    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 404.3k Views 172 Watching
      tomot
      @solo said:
      Oh yes,I agree the leaves need to be .png's with alpha channel, especially for render purposes, I'd like to have something similar to fur plugin that I can choose what to use as leaves if possible.
      Face me would be awesome.
      I don't know where all this **"png with alpha channel"**stuff is coming from, certainly one can do a precise cutout using PS and SU only, that's how I make the new Ivy leaves I posted in my rar file. Granted its a little more work. Also everyone in the photo-reproduction industry I know, is NOT a .png fan, and will always ask to convert to .jpg before printing.
      If you use my .jpg ivy files they will also load easily into the fur plugin.
      [my plugins](http://thingsvirtual.blogspot.ca/)
      tomot
      • soloS Offline
        Tomot, the reason I insist in .png is because for ivy you going to have a lot of geometry with the branches, now using your jpg cut out leaves will add 112 edges per leaf as opposed to 4. So imagine having 1000 leaves. I was more concerned with the huge geometry than the shadows in SU as I would be rendering anyway.
        • rodrigonotorR Offline
          rodrigonotor
          Good point Solo.
          Regards
          • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
            tomot
            fair comment! I very rarely use Vray rendered images for presentations, I'm more a fan of the Dennis presentation technique hence I want leaves without borders. I suppose that's the trade-off
            tomot
              rodrigonotor
              Sorry, you are rigth, I was thinking only in the render process. I'm also denni's tech fan.
              • Alan FraserA Offline
                Alan Fraser
                Is there a way to change the parameters of the number of segments in the stems? To be honest, I don't think it's necessary to be using hexagonal stems metres off the ground. You could probably start with a square cross section and quickly move to triangular(as in earlier releases) without any visible difference...especially as most stems will be hidden behind leaves.
                This plugin is looking really good. 👍
                3D Figures
                  justinplunkett
                  It looks like an awesome Plugin, unfortunately as previously mentioned it's not working on Mac Sketchup 8.
                  Hope you resolve it as it would be fantastic to use on an upcoming project.
                  Tx
                  Justin
                    driven
                    Tx
                    Justin
                    Hi Justin,
                    it does work on Mac with SU version 8, but I need to load it after startup from ruby console, or with as_pluginloader.rb.
                    to use with either method of loading, I would suggest the following-
                    go to LiveIvy.rb (in your plugins folder) >> right click and color it green >> drag it into LiveIvy Folder >> start SU >> open Ruby Console >> type load "LiveIvy/LiveIvy.rb" hit return >> draw or select a surface/shape/group... >> last item in plugins menu should be Ivy.
                    or use plugin loader to do the same, navigate to then select the green file... that's why I color it...
                    the standard image files can be improved by editing the .skp's in the folder, and I haven't got my head around all the settings yet.
                    but they do work.
                      rodrigonotor
                      Just a quicky test with others leafs
                      http://img215.imageshack.us/img215/3357/20052011070953pm.jpg
                      http://img803.imageshack.us/img803/6654/20052011075532pm.jpg
                        rodrigonotor
                        Here are a spanish translate from version 0.5.4. I'm going to translate version 0.6.x when is more stable.
                        LivIvy_0.5.4_ver_esp.rar
                          j40
                          Thanks for the great Plugin!
                          Top3D Studio
                            a4chitect
                            thanks for this magnificent plugin!!
                            • romboutR Offline
                              rombout
                              Hi all,
                              Is posted before that i could get either of the plugin and its revisions to work on a mac. So tonight itried on my (pc) laptop using su6 and su7. And... Some error as on the mac! Sorry cant type the complete code (commenting in my bb, sorry) its that error about birth_stem line 236 , something about 'birth' line 223 and so on. I tried all the tricks i saw here in this post. But i dont have su8 installed yet on my pc so i got one option left. Everything runs untill the shift+click... And that the error starts with TypeError: reference to deleted group .....
                              Hope some can resolve this one on both my machines. Ps on the mac i do have su6,7 and 8 running
                                Rombout
                                Are you sure you have installed all of the zipped files correctly ?
                                When you extract files for a zip you must keep them in their respective subfolders...
                                Usually there's only one or two .rb files that go directly into the Plugins folder... all other related files stay inside their subfolder [or even subfolders within that]
                                It you have inadvertently put some files into the Plugins folder that ought to be inside a subfolder, then they can auto-load and cause issues; so reinstall all of the tool's files as outlined above. Then recheck the Plugins folder and remove any files you find in it that should actually be in the subfolder[s]... Restart Sketchup and see if it works now... 🤓
                                • OxerO Offline
                                  Oxer
                                  Hi Rombout, I use mac too and for me only works the 0.6 version, the Keys on Mac:
                                  Cmd+Click : Make the ivy grow towards the mouse position.
                                  Alt+Click : Grow Ivy leafs.
                                  SHIFT+Click : Finish the Ivy.
                                  Key 'i' : Start over.
                                  The line 68 of Lively_tool.rb file is different for Pc and Mac.
                                  For Pc: if key == 73 #i
                                  For Mac: if key == 105 #i
                                  This is the version works for me on Mac
                                  Sketchup Ivy version works on Mac
                                  Say me if this version works for you or not.
                                  • romboutR Offline
                                    rombout
                                    Tx
                                    Justin
                                    Hi Justin,
                                    but they do work.
                                    still doesnt do any thing on the mac using this trick
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;284; warning; parenthesize argument(s) for future version
                                    true
                                    here the ruby output
                                      driven
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb:284: warning: parenthesize argument(s) for future version
                                      true
                                      It has worked, the TRUE means it works, the other bits just a warning about syntax...
                                      So, to prove it works,
                                      open SU >> open Components >> open Materials [select in Model view]>> open Ruby Console >> type load "LiveIvy/LiveIvy.rb"
                                      you should see the components appear and the materials as well.
                                      now draw a rectangle, then go to Plugins Menu and the LAST item should be SketchupIvy, click it and the WebDialog will appear.
                                      let me know if it all works, or how far you can get... if you get this far there's one other trick to make it better on mac.
                                      • romboutR Offline
                                        rombout
                                        jep oke, suddenly version 0.5.4. is working in SU7 mac?! in 8 i dont see what im doing and the shift+click only gives me a small part off a branch
                                        i will check the other download with the adjustment for the mac
                                        • romboutR Offline
                                          rombout
                                          here my test shot from thea?! no i need to go play with it! a lot i think?! 😄
                                          THink i need to modify those leaves, dont like that they are so flat
                                          • E Offline
                                            ergio3485
                                            yes. the same thing happens to me. i've done all you said but in the end it's always the same thing, there's only this pointer with a blue cirlce but when i left-click, shift-click, alt-click, etc... it doesnt' do anything.
                                            It seems to be a very useful plugin!!! if only i could use it 😞
                                            • 11
                                            • 12
                                            • 13
                                            • 36
                                            • 37
                                            • 11 / 37
