    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 651.5k Views 667 Watching
      bupaje
      Try downloading another zip
      Here is a 1 mb zip file on my site with 2 textures
      http://stormvisions.com//modules/download_gallery/dlc.php?file=36&id=1251519768
      see if you can extract the 2 image files. If not it may be that it is a file association issue - if you can take a screen shot of the page that results that might help as well.
      Burt
      Stormvisions
        merlin7777777
        ok - i clicked on the link and the open/save dialogue came up or textures082809.zip.
        I saved it to the plugins folder and during this process i could see all the files i've saved there.
        i went to this folder in explorer and i can't see these files.
        i used 7-zip and i could see your 'textures' folder and the wood and soil textures within it. however when i looked back in explorer the folder can't be seen (I did refresh).
        I tried moving one of the jpgs to the plugins folder thinking a jpg is bound to show up but this jpg doesn't show either in explorer in the plugins folder or even if i search on the filename for it.
        i'm mystified.
          merlin7777777
          in fact, no files show up in explorer in the plugins apart from the ones that originally installed with sketchup!
            bupaje
            Use these settings to temporarily show hidden files and folders (you'll want to change this setting back when you are done with this test).
            (www.bleepingcomputer.com)
            Then see if the files now show. If they do right click on them and select properties and see if the 'Hidden' check box is checked. If it is then either there is some weird Vista error (do you regularly apply updates?) or you may have a virus (do you have anitvirus/anti malware and practice safe computing?).
            If it is a Vista problem there are several good places to ask questions. The above referenced link is one and the Leoville forums another.
            http://towncommons.twit.tv/
            Burt
            Stormvisions
              A zip file is a file containing data that can be used to rebuild files and folders that have had their data compressed into this special format.
              When you open a zip file in your zip/unzip program it will display a window showing files and subfolders within it, BUT at that point it has NOT extracted these files - it's simply showing what's in it and what COULD be extracted.
              Most zip/unzip programs have obvious options to 'extract' their contents - perhaps by a button or file item on this window displaying the contents [you might have to select the contents displayed in the window first] - then usually you are then prompted for a destination for the extracted files/folders, which is usually a new folder named after the zip itself, located on your Desktop or some other location you have set in the program's preferences. Many programs allow you to select all of the zip-file's contents in this display-window and drag+drop them somewhere else - like Plugins... Many such programs also have a right-click context-menu to extract the contents of a selected zip-file. Once you have got all of the files/folders extracted relocate them into the Plugins folder in the Sketchup folder. Files that are loose in the original zip-file go directly into the Plugins folder, folders of files within the zip-file are put unchanged into the Plugins folder, as these files need to be inside their predefined subfolders for them to work... You do NOT put the zip file into Plugins and hope it magically fixes itself... please read the installation instructions provided with a downloaded tool AND the general post on manipulating zip-files... You seem to be making this more difficult that it is, or needs to be ๐Ÿ˜•
                rlcgrn
                Just saying "Hello" as a new "noobie". I'd really like to learn to use SketchUp at a reasonable proficiency and use some of the hacks I've come across to convert SketchUp drawings to .dxf format for use at my company. I'm running Sketchup 8 with WINE on Ubuntu and am not what you'd consider computer savvy, so it's been a huge learning curve all around. I'm currently working on a design for a tomahawk I plan to have produced as an initial entrepreneurial endeavor; I also have some initial designs for some other products, but I find getting the results I want are cumbersome with my limited knowledge so far of SketchUp, so it's all about finding tutorials for me to learn from.
                Thanks in advance for all the resources here!
                  PauloFlatland
                  Hi Everyone..
                  Im Paulo Gepulango from philippines.. a new member of this forum.. just want to ask if how can i render my drawing with thick shadow? or and what is your advice on this drawing? heres my previous render.. thank everyone..
                  http://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc6/223253_211164022237986_100000331691882_685659_4935509_n.jpg
                  cheers!!!!
                    Hi Galt and Paulo and welcome!
                    Galt; whenever you have any particular question, do not hesitate to ask. There are some folks with quite some experience with Linux here (not myself though...)
                    Paulo; and what are you using for rendering?
                    • mitcorbM Offline
                      mitcorb
                      @Galt:
                      Welcome. There are tutorials available here in this Forum. You may also find the series of tutorials by Aidan Chopra helpful. They are posted on YouTube. Google has a series of tutorials, too. Enjoy your journey.
