    1.5k Posts 471 Posters 3.4m Views 470 Watching
      Tikva2
      ok,I understand))
      thank you very much for this plugin)))
        shredder7753
        how can i download? it says i dont have the permissions?
        • I Offline
          inna.newyork
          i downloaded all per instruction,restarted computer, but my sketchup( pro6) says can't find those two plugins! what's wrong????
          • fredo6F Offline
            Did you download LibFredo6 and follow the instructions which are in the main post (in particular about the unzip operation)?
              Tamp
              thanks a lot, it's really be usefull. πŸ˜„
              • N Offline
                Neocene
                Hi there. I've had no problem installing you other great plugins. However I can't get the round corners to work. The icon shows up in the menus but when I try to click on a surface, nothing happens. I've followed your instructions in installing but I can't figure out what I'm doing wrong.
                  You have the current LibFredo installed?
                  You unzipped the correct files/folders into the plugins directory?
                  • N Offline
                    Neocene
                    yes I have. All the other plug ins work fine with no problems.
                    Here are the errors that are showing up in the ruby script
                    Error; #<Errno;;EACCES; Permission denied - E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/FredoTraceRoundCorner.txt>
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `initialize'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `open'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `create_file'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2210;in `trace'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;58;in `initialize'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;42;in `new'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;42;in `launch'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Tool.rb;33;in `action__mapping'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;118;in `call'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;118;in `launch_action'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb;143;in `launch_action'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb;159;in `startup'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;679;in `call'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;679;in `command_invoke'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Plugin.rb;661;in `build_config_commands'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `call'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/LIBFREDO6_Dir_37/Lib6Traductor.rb;908;in `add_command'
                    E;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/RoundCorner_Algo.rb;2197;in `call'
                    • fredo6F Offline
                      Neocene,
                      Could you install the version 2.2c.
                      Normally it does not log traces to file.
                      Apparently, you have some access restriction for creating files by program in your Program directory.
                      • N Offline
                        Neocene
                        I have downloaded that version before and get the same problem. How can I change the access for the program?
                        • fredo6F Offline
                          In file RoundCorner_Algo.rb, can you check that on line 2190, you have
                          @@mode_on = false
                            chronikle
                            Please explain to me why did I just waste 2minutes registering just to find out that I don't have the necessary permissions to download even as a registered user.
                              You should be able to download it with no issues. Please, make sure you have cookies properly enabled and if you are using an url like http://www.sketchucation.com/forums/scf, please, change to http://forums.sketchucation.com
                              When we are at it; are you sure you have SketchUp version 1? As such, you could not use plugins anyway (they were introduced at version 4). If you have anything later, please, correct your profile here.
                                chronikle
                                I am using version 8, I was in a hurry to get the plugin since I was on a deadline and needed a quick way to achieve rounded corners. In regards to the cookies and url, those are not the cause of my problem both are enabled and displaying normally. Any other ideas, can a moderator please pm me the link, I'd still like to use the plugin for future projects.
                                  @chronikle said:
                                  ...I was on a deadline and needed a quick way to achieve rounded corners. ...can a moderator please pm me the link, I'd still like to use the plugin for future projects.
                                  See your email. But then come back and let's fix this issue as it should be working fine.
                                    Sorry, LibFredo contains an exe file and the email is not sent. See your PM then.
                                      cfarrell10
                                      Hi Fredo,
                                      I'm also having trouble with the round corner tool making the program run really slow. Seems to be related to the palette...once this is minimized it works fine, but its is such a pain trying to enter dimensions when the program becomes so clunky with the palette open.
                                      Any help would be greatly appreciated, can't do without this tool.
                                      πŸ‘
                                      Cf
                                      • fredo6F Offline
                                        @cfarrell10 said:
                                        Hi Fredo,
                                        πŸ‘
                                        Cf
                                        Can you confirm your run SU on Windows? (i.e. not on Mac)
                                        Also, when you shrink the palette, do you have fluid performance, or just an improvement?
                                        PS: when the palette is shrinked, you access the parameter settings by typing TAB
                                          cfarrell10
                                          1. I'm running SU on Mac, OS X version 10.6.7 (I have windows at work, works fine on that. I thought this issue was related only to mac, apologies for not mentioning in previous post)
                                          2. Once I shrink the palette it runs smooth enough, tho often I have to clean up edges after the tool has completed the round.
                                          i'm running on an imac intel i5 dual core with 8gb of ram.
                                          cheers
                                          cf
                                          πŸ‘
                                            pablosyk14
                                            Awesome tool fredo. Thank you!
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 73
                                            • 74
                                            • 22 / 74
