    [Plugin] SurfaceGen (0.9.0b) — 28 April 2012
    69 Posts 25 Posters 65.0k Views 25 Watching
      There are also a few error-messages appearing in the Ruby Console that needs traps or begin/rescue forms [e.g. after you explode a special group]...
      Some of them relate to your 'recurve' too...
      But it's a neat tool 😄
        Diggsey
        I've tried doing everything possible and can't seem to get any output in the ruby console from either plugin. Can you tell me exactly how to reproduce it?
          d12dozr
          @diggsey said:
          I've no idea how to make such complicated structures as those ones you linked to, but you can get some interesting shapes by just mixing up a few of the built in functions:
          sin, cos, tan, sinh, cosh, tanh, asin, acos, atan, asinh, acosh, atanh, atan2, hypot, sqrt, cbrt, log, log2, log10, ln, exp
          and constants:
          e, pi
          Thank you for this, and considering my suggestions too!
          http://goo.gl/f7ooYh
            For example...
            Error: #<NoMethodError: undefined method curve' for #<Sketchup::Group:0xa9d06fc>> C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:17:in can_select_curve?'
            C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:32:in `can_select_curve_selection?'
            C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:352
            When right clicking a tagged 'surfacegen-group'.
            Explode the special surgfacegen-group and right-click gives
            Error: #<NoMethodError: undefined method curve' for #<Sketchup::ComponentInstance:0xb440344>> C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:17:in can_select_curve?'
            C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:32:in can_select_curve_selection?' C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:352 C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:17:in call'
            Erase that 'bounds' Instance then Select the surface...
            Error: #<NoMethodError: undefined method curve' for #<Sketchup::Face:0xad7783c>> C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:17:in can_select_curve?'
            These all relate to 'recurve' reaction to 'surfacegen' entities ?
            I did have a surgacegen error but I can't get it to reproduce now 😕
            • N Offline
              notareal
              Nice! Can't wait some more complex math sculptures... and naturally even more functionality, like with K3DSurf.
              Little test...
                In the V6
                We can draw the "Box" but dialog's window don't opening 😉
                No error message, nothing in the Ruby console
                  Diggsey
                  @notareal
                  That's really nice! What's the equation you used?
                  @TIG
                  Make sure you have the latest version of Recurve. I fixed that bug with the last update which is why I couldn't reproduce the error. If you ever get the SurfaceGen error again let me know.
                  @Pilou
                  Just re-select the group with the select tool. It seems that the SelectionObserver doesn't fire when the selection is changed in code.
                    You are right, in that when I get v1.4 of 'recurve' I no longer get these errors with 'surfacegen'. However, I had v1.3 [with SUpv8] and there were no major changes except for making it SUpv6 friendly ?
                    Anyway... no more error messages... I'll try to break it 😉
                      Builder Boy
                      Sponge-like object:
                      All my plugins
                        driven
                        this is great,
                        some odd behavior on the Mac... when run from plugins (like you should) I get this
                        Error; #<ArgumentError; Cannot convert argument to Sketchup;;Point3d>
                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SURFACEGEN_Dir/surfacegen_tool.rb;266;in `add'
                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SURFACEGEN_Dir/surfacegen_tool.rb;266;in `getExtents'
                        if I put the surfacegen.rb into the folder do a restart and then load from Ruby Code Editor, I get this
                        (eval);428; warning; don't put space before argument parentheses
                        "Run aborted (error has occurred)"
                        (eval);10; warning; already initialized constant SURFACEGEN_DIR
                        (eval);11; warning; already initialized constant GRAPH_SIZE
                        (eval);12; warning; already initialized constant WINDOW_HEIGHT
                        (eval);13; warning; already initialized constant ATTR_DICTIONARY
                        but if I restart again and use as_pluginloader.rb to load it I get
                        /Library/Application Support/Google SketchUp 8/SketchUp/plugins/SURFACEGEN_Dir/surfacegen.rb;428; warning; don't put space before argument parentheses
                        it works, but has no tool button image...