                        PauloFlatland
                        Thank you sir.. i am using sketch-up pro 8 and vray 6 for rendering.. i know that i am amature to this any tips sir? ๐Ÿ˜„
                          @pauloflatland said:
                          ...any tips sir? ๐Ÿ˜„
                          Well, since I do not use V-ray myself, my "best" tip is to scroll down on the main forum index and post your V-ray problem in our special V-ray subforum under the Extensions... main forum:
                          http://forums.sketchucation.com/viewforum.php?f=322
                          ๐Ÿ˜‰
                            PauloFlatland
                            ๐Ÿ˜‰
                            oh ok sir.. thank you so much.. ill go tour around this site for any help tips.. ๐Ÿ˜„
                            cheers!!!!!
                              @greenbelt said:
                              Hope this helps other Newbies like me. Could a forum member (me?) edit someone else's post to add the updated link? Is that allowed?
                              No way. Imagine hat would happen if members started to edit each other's posts!
                              ๐Ÿ˜ฎ
                                greenbelt
                                Hi. Decided to spend this morning re-reading some forums and tutorials. I was having trouble with finding Materials/Textures and am still learning. Found an old link in this post %(#0000FF)[**
                                **.] - here is the new link.
                                http://sketchup.google.com/support/bin/answer.py?answer=94956
                                Sketchup User's Guide - Paint Bucket Tool
                                Hope this helps other Newbies like me. Could a forum member (me?) edit someone else's post to add the updated link? Is that allowed? Or is this way better?
                                P.S. Answered my own question. Cannot edit other posts. Here is a link to a list of textures elsewhere on the forums.
                                http://forums.sketchucation.com/viewtopic.php?f=40&t=486
                                I am still a little confused about adding my own textures.
                                1. One way is to go on-line and copy images from the web (mindful of copyrights, etc.). I use IrfanView. I save these jpgs in an organized set of folders with my other Sketchup Stuff. Then using File -> Import dialogue window, I browse over to my previously saved jpg file and open it. In Sketchup, my curser becomes a paintbucket and I'd better have a face ready to paint or I have to do it again. (annoying)
                                2. Second way that sometimes works is to use the Window -> Materials dialogue -> Open or Create Collection. Again I browse to where I keep my collection of textures. But this time I can only open a folder/directory containing .skp files. I cannot go to one specific jpg file nor can I successfully open a folder containing jpg files.
                                So more experienced users out there... am I doing this correctly. Is there a better way?
                                FYI: Learned something new at one of the about listed sites for textures. Creating textures to be used on models is an art in itself. hoo neeoow (who knew?) (my old Wisconsin accent) ๐Ÿคฃ There are issues regarding tiling etc. Amazing!
                                Thanks for reading and answering my doubts.
                                Newbie. Planning my dream retirement home!!
                                  justinplunkett
                                  Hi everyone.
                                  I'm an illustrator and often use SU for my work, love it. I also use SU-podium for my rendering. Thanks for the plug-ins - have tried out a couple and will try out some more.
                                  Cheers
                                  Justin
                                  http://www.justinplunkett.com
                                    Avi Sacks
                                    I would like to know how to superimpose more than one building onto a photograph using photomatch (each building is not parallel to the next building - i.e. each one is set at a different radius). Thank you very much for your help.
                                    All the best,
                                    Avi Sacks
                                      CHEVOTA
                                      Hello,
                                      I was introduced to sketchup through the company I work for. We are a startup company and we have had to learn things as we go and keep cost's down. Sketchup is great for that. We have begun to do our own shop and architectural drawings and I found this forum looking for line weight help. However the rendering that I have been seeing here is really good stuff! I sure I will find more information here than I can handle.
                                      Cheers,
                                        Welcome Chevota and enjoy your time here!
                                          Giganaut
                                          Hi. everybody! Greetings from Brunei Darussalam. you can call me Giggs for short
                                          i may be new to this place but im very fimiliar to Sketchup X3
                                          got hooked p to this program a year before and i used this program to model my work ever since.
                                          if you want to see my recent works. you can go to deviant art to see hehehe.
                                          here are one of my recent stuff i made:
                                          http://giganaut.deviantart.com/art/Tiger-IV-A-B-211236738
                                          since i stumbled upon this site last week. it opened me to new ways too model and develop designs.
                                          • Rich O BrienR Online
                                            Great to have you here ๐Ÿ‘
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 72
                                            • 73
                                            • 45 / 73
