    Blending rounded corners of different radii
    7 Posts 4 Posters 1.3k Views 4 Watching
    • unigamiU
      unigami
      I'm making a box with rounded corners on the vertical edges using a 3" radius, but I want to put a rounded corner around the top surface at a 6" radius. When I try to do this using Fredo6's rounded corners tool, I get the result shown in the picture on the left. I'm trying to figure out how to fill the void shown in the picture on the right. I have a feeling that there is a simple solution but I'm stumped...can anyone help? Thanks!
      http://www.unigami.com/corner problem.png
      • Chris FullmerC
        What should it look like? Have you figured out a way to make that work manually?
        • unigamiU
          unigami
          Chris - I want the missing corner shown in the right hand picture to be filled with a surface that is blending between top surface and the sides. I haven't figured out a way to do it manually yet!
          • jeff hammondJ
            use curviloft by fredo
            (you may have to swap rails/profiles until you get the proper orientation)
            click pic -> bigger
            • unigamiU
              unigami
              THANKS! I figured out how to do it manually like this, but I would much rather use the plug-in! Many thanks Jeff!!!!
              http://www.unigami.com/corner problem solution.png
                • unigamiU
                  unigami
                  @tig said:
                  Or try my ExtrudeEdgesByRails tool...[attachment=0:3fyeuj77]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:3fyeuj77]
                  Thanks TIG!
