    [Plugin] Facewarp
    6 Posts 4 Posters 10.8k Views 4 Watching
      Builder Boy
      My original post was here. I still got tired of dividing edges(by the way, does anyone know how to do this with ruby?), then welding them back together, then filling out a lot of dialog boxes. So, I made my own plugin to do this. I give you:
      Facewarp.rb
      All my plugins
        Lots of vanishing lines when drawing? And not all faces created?
          http://code.google.com/apis/sketchup/docs/ourdoc/edge.html#split ???
            Builder Boy
            This plugin does not always work when 2 points have the same location. Also, may give unexpected results when 3 points are collinear.
            This will only split a line into 2 segments with controllable proportions, I am looking for something more like this:
            edge.divide(5) # for 5 equal-length segments
            All my plugins
            • Didier BurD Offline
              Didier Bur
              You can do that with edge.split, just create a loop 0.upto(4) for instance to divide in 5 segments...
              DB
                It'd be easily enough to make a custom 'divide' method that works as you want - you know the edge's starting length and therefore the length of one divided part. So simply iterate through the edge the number of divisions-1 nibbling off the appropriate proportion as another edge until you are done. I don't recommend extending the Edge class but more like this...
                self.divide(edge,5)
                calling this
                def divide(edge=nil, num=nil)
                  return nil if not edge or edge.class!=Sketchup;;Edge
                  return nil if not num or not num.class==Fixnum or num<=1
                  len=edge.length
                  bit=len/num.to_f
                  num.times{
                    begin
                      nedge=edge.split(bit/len)
                      if nedge
                        edge=nedge
                        len=edge.length
                      end#if
                    rescue
                      puts 'Divide Error'
                Which splits the specified edge into the specified parts...
