    Notepad++
    38 Posts 15 Posters 21.8k Views 15 Watching
    • H
      huckrorick
      Hi Dan,
      If I remember correctly you were going to start using Notepad++ (but hadn't used it yet). Did you start? Do you have the file for autocompletion? (I think there are more than one around.) The one I have is useful but seems to miss a few things, oddly enough "def" is one of them.
      Huck
      • Dan RathbunD
        Dan Rathbun
        Yes.. I've been using it for the past 2 days.
        Much easier to change settings (colors, etc.) using the dialogs, then those 'properties' files that SciTE uses!
        Yes.. I've found that the file made by radhikari has more entries in it.
        Altho... I think I would have done it differently. For instance many method names have '(UI::Toolbar)' [ie, the qualification after them], which gets pasted in, and you then have to backspace over it, as it doesn't belong there.
        I'll have to find time, to play around with the API file sometime.
        ALSO... the file(s) were just modified FULL ruby files. Many of the listed modules and classes (and their methods,) are for Full Ruby, and are not available to Sketchup Ruby (unless a user has a full ruby install AND has paths to the full Ruby folders set.)
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          Another difference betwen the two editors.
          I belive SciTE lets you execute scripts from the editor without saving them.
          Notepad++ won't execute the script unless it's saved first. (I get an file 'such-n-such.rb' not found error.)
          • H
            huckrorick
            I didn't know you could execute a file directly from Notepad++. The way I've been doing it is:
            1. save the file
            2. go to Ruby Console in Skectchup and "load" the file (not too hard because the load command is saved and you can execute it again each time you modify the file"
            did you discover a more direct way to do it?
            Huck
            • Dan RathbunD
              Dan Rathbun
              @huckrorick said:
              I didn't know you could execute a file directly from Notepad++. The way ...[snip]... did you discover a more direct way to do it?
              NewOne explains how to do it, on page 1 of this thread, here's the direct link:
              http://forums.sketchucation.com/viewtopic.php?f=169&t=6903&st=0&sk=t&sd=a#p137855
              You need to install the NPPEXEC extension first. It helps if you have the PluginManager extension installed.
              Plugins > PluginsManager > show...
              Available (tab) > Hilite NPPEXEC and click 'Install' (button)
              • Z
                zitoun
                @newone said:
                For this you will need last version of Notepad++ or if you use a older version, download NppExec plugin from http://notepad-plus.sourceforge.net/uk/site.htm (last version have this integrated).
                Then you will need TBD's SketchUp Bridge from here http://labs.plugins.ro/.
                Hey there!
                Please let me unbury this thread to say first that I really appreciate it and like to thank every people that participate (especially the author of the post above). It is very important to have the right tools when you code, and find such info quickly to avoid to loose to much time πŸ˜„
                So : thx !!
                And: TDB, is there a way to get your plugin transmitting compilation info (such as error line number) to NPP? Does anybody know?
                The light at the end of the tunnel is a train.
                • K
                  KSJ100
                  What should I use for mac?
                  πŸ˜’ 😞
                  • jeff hammondJ
                    πŸ˜’ 😞
                    use xcode (it's on your install disks)
                      πŸ˜’ 😞
                      TextMate - very nice editor. http://macromates.com/
                        driven
                        another Mac answer...
                        TextWrangler (the free version of BBEdit without some of it's web tools) is very capable editor
                        and inside Sketchup I use Ruby Code Editor, which is getting better by the day.
                        • H
                          Heven7_floor
                          I have used Notepad++ with TBD 's bridge to learn with ruby plugin, it worked well with SU7 πŸ˜› , but after I d/l SU8 and try to setup bridge, I found problem that bridge can't run, I doubt that I missed something or SU8 can't bridge with Notepad++,Please suggest how I can do this.. 😐
                          thanks in advance. πŸ˜’
                            Update to Notepad++ download here
                            New features:
                            • Add Character Insertion Panel.
                            • Add Clipboard History feature.
                            • Add find characters in range feature.
                            Included plugins (Unicode):
                            • Spell Checker v1.3.3
                            • NppExport v0.2.8
                            • Compare Plugin 1.5.6.1
                            • Plugin Manager 0.9.3.1
                            • Converter 3.0
                            Included plugins (ANSI):
                            • TextFX v0.25
                            • NppExec v0.4.1
                            • NppExport v0.2.8
                            • Light Explorer v1.6
                            • Compare Plugin 1.5.5
                              πŸ‘
                                Another bug fix....
                                Fixed bugs
                                • Fix the Clipboard History crash issue while no data in Clipboard.
                                • Fix the local directory installation option ignored issue in Installer.
                                • Reduce the recent file history width to 32 characters.
                                • NppExport v0.2.8
                                • Converter 3.0
                                • TextFX v0.25
                                • NppExec v0.4.1
                                • NppExport v0.2.8
                                http://notepad-plus-plus.org/
                                  πŸ‘
                                  Strangely when I use 'update' from the Notepad++ '?' menu item [v5.9.1] it says there is no update available... BUT of course there is, via your link... πŸ˜’
                                    Filehippo update checker Mr.TIG
                                    Fastly error: unknown domain 151.101.1.91
                                    (www.filehippo.com)
                                    Looks after all your freeware updates πŸ‘
                                      @tig said:
                                      :thumb:
                                      Because the auto-update notification is delayed so that it only provides mature updates. (As oppose to these more frequent manual ones.)
                                        (www.filehippo.com)
                                        πŸ‘ πŸ‘ πŸ‘
                                          3 thumbs 😲
                                            I already use FileHippo for many of my app downloads [and very good it is too]... BUT I don't like yet another 3rd party app*** lurking on my PC, looking through 'my drawers', and then communicating what it finds with the outside world - all secretly and behind my back... I'm sure they are very honorable guys but... one hacked line of code and full details of my inside-leg measurement and favorite pizza-toppings are beamed off to say the Sony Corporation, for them to [accidentally] spread all over the known universe... I've nothing to hide... but I'd rather it remained private anyway... I'll give them a chance - BUT when my personal data is on the BBC News at 10 questions will be asked 'in the House' πŸ˜’
                                            ***I already have enough annoyance from QT, iTunes, Google-Updater, Adobe and the like, all wanting to waste my time updating stuff I don't really need much in the first place - without an option to stop most of them...
                                            πŸ˜‰
                                            • 2 / 2
