    Does layout not support hidden lines?
    layout
    25 Posts 10 Posters 11.1k Views 10 Watching
      bjanzen
      So if your style has back edges turned on in SketchUp, you should see those in LayOut. Is that not working for you? If you don't have LO3, does changing face style to X-ray work for you in 2.1? It does for me.
      b
      • W Offline
        walzo
        I'm guessing the issue here is that Layout doesn't display hidden lines in vector mode (I wish it did!). Correct Gaieus? Ideally one wouldn't have to explode a model, thereby losing the capacity to remodel it in Sketchup.
          Not in vector mode but in hybrid mode it does (where your edges are vectors but your textures are raster). Probably the most resource hungry mode however.
          • bmikeB Offline
            bmike
            Not seeing this in hybrid, was really hoping for it on a complex project...
            Will have to settle for vector, I guess.
              Looks like Back Edges will only display in Raster mode.
                Above, my rendering was in hybrid. Note that back edges is a face style actually so you cannot expect it to work in vector mode but in hybrid mode they should appear (however not as vector edges but as a raster effect on the face itself as far as I can tell or at least imagine).
                  I don't see back edges in Hybrid. Here's what I get.
                  Original SU image with style updated:
                  http://farm3.static.flickr.com/2375/5709861352_611f5b9c6b.jpg
                  LO Raster render:
                  http://farm4.static.flickr.com/3128/5709297161_9994d5eba2_z.jpg
                  LO Hybrid render:
                  http://farm3.static.flickr.com/2061/5709297299_4b978f7b43_z.jpg
                  • bmikeB Offline
                    bmike
                    LO Raster render:
                    LO Hybrid render:
                    Same here. I even exported to PDF, to make sure I wasn't missing something.
                    And set display of models to 'high'. No dice.
                      jhauswirth
                      LO doesn't support the new hiddenline drawing in hybrid or vector.
                      It will only show them in raster. In hybrid mode it first renders
                      everything except edges (it turns off ALL edges) and then it
                      draws all visible edges as vector on top of the raster image.
                      • bmikeB Offline
                        bmike
                        Would be great to have it available in hybrid... but in my limited testing it would need some finesse on the software side.
                        I thought it might work to do 2 viewports, one in raster, another on top in vector, but I can't seem to get that to work - although I did think it possible to have 2 or more windows stacked atop one another with transparent backgrounds...
                          Well, you could do it with overlapping scenes. See the attached PDF. I made two scenes, one in simple Hidden Line style and the other with Back Edges turned on. I overlapped the two scenes in LO with them on separate layers. The Hidden Line view is rendered as Vector and the Back Edges scene in Raster.
                          To be honest, though. I don't see much point in doing this. The quality of the result isn't very good.
                          back edges test.pdf
                          • bmikeB Offline
                            bmike
                            Just figured that out by doing a similar test with something I'm working on. Only time it would make sense for me would be for complex joinery / shop drawings...
                              Out of curiosity, wouldn't just the Raster-rendered image work for that? Or, you could make a high res image export from SU and insert the image into LO. Of course you'd lose the automatic update if you edit the model but for a few images it might not be so bad.
                              • bmikeB Offline
                                bmike
                                I guess the raster would be fine. But I have no idea in actual practice. I've only used vector for line heavy work, and hybrid for anything with color and shadows...
                                I've sent a few pages off to plot with the overlay and with just the raster. We'll see how they plot out.
                                  I may have remembered my (old) post above wrong then, sorry.
                                  • bmikeB Offline
                                    bmike
                                    Nice thing about backedges, even if they don't render in hybrid or vector - is that they do allow you to snap when section cutting through a model...
                                      bertsminky
                                      I did the two SU Scenes onto two LO layers and at first it showed perfectly well then after going back to it one of the scenes had become a solid form - ie you couldnt see through it to the other scene/layer behind ?
                                      Any idea on why this would happen cos it had me scratching my head for a while - in the end i drew a clipping mask but for the backedges example above this wouldnt be suitable.
                                        Bert, could you post the LO file so we can see? It could be something fairly straightforward.
                                        • AnssiA Offline
                                          Anssi
                                          Dave's method could perhaps be refined:
                                          • create two identical scenes in SketchUp, one in a style you want, the other in Wireframe, with a white background.
                                          • In LayOut, overlay the wireframe view on the standard view, and set it to use a Hidden linetype (I don't know if it is necessary to explode it first - my old laptop is too slow to run LayOut well)
                                          Anssi
                                          • Y Offline
                                            Yousefk88
                                            For me i'm turning off edges in sketchup but they are showing again in layout, and couldnt find a style with there's no edges (out lines)...what to do?
