    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
    • Alan FraserA
      Alan Fraser
      All it needs now is a parameter to add bunches of grapes...and the designers of Greek tavernas will be very happy. šŸ˜„
      3D Figures
      • leedeeteeL
        leedeetee
        Any idea what I'm doing wrong?
        My ivy leafs appear with borders?
        (Thanks to Earthmover for answering previous question).
        • soloS
          What render engine?
          The answer is because they are jpg and have no alpha channel, they need to be .png or you need to have the alpha mask in the right slot.
          • leedeeteeL
            leedeetee
            Just playing with SU output at the moment, Solo.
              driven
              hi
              question for the experts?
              I'm going out to the garden to collect some english dog rose stem, leafs, buds and flowers to make up a set.
              what would be the best size, resolution, etc... to use with this. The originals seem huge to me, is that necessary?
              Obviously transparent background png's
              • FrederikF
                Frederik
                Looked so to me as well, nonetheless, you need to use png-files where the white parts are actually transparent as Solo already have pointed out...
                If you don't have one, you can play with this ivy leaf EarthMover posted earlier...
                Cheers
                Kim Frederik
                • leedeeteeL
                  leedeetee
                  Super, thanks, and thank-you Solo.
                  • PixeroP
                    Pixero
                    @driven said:
                    hi
                    That depends on how close the camera will be. A general rule is to use sizes such as 256x256 pixels, 512x512 etc. since they use the least amount of memory compared to it's size.
                    • T
                      tomot
                      @solo said:
                      Oh yes,I agree the leaves need to be .png's with alpha channel, especially for render purposes, I'd like to have something similar to fur plugin that I can choose what to use as leaves if possible.
                      Face me would be awesome.
                      I don't know where all this **"png with alpha channel"**stuff is coming from, certainly one can do a precise cutout using PS and SU only, that's how I make the new Ivy leaves I posted in my rar file. Granted its a little more work. Also everyone in the photo-reproduction industry I know, is NOT a .png fan, and will always ask to convert to .jpg before printing.
                      If you use my .jpg ivy files they will also load easily into the fur plugin.
                      my plugins
                      tomot
                      • soloS
                        Tomot, the reason I insist in .png is because for ivy you going to have a lot of geometry with the branches, now using your jpg cut out leaves will add 112 edges per leaf as opposed to 4. So imagine having 1000 leaves. I was more concerned with the huge geometry than the shadows in SU as I would be rendering anyway.
                        • rodrigonotorR
                          rodrigonotor
                          Good point Solo.
                          Regards
                          • Sketchando.net • www.arqcad.net •
                          • T
                            tomot
                            fair comment! I very rarely use Vray rendered images for presentations, I'm more a fan of the Dennis presentation technique hence I want leaves without borders. I suppose that's the trade-off
                            my plugins
                            tomot
                            • rodrigonotorR
                              rodrigonotor
                              Sorry, you are rigth, I was thinking only in the render process. I'm also denni's tech fan.
                              • Alan FraserA
                                Alan Fraser
                                Is there a way to change the parameters of the number of segments in the stems? To be honest, I don't think it's necessary to be using hexagonal stems metres off the ground. You could probably start with a square cross section and quickly move to triangular(as in earlier releases) without any visible difference...especially as most stems will be hidden behind leaves.
                                This plugin is looking really good. šŸ‘
                                3D Figures
                                  justinplunkett
                                  It looks like an awesome Plugin, unfortunately as previously mentioned it's not working on Mac Sketchup 8.
                                  Hope you resolve it as it would be fantastic to use on an upcoming project.
                                  Tx
                                  Justin
                                    driven
                                    Tx
                                    Justin
                                    Hi Justin,
                                    it does work on Mac with SU version 8, but I need to load it after startup from ruby console, or with as_pluginloader.rb.
                                    to use with either method of loading, I would suggest the following-
                                    go to LiveIvy.rb (in your plugins folder) >> right click and color it green >> drag it into LiveIvy Folder >> start SU >> open Ruby Console >> type load "LiveIvy/LiveIvy.rb" hit return >> draw or select a surface/shape/group... >> last item in plugins menu should be Ivy.
                                    or use plugin loader to do the same, navigate to then select the green file... that's why I color it...
                                    the standard image files can be improved by editing the .skp's in the folder, and I haven't got my head around all the settings yet.
                                    but they do work.
                                    • rodrigonotorR
                                      rodrigonotor
                                      Just a quicky test with others leafs
                                      http://img215.imageshack.us/img215/3357/20052011070953pm.jpg
                                      http://img803.imageshack.us/img803/6654/20052011075532pm.jpg
                                      • rodrigonotorR
                                        rodrigonotor
                                        Here are a spanish translate from version 0.5.4. I'm going to translate version 0.6.x when is more stable.
                                        LivIvy_0.5.4_ver_esp.rar
                                          j40
                                          Thanks for the great Plugin!
                                          Top3D Studio
                                            a4chitect
                                            thanks for this magnificent plugin!!
                                            With your input, this post could be even better šŸ’—
                                            • 11
                                            • 12
                                            • 13
                                            • 36
                                            • 37
                                            • 11 / 37
