    [Info] Allowable Classes for "set_attribute"
    57 Posts 12 Posters 7.9k Views 12 Watching
    • Z Offline
      zitoun
      VERY useful thread, thanks !
      Please make it kind of sticky: I've been chasing an uncatchable bug for hours, ignoring this information... Others might like to know this in the future!
      The light at the end of the tunnel is a train.
      • Dan RathbunD Offline
        Dan Rathbun
        To recover a hash-string from an attribute, you eval() it into a reference.
        hashStr = some_entity.get_attribute( "dict_name", "hash_att" )
        my_hash = eval(hashStr)
        I'm not here much anymore.
          Length classes also seem to be stored and recovered properly. I'd thought that maybe it got read back as Float, but in my tests I seem to get Length - anyone confirm?
            @kwalkerman said:
            Array -- good to store by doing "array.inspect" first, see Dan's comments below
            Only if the array contains hashes. If the array only use the other allowable types there is no need. Might be less overhead since it's not parsing between strings.
              Geom::Point3d also seems to be possible to store:
              ` pt1=Geom::Point3d.new(1,2,3)
              Point3d(1, 2, 3)
              pt2=Geom::Point3d.new(4,5,6)
              Point3d(4, 5, 6)
              pt3=Geom::Point3d.new(7,8,9)
              Point3d(7, 8, 9)
              pt_array = [ pt1, pt2, pt3 ]
              [Point3d(1, 2, 3), Point3d(4, 5, 6), Point3d(7, 8, 9)]
              model.set_attribute('test', 'bar', pt_array )
              model.get_attribute('test', 'bar' )
              [Point3d(1, 2, 3), Point3d(4, 5, 6), Point3d(7, 8, 9)]`
              I even saved the model and reopened it just to make sure it worked across sessions.
                Although storing/reading-back a 'point3d' or a 'vector3d' as an array [.to_a] would be 'safer' ?
                Presumably a 'transformation' is not storeable unless it's first made into an array ?
                  I was storing points as arrays - because I just assumed point3d's would not work. But they appear to do so. In which case I'd prefer to do so unless there is any known issues.
                    kwalkerman
                    Nice. I just tested it as well. I'll add it to the list.
                    It also seems to work as an attribute dictionary key:
                    p1 = Geom::Point3d.new(1,2,3)
                    p2 = Geom::Point3d.new(4,5,6)
                    entity.set_attribute "k", p1, p2
                    Karen
                      hmm... interesting.
                      I a haven't tried, but I'd think that Vector3d should work as well. (Though one can never be sure until it's tested...)
                        kwalkerman
                        yep, vectors work too. I wonder about the other Geom classes (although transformation doesn't work, I just tried it).
                        Karen
                          Dan Rathbun
                          reminder.. that keys should be unique, in the same way that hash keys need to be unique.
                          If you have two Point3d objects that are eql? (in the Ruby sense,) ie, the 3 elements, x, y, z have the same values, (but differing object_id,) can they be used as separate keys for 2 separate values ?
                          .. or will one overwrite the other's value in the dictionary ?
                            kwalkerman
                            Dan,
                            Good point. A quick check indicates that any point with the same x,y, and z values can access the attribute.
                            Karen
                              Dan Rathbun
                              Karen
                              .. thot so.
                              This could be bad,.. or good, depending on what your doing. If you wanted to store some explanitory text for ANY point with certain x,y,z co-ordinates like "at the hinge point" then this feature might work ok. (Of course, nil will be returned if no such "point-key" exists in the dictionary.)
                                kwalkerman
                                Dan,
                                For applications I can think of, this is actually an advantage, especially if you are using attributes between sessions, as the 'entity' attached to your particular point3d would be lost. AND, it works just like any other key for attributes.
                                string1 = "My Attribute"
                                string2 = "My Attribute"
                                entity.set_attribute "a", string1, "q"
                                entity.get_attribute "a", string2 ==> "q"
                                string1 and string2 are different objects, but both can reference the same attribute dictionary.
                                Karen
                                • jiminy-billy-bobJ Offline
                                  jiminy-billy-bob
                                  Shameless bump, it would be great to add this to the online docs. (TT, if you read this...)
                                  • eneroth3E Offline
                                    eneroth3
                                    Perhaps it's worth mentioning that Point3ds and vector3ds are transformed along with the geometry they belong to when using move tool or rotate tool on it.
                                    My website: http://julia-christina-eneroth.se/
                                      Dan Rathbun
                                      Geom::Point3d and Geom::Vector3d are virtual classes. Instances of them do not actually exist in any entities collection. Sketchup::Vertex however, does have instances "in the model."
                                      Can you be more specific? (Your statement seems vague.)
                                      • tt_suT Offline
                                        tt_su
                                        Christina is correct, any Point3d and Vector3d stored in an Entity's attribute will be transformed along with the entity itself.
                                        I don't have a list of what classes can be stored, I'll look into it.
                                        • eneroth3E Offline
                                          eneroth3
                                          After some tests in SU2013 I found out that these classes are not transformed when using move!, transform! or transformation= on the entity, but they are when using the move, rotate or scale tool on it.
                                          This might be quite useful for custom animations scripts since things like rotation axes etc can be saved as attributes to the entities being transformed without be changed by the animation. When creating the mechanic parts for my railroad plugin I turned these data into normal arrays to avoid them from being transformed but perhaps that wasn't required.
                                          • tt_suT Offline
                                            tt_su
                                            Poking into the source here.
                                            set_attribute converts Ruby values into C++ types. The functions that handles it deals with the following types:
                                            True/False
                                            Length
                                            Integer
                                            Float
                                            String
                                            Array (Containing any of the other types)
                                            Color
                                            Time
                                            Point3d
                                            Vector3d
                                            And if its not any of those types it appear to silently ignore it. An empty setting is written. (It'll write the key, but value will be empty.)
                                            • 2 / 3
