    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 962.3k Views 175 Watching
      @jim said:
      @tig said:
      Your screen-shot suggests that #extrusionToolbar.rb is missing as there's no 'Extrusion Tools' submenu ??
      Ah, I renamed it without the #. Guess I can't do that.
      NO! It needs to load before the other tools so they find the toolbar/submenu ready-made...
      The existence of the EEby...rb tools are checked by it 'by name' so renaming all of those would also stop the toolbar/submenu getting created...
      Its filename doesn't have to start with a #, it just needs to list somewhere before the other tools in alphanumeric order... I use a leading # on the name of for my tools if I want it to load early - like the '#HolePunchTool.rb', as I want its items high up on the context-menu listings...
      πŸ˜’
        Jim
        And I use C:\Plugins rather than the default so I can share plugins between versions. EEbX isn't portable in that way either.
        Thanks.
          Jim
          I made these mods to make it portable:
          starting @ ~ line 50
              eePlugins.each{|plugin|
          	path = File.join(File.dirname(__FILE__), plugin+".rb")
          	#if Sketchup.find_support_file(plugin+".rb","Plugins/")
          	if File.exists?(path)
          	    gotPlugin=true
          	    break
          	end#if
            Here's an updated set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
            The tool now makes the Extrusion Tools toolbar/submenu even if the various .rb files are not located in the standard ../Plugins/ folder and are loaded from elsewhere [it now uses File.dirname(__FILE__) rather than the .find_support_file() which is limited to a standard set of folders]. It just requires that all of the files [including those in the ../TIGtools/ submenu] are kept in the same relative locations rather than the previous absolute ../Plugins/ location...
            It also includes the latest Chinese lingvo files, thanks to 'hebeijianke'...
              > 	    gotPlugin=true
              > 	    break
              > 	end#if
              I had just made very similar changes - you posted as I uploaded it - see updated set... πŸ˜’
                Jim
                Frequent updates are another advantage of using a shared Plugins folder! πŸ˜†
                Thanks again.
                  I think I'm done for a while on updating this tool... πŸ˜’
                  • U Offline
                    unclex
                    Sorry , my mistake
                    the reason is another Plugins
                    Thanx for ur replied
                      manson666
                      I'm new Sketchup user
                      now learning it
                      I founded out sketchup plug in is strong tool
                      thx share
                      • O Offline
                        openhatch
                        If I haven't said this before, awesome tools, thx. πŸ‘
                        This doesn't play well with SketchyPhysics; this newest version won't extrude edges by rails successfully if SketchyPhysics is installed. So I keep the two installed in different versions of Sketchup. 😞
                          I know about the SketchyPhysics issue - it can also affect other tools... http://forums.sketchucation.com/viewtopic.php?p=300111#p300111
                          The fix is relatively simple BUT it means recoding a few lines in one of the SketchyPhysics rubies...
                          http://forums.sketchucation.com/viewtopic.php?p=300105#p300105
                            Destors
                            How i need to make these things, help me please πŸ˜„
                            http://pix.playground.ru/download/gallery/664241/e8dc3ff2a2429a9a221028809dbf41d6.jpg
                            http://pix.playground.ru/download/gallery/664241/f57318be4e038aa96c6285ff3df68a19.jpg
                            • O Offline
                              openhatch
                              Okay, I knew you knew; I guess I might have clarified I was wondering if it's an outstanding problem (I hadn't read those posts you link to here). But the fix you link to will do (assuming it works, as I haven't tried it yet), thanks!
                              • ? Offline
                                [[global:former-user]]
                                Thanks guys this is extremely good plugin that i was looking for so long
                                  doraemon79
                                  Wonderful tool....
                                    rock1
                                    this toolset is a bit complicated for usage for a novice like me. I'm getting some unexpected results. Are there any video tutorials πŸ˜’
                                    Signature removed by SCF Admin
                                    • majidM Offline
                                      majid
                                      ow... it jumps out of Sketchup with no error message!!! (almost half of tools!!!! eebe , eebf,eebfs, EEbR)
                                        Majid
                                        Have you installed any new Plugins lately?
                                        Try disabling them temporarily and see if that helps.
                                        Do you get any error messages in the Ruby Console before the 'crash'?
                                        If you do find the culprit let use know asap.
                                        πŸ˜•
                                        Have you tried repair/reinstall Sketchup and/or reinstalling the Extrusion tools again...
                                        This is weird πŸ˜•
                                          You might find it helpful to learn the basic tool set first. And then search through the forum because there's lots of information on using TIG's Extrude Tools. He did instructions for all of the tools in individual threads.
                                            rock1
                                            I'm unable to have the first button, don't know why.
                                            http://i.imgur.com/xFvTG.jpg
                                            This has been a problem since a long time. I have got now windows 7 ultimate but the problem is still there. I did a fresh download of this set, overwrote the old extrude tools files but the problem is still there. πŸ˜•
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 31
                                            • 32
                                            • 12 / 32
