    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      Jim
      Did you install LibFredo6, as the instructions say? It's required to run most of Fredo's plugins.
        merlin7777777
        ah - no. can't see that info in the OP. can you direct me where to go for it?
          • gillesG Offline
            gilles
            I am trying to bend a profile with precision, let say a 4000mm radius bend at 90°.
            the only way I found to do this is to first calculate the length of the arc: PI2000, then use the bend tool and type 6283,20 (PI2000) and bend 90°.
            Could it be possible to just type the desired radius in VCB ?
              merlin7777777
              OK - added the fredo6, all works ok except still egtting this error on startup:
              Error Loading File bootstrap_FredoScale.rb
              (eval):1: uninitialized constant FredoScale::T6
              Maybe something to do with the double extraction I did?
                To be sure it isn't, why don't you remove anything to do with FredoScale and LibFredo and reinstall them so you know they are installed correctly.
                • fredo6F Offline
                  Do you use Plugin Organizer?
                  Another user had the same problem, which can be solved by setting Excluded Directories.
                  • dereiD Offline
                    derei
                    Hello, Can I use "Stretching with orientation of scaling box" with absolute value? It seems that it works only with scale ratio.
                    It would be nice to work like SketchUp native scale tool (where is you scale and input 500mm, it will scale the object to have 1000mm on the scaling axis. Or to scale the object adding a certain value more (example: +50mm).
                    Thanks.
                    DESIGNER AND ARTIST DEREI.UK
                    • fredo6F Offline
                      Thanks.
                      If you press TAB, you'll get a dialog box where you can enter absolute values.
                      Fields in the dialog box support formulas and units, so you can add " + 50mm" to the fields you wish.
                      • pbacotP Offline
                        I find while using box stretching that sometimes nested components move too far. They seem to move the same scale amount in relation to the component being scaled. So if you stretch a component by 8" nested components on the stretch side move 16". This does not always occur with nested components. I haven't figured out what the difference is. Is this how the tool should work? Peter
                        • fredo6F Offline
                          There may be some issues with nested components when small.
                          Do you have an example?
                          Fred
                          • pbacotP Offline
                            Fred,
                            Here's an example. When I went to make the example file, I copied the component and made it unique-for before and after.
                            Interestingly the doorknob in the original component moved as well--as if the move was made INSIDE the doorknob component itself. AND the doorknob was within a latch component--not all of which moved excessively.
                            I suppose the fix is to explode the components,if feasible?
                            Regards,
                            Peter
                            Example box stretching
                            • N Offline
                              narayan
                              Hi all!
                              It's my first post here; so pardon me if there are any unintentional lapses.
                              I am facing a small problem with the FredoScale's toolbar: The buttons require some buffer space on the right. So, if I fold the toolbar in two columns, the width of this toolbar does not match the other two-column toolbars (e.g. the SU's own "Large tool set").
                              Can this toolbar width be standardized?
                              Thanks in advance!
                                Hi Narayan,
                                Could you post a screenshot of it?
                                • N Offline
                                  narayan
                                  The screenshot is attached (this is link to my Dropbox account. Please let me know if there is a better way to share images. Thanks in advance!)
                                  http://db.tt/4oxATnt
                                  As the image shows, the FredoScale toolbar is wider than the other toolbars, such as "Drawing", "Construction", etc.
                                    blajnov
                                    @narayan said:
                                    Hi all!
                                    Thanks in advance!
                                    Probably it had in mind?
                                      Aha, yes, I can see. Those are the toolbar "inner" separators. Those can be removed I am sure (only not sure where in the script...)
                                        You can read/edit a .rb script with a plain-text editor [like Notepad[++].exe]... do NOT use a wordprocessor as that can add special characters that will break the script's functions!
                                        There is a file 'FredoScale_Box.rb' [inside the subfolder 'FREDOSCALE_Dir_21' - or a similar name depending on the current version!] - you should make a backup copy of it to use to revert to if you mess up!...
                                        In the file there are 4 lines that add 'separators' - using the code:-
                                        menu.add_separator
                                        • you can find these in lines 700, 705, 719 and 732.
                                          If you add a ' #' to the start of these lines it will disable them...
                                          Test how the tool works after making these adjustments, saving the file and restarting Sketchup... if it works 😄 ... but if it messes up simply remove a ' #'... OR revert to the original saved file... 🤓
                                        • fredo6F Offline
                                          Gaieus,
                                          You are right. There is the option in Default Parameters
                                          PS @TIG : All menus and toolbars are managed by LibFredo6. So it is not easy to tweak the code locally.
                                          • N Offline
                                            narayan
                                            Hi all,
                                            Thanks for the replies.
                                            I am using v3.7b (confirmed by using the Window>LibFredo6 settings...>About menu). Yet I do not see the Active options at statup section at all. It only has four sections: Plugin configuration, inference for lines, Check for update and Palette configuration. It does not have the two sections shown in Fredo6's screenshot.
                                            I tried to "Reset factory" button, but it did not change anything.
                                            There is another problem, which may be related: When I restart SletchUp, the FredoScale6 toolbar on its own folds into a 3-column toolbar, as shown here:
                                            http://db.tt/QXJ3PsH
                                            This does not happen always, but very often. I have to drag the toolbar in the "canvas" area, fold it into a two-column toolbar and place it back.
                                            %(#0040FF)[I am not sure whether this is a problem in FredoScale toolbar or a problem with SU8; because twice all the toolbars became flat horizontal bars, and escaped their positions, and lined up vertically (one below the other).
                                            While looking for solution, I read that SU has a bug which makes it forget the toolbar positions. While SU8 has improved, the problem is not resolved entirely.]
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 56
                                            • 57
                                            • 32 / 57
