    1.5k Posts 476 Posters 4.0m Views 476 Watching
      Tamp
      thanks a lot, it's really be usefull. πŸ˜„
      • N Offline
        Neocene
        Hi there. I've had no problem installing you other great plugins. However I can't get the round corners to work. The icon shows up in the menus but when I try to click on a surface, nothing happens. I've followed your instructions in installing but I can't figure out what I'm doing wrong.
          You have the current LibFredo installed?
          You unzipped the correct files/folders into the plugins directory?
          • N Offline
            Neocene
            yes I have. All the other plug ins work fine with no problems.
            Here are the errors that are showing up in the ruby script
            Error; #<Errno;;EACCES; Permission denied - E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/FredoTraceRoundCorner.txt>
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `initialize'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `open'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `create_file'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2210;in `trace'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;58;in `initialize'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;42;in `new'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;42;in `launch'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;33;in `action__mapping'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;118;in `call'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;118;in `launch_action'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb;143;in `launch_action'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb;159;in `startup'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;679;in `call'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;679;in `command_invoke'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;661;in `build_config_commands'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `call'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `add_command'
            E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `call'
            • fredo6F Offline
              Neocene,
              Could you install the version 2.2c.
              Normally it does not log traces to file.
              Apparently, you have some access restriction for creating files by program in your Program directory.
              • N Offline
                Neocene
                I have downloaded that version before and get the same problem. How can I change the access for the program?
                • fredo6F Offline
                  In file RoundCorner_Algo.rb, can you check that on line 2190, you have
                  @@mode_on = false
                    chronikle
                    Please explain to me why did I just waste 2minutes registering just to find out that I don't have the necessary permissions to download even as a registered user.
                      You should be able to download it with no issues. Please, make sure you have cookies properly enabled and if you are using an url like http://www.sketchucation.com/forums/scf, please, change to http://forums.sketchucation.com
                      When we are at it; are you sure you have SketchUp version 1? As such, you could not use plugins anyway (they were introduced at version 4). If you have anything later, please, correct your profile here.
                        chronikle
                        I am using version 8, I was in a hurry to get the plugin since I was on a deadline and needed a quick way to achieve rounded corners. In regards to the cookies and url, those are not the cause of my problem both are enabled and displaying normally. Any other ideas, can a moderator please pm me the link, I'd still like to use the plugin for future projects.
                          @chronikle said:
                          ...I was on a deadline and needed a quick way to achieve rounded corners. ...can a moderator please pm me the link, I'd still like to use the plugin for future projects.
                          See your email. But then come back and let's fix this issue as it should be working fine.
                            Sorry, LibFredo contains an exe file and the email is not sent. See your PM then.
                              cfarrell10
                              Hi Fredo,
                              I'm also having trouble with the round corner tool making the program run really slow. Seems to be related to the palette...once this is minimized it works fine, but its is such a pain trying to enter dimensions when the program becomes so clunky with the palette open.
                              Any help would be greatly appreciated, can't do without this tool.
                              πŸ‘
                              Cf
                              • fredo6F Offline
                                @cfarrell10 said:
                                Hi Fredo,
                                πŸ‘
                                Cf
                                Can you confirm your run SU on Windows? (i.e. not on Mac)
                                Also, when you shrink the palette, do you have fluid performance, or just an improvement?
                                PS: when the palette is shrinked, you access the parameter settings by typing TAB
                                  cfarrell10
                                  1. I'm running SU on Mac, OS X version 10.6.7 (I have windows at work, works fine on that. I thought this issue was related only to mac, apologies for not mentioning in previous post)
                                  2. Once I shrink the palette it runs smooth enough, tho often I have to clean up edges after the tool has completed the round.
                                  i'm running on an imac intel i5 dual core with 8gb of ram.
                                  cheers
                                  cf
                                  πŸ‘
                                    pablosyk14
                                    Awesome tool fredo. Thank you!
                                      cfarrell10
                                      @cfarrell10 said:
                                      cheers
                                      cf
                                      πŸ‘
                                      Hi Fredo
                                      Any ideas why tool doesn't work so well on my Mac????
                                      cheers
                                      cf
                                      • fredo6F Offline
                                        I am still scratching my head where it can come from, why it is only on Mac and why only for Roundcorner (the palette package is the same for other plugins like Curviloft and TOS).
                                        Several Mac users have reported the problem, so there must be a rational explanation.
                                        Still investigating
                                        • fredo6F Offline
                                          By the way, can you confirm the follwoing point:
                                          When you start Roundcorner on an empty selection
                                          1. Do you have to wait to see the button palette appear for the first time ?
                                          2. or slow behavior is only when you move the mouse(which refreshes the palette) without clicking ?
                                          3. Or is it only when you select edges that you have the slow behavior?
                                          Also, can you open the Ruby console when you run RoundCorner, in case there are messages displayed.
                                          • jeff hammondJ Offline
                                            fwiw, here's roundcorner on my laptop (15" i7) but it works the same on my desktop (2.66quad macpro)..
                                            [flash=853,510:3hfz6m0m]http://www.youtube.com/v/CFV33Eu8Y6I?fs=1&amp;hl=en_US&amp;rel=0[/flash:3hfz6m0m]
                                            as you can see, everything works fine.. i used this example because it had so many edges to round but even then, it only took 6 seconds.. a simple box is basically instantaneous..
                                            also, orbiting etc. works fine as well when the palette is up..
                                            i wish i could make roundcorner work not so well in order to help find a solution but i've tried literally 100 different things to mess it up and i can't do it..
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 74
                                            • 75
                                            • 20 / 75
