilerU
                                            utiler
                                            Only for those with a twisted mind, Tim..... 😎
                                            Just Curious...
                                            • 2 / 6
