    [Plugin] Pen Tool +
    126 Posts 40 Posters 100.5k Views 40 Watching
      Pen Tool +
      [highlight=#800000:1yrimny6]NOTE: If upgrading from 1.5 then please delete the Pen Tool+.rb file and rob_hsltool folder from your plugins folder.[/highlight:1yrimny6]
      Overview:
      To help when manually stitching softened meshes
      To quickly creates curves with lines
      To sketch guide lines, points
      To create lines with or without faces
      Description:
      Similar to native Line Tool in use but has 7 primary features :-
      [1] Soft Draw allows the sketching of softened/smoothened lines (Hidden Geometry On)
      [2] Hide Drawallows the sketching of hidden lines (Hidden Geometry On)
      [3] Guide Draw allows the sketching of guide lines
      [4] Weld Draw allows the sketching of curves
      [5] Edge Draw allows the sketching of edges [lines] without making faces
      [6] Line Draw allows the sketching of edges with faces
      [7] Point Draw allows the sketching of construction points
      Usage:
      Run via 'Draw' menu or via the 'Pen Tool +' toolbar
      [flash=600,450:1yrimny6]http://www.youtube.com/v/u6mdaWG3FAc[/flash:1yrimny6]
      Requirements:
      Tested on SU8+ only (PC)
      Installation:
      Please get the latest version from the SketchUcation PluginStore http://sketchucation.com/pluginstore?pln=Pen_Tools
      [highlight=#800000:1yrimny6]NOTE: If upgrading from 1.5 please delete the Pen Tool+.rb file and rob_hsltool folder from your plugins folder.[/highlight:1yrimny6]
      Version 1.1
      • VCB Fix
      • Edge Draw added
      Version 1.2
      • Group/Component bug fixed
      • Midpoint 'jumping' on intersection' fixed
      Version 1.3
      • Weld bug addressed (don't click too fast when using Weld Draw mode)
      Version 1.4
      • Line Draw and Point Draw added
      Version 1.5
      • Clash addressed
      Version 1.6.0
      • Added Extension compatibility and custom folder goodness
      Version 1.7.0
      • Fix glitch with 'langhandler' which meant that in newer SketchUp versions lines always started at the origin, and some tools failed completely. [TIG]
      Many thanks goes to TIG for helping me out with this tool.
      • boofredlayB Offline
        boofredlay
        Nice. I especially like the Weld Draw. πŸ‘
          It can be a bit funky but that's part of it's charm πŸ˜‰
            boofredlay
            Funky already πŸ˜„
            I am getting artifacts with the Weld Line. See image.
            Also when you close a loop with the weld line then push/pull the face the edges created by the operation are not all soften/smoothed.
            I am running a PC with Windows 7.
            Great start however.
            I will be out the rest of the day so I won't be able to respond for a while.
            I only drew 5 lines, not the short one connected by the longer one on the inside.
            I closed the loop and then push/pulled the shape up. 3 out of the 5 lines were smoothed.
              Well well well - Rich is becoming a scripting monkey. πŸ˜„
              I'll congratulate you by making a feature request: πŸ˜‰
              Tool that draws normal Edge.
              The difference from the native Edge Tool: Doesn't auto generate faces. It can be bloody annoying at time that SketchUp keeps trying to generate faces for each edge created.
                I wanna live the rock'n'roll life you enjoy
                • mitcorbM Offline
                  mitcorb
                  Congratulations, Rich.
                    SketchUpNoobie
                    Useful tool Rich. πŸ‘
                    SketchUpNoobie: the complete noob in all things SketchUp.
                      Good start Rich. You'll need to get some shades like ThomThom has. πŸ˜„
                      So now the requests begin. If you enter a length for the line in the VCB, the line is drawn but the tool continues from the start point rather than the end. Is it possible to fix that so it behaves like the native Line tool? And you only get one shot at entering the length of the line so if you change your mind or make an error when typing the length, you have to Undo and start over. Can that be fixed to operate like the native Line tool? Maybe both things go hand in hand?
                        what shades?
                        Yes, feel free to do so
                        Like peanuts and gum Dave
                          what shades?
                          Those things over his eyes. What are those things anyway?
                            Eyebrows?
                            There's a fix coming on the VCB issue and an extra Edge Draw mode that doesn't create faces
                            • jason_marantoJ Offline
                              jason_maranto
                              Very cool idea -- thank-you! β˜€
                              Best,
                              Jason.
                                Little update with Thom's and Dave's suggestions [not Eric's πŸ˜• ]
                                  Well, Rich, congrats, really. I remember when Remus also wrote a plugin - now "non-scripters" are slowly becoming a minority here... πŸ˜’
                                  I remember a wise man once answering this question:
                                  Do you build or have you built any SketchUp Ruby Scripts?
                                  like this...
                                  There are so many talented and generous ruby scripters out there that it would be a waste of resources to start playing with it and keep hindering them in their work with my basic questions...
                                  And sorry for not having been able to me of more help - I have just come back home.
                                  Nice icons, too!
                                  πŸ˜‰
                                    Thanks Csaba, there are still some little gremlins [not Mike] to iron out
                                      Thanks Rich.
                                      Out of curiosity, is this what I should see when I open the ZIP file?
                                        try again
                                          Cool! 😎
                                          • H Offline
                                            hebeijianke
                                            try again
                                            There something wrong
                                            • 1 / 7
