    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 790.8k Views 175 Watching
      Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      It has an additional tool ExtrudeEdgesByVectorToObject... see here for more details of the new tool... http://forums.sketchucation.com/viewtopic.php?p=331059#p331059
      • jeff hammondJ Offline
        oh nice! that's a great addition.
        [it also shows hints of a sweet trim tool plugin - sort of like solid booleans without the solids part.. in rhino, it works like: select cutting object(s) then pick the parts of the intersecting geometry you'd like to delete.. in eeVO, it automatically picks the side to delete on the opposite side of the cutting object of where the vector extrusion started.. in this hypothetical trim tool, you would be able to pick which side to delete... i dunno, just ideas in case you get bored one day πŸ˜„)
          prismcnd
          just wanted to say thank you for your amazing efforts.
          β€œWhatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
            costa
            you are really great!!! fantastic work, thank you
              Here's an updated set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
              A new tool ' ExtrudeEdgesByOffset' has been added.
              Its details are found here http://forums.sketchucation.com/viewtopic.php?p=331303#p331303
                d12dozr
                Wow, TIG, a tool a day? πŸ˜„ Thank you for these!
                http://goo.gl/f7ooYh
                  The 'Extrude Edges By Vector To Object' tool has been improved considerably:-
                  A new algorithm has been added for the intersecting with objects: now walls extend to soffits with additional apex vertices and so on so it extrudes fully to the faces/edges.
                  'Ghost' extrusions now show intersections as red dots.
                  The original selection is kept, unless the is group exploded.
                  Some ES lingvos updated by Defisto [thanks].
                    Here's another update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                    The 'Extrude Edges By Vector To Object' tool has additional traps added for rare glitches when a faced edge-selection was used.
                      Here's yet another update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                      The 'Extrude Edges By Vector To Object' tool has had a glitch fixed with 'undo' if you'd reversed faces etc...
                        The 'Extrude Edges By Vector To Object' tool has had glitches fixed with 'commit' and extruding faces inside groups to objects outside...
                        • W Offline
                          Wildchild
                          DUUUDE! Exactly what I was talking about!
                          Here's a few tests:
                          et1.jpget2.jpget3.jpget4.jpgThis last one took a little bit to work it out but then it did it just fine
                          I have a couple more tiny requests to ask, but now i don't have time! πŸ˜†
                          Eternity is very long, especially towards the end. Woody Allen
                          • U Offline
                            unclex
                            [Plugin] ExtrudeTools - Zipped Set 20110525 Installed
                            [Plugin] Shape Bender Beta v0.55 Can't work...
                            Need Help !!!
                            ThanX
                            • H Offline
                              hebeijianke
                              @tig said:
                              I translate All the plugins in ExtrudeTools into chinese
                              This is the translation file
                              chinesetranslation.zip
                                Need Help !!!
                                ThanX
                                I [and many others] have both toolsets installed without any interconnected problems πŸ˜•
                                Can you explain the nature of the problem a bit more ?
                                Are there any error messages [either at startup or when it's run with the Ruby Console open]? if so please post them here, or perhaps more logically in the ShapeBender thread, as that's the broken tool.
                                Nothing has changed between recent versions of the EEby... tools that I could think might affect ShapeBender in any way. that tool itself has been around for some time...
                                Please check you have progressbar.rb installed in the Plugins folder [available free from Smustard.com] - this is a frequent cause of tools failing that need it [it's not needed for any of the EEby... tools though!]
                                πŸ˜•
                                  I'll include them with the next update of the toolset.
                                  Meanwhile Chinese locale users can install them into the TIGtools folder and feedback...
                                    Jim
                                    Hi TIG,
                                    Shouldn't there be a Toolbar? I don't see it. I have all the EEb Tools in the Plugins menu, but no Extrusion* in Toolbars.
                                      There should be a file in ../Plugins/ #extrusionToolbar.rb makes the Toolbar/Sub-Menu.
                                      It starts with a '#' so it loads first - it then checks to see if any of the possible EEby...rb files exist and if so it adds the 'Extrusion Tools' toolbar referenced as ' $extrusionToolbar' and an 'Extrusion Tools' submenu referenced as ' $extrusionToolsSubmenu'. As each of the EEby...rb files loads it checks for these $ references and if they don't exist then there is no toolbar/button and the tool's menu item is added direct to Plugins-menu rather than into a subfolder...
                                      Your screen-shot suggests that #extrusionToolbar.rb is missing as there's no 'Extrusion Tools' submenu ??
                                      Note that the EEby... tools also 'require' deBabelizer.rb ?
                                        Jim
                                        Ah, I renamed it without the #. Guess I can't do that.
                                          NO! It needs to load before the other tools so they find the toolbar/submenu ready-made...
                                          The existence of the EEby...rb tools are checked by it 'by name' so renaming all of those would also stop the toolbar/submenu getting created...
                                          Its filename doesn't have to start with a #, it just needs to list somewhere before the other tools in alphanumeric order... I use a leading # on the name of for my tools if I want it to load early - like the '#HolePunchTool.rb', as I want its items high up on the context-menu listings...
                                          πŸ˜’
                                            Jim
                                            And I use C:\Plugins rather than the default so I can share plugins between versions. EEbX isn't portable in that way either.
                                            Thanks.
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 31 / 32