                        the dialog keeps disappearing behind SU, but that needs show_modal on Macs
                        this is a 'normal' load i.e. image-no dialog
                        • N Offline
                          notareal
                          @diggsey said:
                          @notareal
                          F(x,y,z) = 2-(cos(x+(1+sqrt(5))/2*y)+cos(x-(1+sqrt(5))/2*y)+cos(y+(1+sqrt(5))/2*z)+cos(y-(1+sqrt(5))/2*z)+cos(z-(1+sqrt(5))/2*x)+cos(z+(1+sqrt(5))/2*x))*16/(x*x+y*y+z*z)
                          [x]; -5, 5
                          [y]; -5, 5
                          [z]; -5, 5
                          There is plenty more at the k3dsurf forum.
                          • N Offline
                            notareal
                            Perhaps you could add some more functionality; like functions min, max and abs. Also allow use of arithmetic operations and pi in axes, like -2*pi.
                                @diggsey said:
                                @Pilou
                                The SelectionObserver has always been very buggy: http://www.thomthom.net/software/sketchup/observers/
                                  Diggsey
                                  Just uploaded a fairly major update to the first post!
                                  @driven
                                  This should fix the issues with macs. It now uses cross-platform methods to locate and load resource, and uses show_modal rather than show on macs with the WebDialog.
                                  @notareal
                                  The axes now let you use an expression such as 2*pi
                                  @d12dozr
                                  Helpful error message are now shown when an expression is invalid.
                                    Thanks 😄
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/SURFACEGEN_Dir/surfacegen_tool.rb;270;in `add'
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/SURFACEGEN_Dir/surfacegen_tool.rb;270;in `getExtents'
                                    One minor error in getExtents in surfacegen_tool.rb
                                    Line #270 result.add @p0 if @state >= 0
                                    can raise an error so adjusting it to
                                    return if !@p0 or @p0.class!=Geom::Point3d; result.add @p0 if @state >= 0 might help - you could also add similar validity checks on the other points that are added to the extents ?
                                      Diggsey
                                      Ah, I knew I'd forgotten something 😄
                                      I've updated the first post. It shouldn't show those errors anymore.
                                        Cool.
                                          Diggsey
                                          Just updated again fixing a small bug with the expression parser.
                                          Check out this graph:
                                          http://i59.photobucket.com/albums/g314/diggsey/th_face.jpg
                                          Equation = min(((max(abs(y)-(2sqrt(z+4)) ,(x+0.5abs((abs(y)+4)/3.5)/(1+(((abs(y)+4)/3.5)^2-2)^2)/2 2/(1+(z-2)^2)+abs(y/1.5)^3.5/7 ) )max( max( abs(x+0.15+(y/0.7)^2)+(z-1.3)/1.4,max(z-2.3, max( abs(x+0)/2.4 -1+2abs(1.5y)+(z+0.1)/2 , -z ))) ,x-0.8+z/2)-0.1 )*(abs(x+y^2/3)-0.2+abs(abs(z+1.8)-(0.5-(y/2)^2) )^1.2 )-0.1 ),( (x+1.2+abs(y)/10)^2+(abs(y)-1.1)^2/2.5+(z-2.3)^2/1.8-0.64))
                                          x: -3 to 1
                                          y: -4 to 4
                                          z: -4 to 5.4
                                          @TIG
                                          Yes you can use any built in ruby function;)
                                          @jim
                                          I can't make the window resizable because it is shown and hidden by resizing it to a fixed value and zero respectively, and there is no API function to get the size of the window to save it. However, you can easily change the height of the window. Open surfacegen.rb in notepad and change the line "WINDOW_HEIGHT = 320" to about "WINDOW_HEIGHT = 350". You can try different values until you get what you want.
                                            driven
                                            yes,
                                            working on the mac...
                                            I don't know if I downloaded before or after your latest tweak,
                                            is there a version number somewhere on the files?
                                            another thing, is it possible to have a 'use last' settings option?
                                            playing around with the box size on the head requires [re]inputting the data each time
                                            cheers
                                            • 2 / 4
