    [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
    118 Posts 53 Posters 150.1k Views 53 Watching
      dbalex
      No it still only works partially for me but I didn't try the new version, I will do it soon and reply here. We should wait for the next release when bezier.rb will not be needed anymore, maybe that will make it work for us..
      http://www.bocostudio.com
        macgile
        Hi dbalex 😄
        Currently I am looking for a way not to use Bezier curves.
        I test the natural cubic spline and B-spline.
        The cubic spline requires too much precision in their adjustment to smooth the path.
        The B-spline is my preference because it is more accurate than Beziers and less than the Cubic Spline.
        But the algorithm is very greedy for the moment.
        So maybe I'll use both.
        To correct the bug in edit mode:
        I used the old pick_point_to_move method of bezier.rb
        This method has been corrected in the new version (see http://forums.sketchucation.com/viewtopic.php?f=323&t=30973)
        Thank's TT and Fredo
        you can make the following changes
        in file camera_key_maker.rb:
        in
        def pick_point_to_move (x, y, view)
        change:
        if ph.pick_segment @points_eye
         path       = "eye"
         @selection = ph.pick_segment @points_eye
        elsif ph.pick_segment @points_target
         path       = "target"
         @selection = ph.pick_segment @points_target
        by :
        if ph.pick_segment(@points_eye, x, y)
        path = "eye"
        @selection = ph.pick_segment(@points_eye, x, y)
        elsif ph.pick_segment(@points_target, x, y)
        path = "target"
        @selection = ph.pick_segment(@points_target, x, y)
        Best Regard 😄
          dbalex
          perfect! it's fully working now! thanks for this incredible plugin macgile! finally some decent animation in sketchup!
          • I Offline
            isda
            macgile, i have edited the script as you suggested and it's working fine with me, too. thanks very much, i can now move the camera keys from all views now. I have another question... have you tried using this on a walkthrough? I seem to lose the camera angle even if I edit the camera path and the target to make sure that I see my models as I glide through them. the line between the key and the target does not seem to be what it is supposed to be when I hit up button..
            going around a single model is a breeze but zigzagging through different models is a different story.
            hope this script really develops into a plugin all of us cannot do without... keep it up, sir. thanks much!!!
              macgile
              hi isda 😄
              The final path of the eye and the target is smoothed by Bezier interpolation.
              you can see into view because they are drawn dashed.
              Consider the offset between keys and smoothed path to adjust the control keys.
              In the next version this offset will be smaller, and higher accuracy.
              I also added the ability to move around the target (the locked or not)
              or rotate the eye of the camera.
              This should facilitate the zigzagging between objects.
              Your suggestions are welcomed 😄
                driven
                this is basically working on the mac using ShiftQ, and mac arrow keycodes, the html needs some work as you need to right click after the dialog appears to load the page content, but then it works.
                is it possible to loop over an object, the camera rotates twice with this path [see pic]
                cheers
                can this be made to work?
                  macgile
                  cheers
                  [attachment=0:2glsdkjl]<!-- ia0 -->loopAnim.png<!-- ia0 -->[/attachment:2glsdkjl]
                  hi driven 😄
                  I don't understand what you want?
                  in the picture the camera rotates around object but look to outside!!!!
                    driven
                    hi macgile
                    sorry that path pic was me trying to edit out the camera rotate,
                    on this simple version the camera rotates on scene 4.
                    johnloop over cube
                    • I Offline
                      isda
                      Hi Macgile,
                      Can't wait to try the next version (I don't mean to pressure you by this.. haha (= ). God bless you in your pursuit to excellence.
                      The ability to rotate the eye of the camera is a great idea, as well.
                      I don't know if I am pushing the limit but I remember one 3D software where you can see the camera on the path and being able to see (from the top view) in what direction the cam is facing much like the AdvanceCameraTool... but anyways, as it is, I believe this plugin is great already.. kudos to you.
                        macgile
                        Hi Macgile,
                        hi isda
                        yes drarq already suggesting this improvement.
                        but it will be for a future release.
                        now I made ​​a version that works for everyone (PC and MAC OS)
                        I fix bugs and improve the design.
                        best regards
                          putnik
                          macgile, this is awesome! Thank you!
                          http://keshas.info
                            macgile
                            Thank's putnik 😄
                            best regard
                              macgile
                              @driven said:
                              hi macgile
                              john[attachment=0:1hzgzkb0]<!-- ia0 -->loop2.png<!-- ia0 -->[/attachment:1hzgzkb0]
                              hi driven 😄
                              Ok in the next release you can do it with rotate around camera target.
                              best regard
                                alphannurridho
                                @pixero said:
                                Just did a quick test and it's supersmooth.
                                Love it already.
                                please tell me how i can make video from sketchup with render image..
                                • E Offline
                                  Enzay
                                  Hey,
                                  I noticed you updated something for "large models". Mine might be excessively large but I'm trying to get a "flightpath" along a road and acrross a bridge. This looks like it would work great for that because it is able to set the camera point andthe point of focus. I however, found that starting the script made the model disappear. It seems to have zoomed way out and I can't zoom in to set the camera position. Wondering if this has to do with the model being so large. My road chainage is around 2.6km. I tried using flightpath.rb but it still has the lag between scenes with 0 scene delay so it's not doing me much good.
                                  Has anyone thought about making a script that places points or cameras (like advanced camera tools) and connects those points afterwards to make a smooth path? That would allow the user to set points without "being" the camera. Just some thoughts...
                                  Enzay.
                                    DesignChest
                                    Just tried to install your plug in but i'm getting the error box - no file to load. Any ideas?
                                    http://img823.imageshack.us/img823/2785/953499.png
                                      @designchest said:
                                      Just tried to install your plug in but I'm getting the error box - no file to load. Any ideas?
                                      Celina
                                      Please get a screen-capture of the error-message and post it that way we can then try to help solve the issue. I suspect from what you say here and other of your posts that you are not installing these plugins properly...
                                      Please reread the installation instructions that accompany almost all Plugins
                                      This thread covers many issues http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                                      Also as a MAC user please double check you are using the right Plugins folder and that any files that are supplied in a subfolder within a zip file are left inside an equivalent subfolder inside the Plugins folder - some poor [or badly optioned] unzip tools ignore the subfolders and don't extract properly. Also if you have inadvertently put any such files into Plugins that shouldn't be there please remove them before restarting Sketchup as these could we cause unexpected problems as all scripts directly within Plugins will auto-load...
                                        DesignChest
                                        Thanks Tig
                                        I knew it must be something i was not doing. Will follow your instructs and fingers crossed I'll be on my way. I have had a bit of headway with some of the installs now.
                                        Trying to get my animations up to scratch for a client whom I am hoping to design a great film set for. So used to hand drafting that the world of sketchup is just opening up to me, so bear with me - a little green still.
                                        • V Offline
                                          Viztecture
                                          Great plugin! Couple of questions tho,
                                          How do you control the speed of the animation after turning it into scenes. I say this because on the model I have, I get only one very slow speed regardless of how many transition frames I use, i have used numbers from 1 to 999 and I see no difference.
                                          Also does this actually work with Vray? If so does anyone know how?
                                          Cheers
                                          http://www.viztecture.mfbiz.com
                                          • V Offline
                                            Viztecture
                                            Ok I used scene transitions.rb and it works a treat now. New problem now lol. The animation is not smooth, im still getting jumps as the camera slows towards the next scene. Its fine on the preview however... any suggestions?
                                            • 3 / 6
