    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
      manson666
      I'm new Sketchup user
      now learning it
      I founded out sketchup plug in is strong tool
      thx share
      • O
        openhatch
        If I haven't said this before, awesome tools, thx. ๐Ÿ‘
        This doesn't play well with SketchyPhysics; this newest version won't extrude edges by rails successfully if SketchyPhysics is installed. So I keep the two installed in different versions of Sketchup. ๐Ÿ˜ž
          I know about the SketchyPhysics issue - it can also affect other tools... http://forums.sketchucation.com/viewtopic.php?p=300111#p300111
          The fix is relatively simple BUT it means recoding a few lines in one of the SketchyPhysics rubies...
          http://forums.sketchucation.com/viewtopic.php?p=300105#p300105
            Destors
            How i need to make these things, help me please ๐Ÿ˜„
            http://pix.playground.ru/download/gallery/664241/e8dc3ff2a2429a9a221028809dbf41d6.jpg
            http://pix.playground.ru/download/gallery/664241/f57318be4e038aa96c6285ff3df68a19.jpg
            • O
              openhatch
              Okay, I knew you knew; I guess I might have clarified I was wondering if it's an outstanding problem (I hadn't read those posts you link to here). But the fix you link to will do (assuming it works, as I haven't tried it yet), thanks!
                A Former User
                Thanks guys this is extremely good plugin that i was looking for so long
                  doraemon79
                  Wonderful tool....
                    rock1
                    this toolset is a bit complicated for usage for a novice like me. I'm getting some unexpected results. Are there any video tutorials ๐Ÿ˜’
                    Signature removed by SCF Admin
                    • majidM
                      majid
                      ow... it jumps out of Sketchup with no error message!!! (almost half of tools!!!! eebe , eebf,eebfs, EEbR)
                        Majid
                        Have you installed any new Plugins lately?
                        Try disabling them temporarily and see if that helps.
                        Do you get any error messages in the Ruby Console before the 'crash'?
                        If you do find the culprit let use know asap.
                        ๐Ÿ˜•
                        Have you tried repair/reinstall Sketchup and/or reinstalling the Extrusion tools again...
                        This is weird ๐Ÿ˜•
                          You might find it helpful to learn the basic tool set first. And then search through the forum because there's lots of information on using TIG's Extrude Tools. He did instructions for all of the tools in individual threads.
                            rock1
                            I'm unable to have the first button, don't know why.
                            http://i.imgur.com/xFvTG.jpg
                            This has been a problem since a long time. I have got now windows 7 ultimate but the problem is still there. I did a fresh download of this set, overwrote the old extrude tools files but the problem is still there. ๐Ÿ˜•
                              There are only ever 11 buttons - there are only 11 extrudeEdgesBy...rb files!!!
                              I suspect that you have put one of the files into two auto-loading locations or have two copies with slightly different names in Plugins - so something is loading twice but the 1st time its icon files are not found - SO... what is the first button ? See its Tooltip etc or look in the Plugins>ExtrusionTools... for a submenu duplicate.
                              Temporarily move all of the 11 'good' extrudeEdgesBy...rb files into another folder and restart SUp [leave the #extrusionToolbar.rb in placeso the toolbar MIGHT get made]. Then you can track down the culprit - perhaps something like 2x extrudeEdgesByEdges.rb ??
                              Let us know when you've fixed it.
                                rock1
                                Whoa what a shot TIG!, bingo, its' the one extrude edgesbyedges, WTH it's duplicated ๐Ÿ˜† !!!. ๐Ÿ˜ฎ I'll try to solve. i'm getting a duplicate in plugins menu man!! ๐Ÿ˜ฒ
                                  rock1
                                  i am unable to solve this problem. what should i do โ“
                                    Have you got two brain-cells to rub together ๐Ÿ˜’
                                    You have got two files with similar names loading, that then add the same tool twice.
                                    So simply look through the contents of Plugins.
                                    Find these two files and open/read them both with Notepad.exe
                                    The one called "extrudeEdgesByEdges.rb" is the one to keep - it's from the zipped set [it says 'Version 3.0' in its notes]
                                    The other one that's maybe 'older' and/or just has 'another similar name' needs removing.
                                    There are several files in Plugins with similar names but only two of the 11 [in your case 12!] are the ones you need to worry on...
                                    I can't do this for you - you must help yourself here - be resilient...
                                      Here's an update
                                      http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                      Two tools now have 'Quad Face' options to complement thomthom's new Quad-Tool
                                      ExtrudeEdgesByRails http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                                      ExtrudeEdgesByLoft http://forums.sketchucation.com/viewtopic.php?p=231016#p231016
                                      The lingvo files have also been updated to suit.
                                        Sweet! More quad tools! ๐Ÿ˜„
                                          Error on startup...
                                          Error Loading File extrudeEdgesByRails.rb
                                          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByRails.rb;163; syntax error, unexpected '='
                                            Error on startup...
                                            > C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByRails.rb;[b]163[/b]; syntax error, unexpected '='
                                            ๐Ÿ˜’ I somehow managed to duplicate a line below '=end' in the guidance notes as I saved the file...
                                            Here's the updated version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                            Sorry ๐Ÿ˜ณ ... but the 8 of you who downloaded it so far do need to do it again ๐Ÿ˜ฒ
                                            More haste, less speed... as the English proverb goes...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 31
                                            • 32
                                            • 12 / 32
