    [Plugin] Show and Hide your toolbar
    29 Posts 16 Posters 37.3k Views 16 Watching
      OK, I got it to work, thanks for the help.
        gavvy
        @charly2008 said:
        it works. Only one click at "Show and Hide toolbar". To reverse it click again "Show and Hide toolbar". The result looks like this! It would be nice if the tool would make sorting a little better. Is that possible in this script?
        I have found a way. When you first use "Show and Hide toolbar" sort the toolbars manually as desired. The next time you use it, all the toolbars are in this sort available again.
        But I've noticed when I undo "Show and Hide toolbar" my toolbars disappear in the top and upper bar. the have to be refurbished.
        Charly
        En....May be Jim will know how to get the position of the toolbars!
        In the Sketchep Api Webside,i can't find the toolbar's position method.
        But like the hotkey ,the position of toolbars are restored in the Registry of Windows.
        If you want to do this ,maybe you have to restart the sketchup .It's that the best way ? 😲
        By the way ,I have not touch the MAC system 😳 πŸ˜† .SO i don't know if it can run on mac or not.
          Jim
          You would need to use Win32API on Windows, and I don't know for the Mac.
            gavvy
            πŸ˜• OH YEAR ~.I remeber a plugin have the example to sort the toolbar in side .em but i don't remember the name of it . 😳
            Win32api is a good tool to do this ,but it always get wrong for the string 😠 Why?
              gavvy
              πŸ˜•
              here is my toolbars . πŸ˜›
              and the toolbar plugins (modify on Jim's Customtoolbar)
                My problem with this plugin is that it shows all the toolbars that I do not even use when I set it. There are a couple of plugins that I do not use regularly and only switch off when I need them. This plugin activates all inactive toolbars, too (on top of all I also use Jim's custom toolbar).
                  gavvy
                  I will upgade it .the pre version ,I had a txt to control which is not show ,and which will show .
                  Next I will add the webDiaglo to control it β˜€
                    Please, don't get me wrong, the plugin seems to be very useful - and I am probably one of those few who keeps plugins under the hood and only activates toolbars when needed (I sometimes do not use a plugin for months but then a certain projects comes and I use it daily).
                    Now if only we could save toolbar locations as well so they do not get cluttered all the time when activating / deactivating certain ones.
                    πŸ˜’
                      Jim
                      There it is!
                      UI.set_toolbar_visible("FullToolSet", true)
                      • X Offline
                        xrok1
                        this plugin is awsome! has anyone figured how to get it to open only active plugs?
                        begreat if you could have it only toggle the ones you want it to or only undocked bars as well. that way you could float the larger ones or the ones you don't use as often. πŸ˜„
                        • N Offline
                          nikus_knx
                          How to hide Scene Tabs ? Any idea? UI.set_toolbar_visible("Scene Tab", false) doesn't work...
                            AFAIK the Scene Tabs can't be toggled through the API.
                            If you were on a PC you could assign a shortcut key to that View > Scene Tabs menu item and then call a WinScript command to mimic the key-stroke, but since it's a 'toggle', then knowing whether you will turn the Tabs on or off is problematical...
                            • N Offline
                              nikus_knx
                              I get it :
                              Sketchup.send_action 10534
                              Do it two times the first time (there 's a bug in Sketchup about the connected checkbox)
                              Enjoy
                                @nikus_knx said:
                                I get it :
                                Enjoy
                                However, that's PC only... πŸ˜•
                                Because it's a toggle there's no way of knowing it the tabs are on before running it, so if they are already off it'll switch them on ?
                                  driven
                                  on a Mac you can use an osascript call to do the same sort of thing,
                                  along these lines, but you need to double check all the escapes
                                  System "osascript -e 'tell application "System\ Events" -e click menu item "Scene\ Tabs" -e of menu 1 of menu bar item "View" -e of menu bar 1 of application process "SketchUp"e- "end tell"'"
                                  PM me if you want a working version or have a play.
                                  • biiidB Offline
                                    biiid
                                    The gadget very practical,I give it a try.
                                    • bsintzelB Offline
                                      bsintzel
                                      I found the 'Show and Hide your toolbar' plugin to be quite useful when I want to 'snag' a full screen shot that includes a 'lot' of close-up detail -- but without the toolbars. πŸ‘
                                      Before this plugin came along, I had to de-select toolbars one at a time to get the screenshot I needed πŸ‘Ž
                                      It would be a shame if no-one updated this puppy so that it hides/shows 'only'
                                      active toolbars. Like Gaieus, I discovered that the current version of this plugin turns on toolbars that I never loaded beforehand. 😲
                                      I've taken obfuscating to a whole new level!
                                      • BoxB Offline
                                        Fullscreen works with 2013
                                        http://sketchucation.com/forums/viewtopic.php?p=382150#p382150
                                        • bsintzelB Offline
                                          bsintzel
                                          Precisely what I need. Thanx Box
                                            TBA
                                            is there any chance to get this helpful tool working for SketchUp 2017 (mac os x)?
                                            Atm, itΒ΄s not working.
                                            Best regards,
                                            Thomas
