    Looking to create a fairly simple plugin.
    4 Posts 4 Posters 203 Views 4 Watching
      DrDyna
      Hello!
      First post here. I've got a quick question. I've recently been dabbling with a little program called Hornresp for building and designing loudspeakers. This program is capable of outputting dimensions in txt/csv format.
      My question is, would it be terribly difficult (for me) to create a plugin for Sketchup that would read something that looks like this:
      Length (cm)	Area (sq cm)	Radius (cm)	Angle (deg)	Side Len (cm)	Height/2 (cm)	Top Len (cm)	Width/2 (cm)	Width Flare
      0.000000	620.000000	14.048207	-0.828064	0.000000	12.450000	0.000000	12.449799	Con
      0.500000	619.362115	14.040979	-0.828490	0.500042	12.443634	0.500041	12.443353	Con
      1.000000	618.724231	14.033746	-0.828917	1.000083	12.437262	1.000081	12.436906	Con
      1.500000	618.086346	14.026510	-0.829344	1.500125	12.430883	1.500122	12.430459	Con
      and translate it into a basic shape in Sketchup? I'm not opposed to learning enough of the plugin language to make it happen, I'd just like to make sure that I'm not embarking on an impossible task before I set out to do it.
      If it is possible, and someone could help me out with a very basic plugin example that grabs information out of a text or csv and draws objects with it, I'd love you forever!
        Seems Dynamic Components of the SU V8 can also make this sort of parametric construction.
        But I don't know if a dialog box of a Dynamic Component can read a list ?
        If Yes that is very more easy than ruby scripting in my point of view πŸ˜‰
        Wait answer of specialist of Dynamic Components πŸ˜„
        • sdmitchS Offline
          sdmitch
          DrDyna, This would be a relatively easy plugin to create. Something like this
          def getdata
          file_name = UI.openpanel "Open Data File", "c:", "*.dat";#get the file name
          inp = File.open(file_name);#open the file
          tmp = inp.readline;#read the header
          while !inp.eof
          tmp = inp.readline;#read a data record
          dat = tmp.split(" ")#split the record using the space character as the seperator
          #process dat array
          length = dat[0].to_f;
          area = dat[1].to_f;
          ;#etc.
          http://sdmitch.blogspot.com/
            There are several existing scripts that read in 'text files' and parse the 'fields/parts' line-by-line into an array of values [e.g. separated by space/tab/,/;/etc] to use in making geometry of some sort from these as x/y/z/material/layer/etc ...
            Find these and see how it's done... πŸ’­
