    [Plugin] Show and Hide your toolbar
    29 Posts 16 Posters 35.3k Views 16 Watching
      My problem with this plugin is that it shows all the toolbars that I do not even use when I set it. There are a couple of plugins that I do not use regularly and only switch off when I need them. This plugin activates all inactive toolbars, too (on top of all I also use Jim's custom toolbar).
        gavvy
        I will upgade it .the pre version ,I had a txt to control which is not show ,and which will show .
        Next I will add the webDiaglo to control it โ˜€
          Please, don't get me wrong, the plugin seems to be very useful - and I am probably one of those few who keeps plugins under the hood and only activates toolbars when needed (I sometimes do not use a plugin for months but then a certain projects comes and I use it daily).
          Now if only we could save toolbar locations as well so they do not get cluttered all the time when activating / deactivating certain ones.
          ๐Ÿ˜’
            Jim
            There it is!
            UI.set_toolbar_visible("FullToolSet", true)
            • X Offline
              xrok1
              this plugin is awsome! has anyone figured how to get it to open only active plugs?
              begreat if you could have it only toggle the ones you want it to or only undocked bars as well. that way you could float the larger ones or the ones you don't use as often. ๐Ÿ˜„
              โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
              • N Offline
                nikus_knx
                How to hide Scene Tabs ? Any idea? UI.set_toolbar_visible("Scene Tab", false) doesn't work...
                  AFAIK the Scene Tabs can't be toggled through the API.
                  If you were on a PC you could assign a shortcut key to that View > Scene Tabs menu item and then call a WinScript command to mimic the key-stroke, but since it's a 'toggle', then knowing whether you will turn the Tabs on or off is problematical...
                  • N Offline
                    nikus_knx
                    I get it :
                    Sketchup.send_action 10534
                    Do it two times the first time (there 's a bug in Sketchup about the connected checkbox)
                    Enjoy
                      @nikus_knx said:
                      I get it :
                      Enjoy
                      However, that's PC only... ๐Ÿ˜•
                      Because it's a toggle there's no way of knowing it the tabs are on before running it, so if they are already off it'll switch them on ?
                        driven
                        on a Mac you can use an osascript call to do the same sort of thing,
                        along these lines, but you need to double check all the escapes
                        System "osascript -e 'tell application "System\ Events" -e click menu item "Scene\ Tabs" -e of menu 1 of menu bar item "View" -e of menu bar 1 of application process "SketchUp"e- "end tell"'"
                        PM me if you want a working version or have a play.
                        • biiidB Offline
                          biiid
                          The gadget very practical,I give it a try.
                          • bsintzelB Offline
                            bsintzel
                            I found the 'Show and Hide your toolbar' plugin to be quite useful when I want to 'snag' a full screen shot that includes a 'lot' of close-up detail -- but without the toolbars. ๐Ÿ‘
                            Before this plugin came along, I had to de-select toolbars one at a time to get the screenshot I needed ๐Ÿ‘Ž
                            It would be a shame if no-one updated this puppy so that it hides/shows 'only'
                            active toolbars. Like Gaieus, I discovered that the current version of this plugin turns on toolbars that I never loaded beforehand. ๐Ÿ˜ฒ
                            I've taken obfuscating to a whole new level!
                            • BoxB Offline
                              Fullscreen works with 2013
                              http://sketchucation.com/forums/viewtopic.php?p=382150#p382150
                              • bsintzelB Offline
                                bsintzel
                                Precisely what I need. Thanx Box
                                  TBA
                                  is there any chance to get this helpful tool working for SketchUp 2017 (mac os x)?
                                  Atm, itยดs not working.
                                  Best regards,
                                  Thomas
                                    Anton_S
                                    There is a better plugin, with a lot more features, such as switching SU fullscreen, called AMS Window Settings. But, unfortunately it's only for Windows.
                                      TBA
                                      Sorry for the delay.
                                      Yes the other plugin is for windows only ๐Ÿ˜ž
                                      Any chance that you compile your script for use in SU 2017/2018 ?
                                      Best regards,
                                      Thomas
                                        TerrorEcho
                                        @gaieus said:
                                        OK, I got it to work, thanks for the help.
                                        Same from me, also had this problem and managed to fix it using advices above.
                                        shake1S 1 Reply Last reply Reply Quote 0
                                        • shake1S Offline
                                          shake1 @TerrorEcho
                                          Many years have passed, and again there is no way to show\hide toolbar.
                                          FullScreen (AMS Window Settings) no longer supports this feature.
                                          Any suggestions?
