    [Plugin] Pen Tool +
    126 Posts 40 Posters 119.2k Views 40 Watching
      Weld Draw is working fine for me. It all works fine except my second request. But, beggars can't be choosers so I'm not complaining.
        Version 1.2 (remove old before installing)
        thanks to TIG for tweaking again for squashing some bugs.
        See first post for latest.
          Now Weld Draw doesn't seem to draw welded edges.
          Soft Draw will convert unsoftened edges to softened but doesn't draw softened wedges from the start.
            It seems it's only welding when aligned to an axis? Can you confirm?
              No, it seems to toggling on/off....strange? TIG?
                It isn't even Friday the 13th.
                  Updated to v1.3
                  Note:
                  Weld Draw does not draw welded loops. It will also split if it intersects with any edge and get a little funky. It's primary function it to create a simple curve from drawn edges[lines]
                  • Chris FullmerC Offline
                    Cool Rich, great job on posting a plugin. I'll never ever use it as I'm sure I won't understand its accent, but should be lots of fun to install just to hear it mock me and my modeling habits all the time ๐Ÿคฃ
                      Make sure to use the Weld tool on your mouth. Before I write a Foot tool for your ass ๐Ÿ˜
                      • mitcorbM Offline
                        mitcorb
                        @Rich:
                        Did you live in the states for awhile?
                        • JClementsJ Offline
                          JClements
                          A visit is all it takes.
                            Comes of drinking American beer at high elevations for a week when you're not used to either. ๐Ÿ˜„
                              @mitcorb said:
                              @Rich:
                              Lived in Boston for a year about 15yrs ago. Was a painter/decorator/illegal alien!
                              But that's the only blot on an otherwise perfect record.
                              @Dave
                              I didn't even realise Boulder was high up? Too busy fixated on the dispensaries.
                              • mitcorbM Offline
                                mitcorb
                                @Rich:
                                'Twas the nuances of your snappy comeback that made me wonder ๐Ÿ’š
                                In your honor:
                                A fellow we know named O'Brien,
                                Sometimes can leave folks a-cryin'.
                                But sometimes his gaffin',
                                Will start you to laffin',
                                Even when sparks are a-flyin'.
                                oh, well.
                                  ๐Ÿ‘
                                  • boofredlayB Offline
                                    boofredlay
                                    Where does this plugin locate itself? I have it installed, the toolbar works fine but when I look in the plugins folder the PenTool+.rb or a folder holding the icons are nowhere to be found. I am confused (as usual).
                                      Look for a folder called 'rob_hsltool'
                                      The 'Draw' menu contains the modes of drawing also
                                        boofredlay
                                        Not there that I can see. Weird. Here is my plugins folder and a screen shot of the toolbar active.
                                          Any chance that's your SU7 Plugins directory?
                                            boofredlay
                                            Nope, I checked and the folder you see is here:
                                            C:\Program Files (x86)\Google\Google SketchUp 8\Plugins
                                            This is my SU7 Plugin folder.
                                            • 2 / 7
