    Making Faces from unconnected lines
    13 Posts 5 Posters 653 Views 5 Watching
      MartinK
      Hello and thanks to all the helpful members here.
      Is there a way to easily make faces from a selection of unconnected lines, all in the same plane, and creating the resultant planes as a separate group from the original lines. See attached images for example.
      Original lines before faces added
      After faces added
        TIG's Extrudes edges by Vector
        • mitcorbM Offline
          mitcorb
          A couple of older ones, maybe not as versatile: Extrude lines, Curve Stitcher, Skin. Just to provide information. πŸ˜„
            MartinK
            What I'd like to be able to do is select all the lines at once and, if possible, have the faces created as a group independent of the lines. I've tried Skin and ExtrudeByVector and can't get them to do what I want.
            Thanks.
            • mitcorbM Offline
              mitcorb
              The tools used on imported 2d graphics, I believe, are Make Faces and Close Opens? Find them at Smustard and/or Ruby Library Depot. These still may not be what you want considering the vertical orientation of your subject. Just trying to help.
                MartinK
                Mitcorb, thanks for the suggestions. I found MakeFaces and CloseOpens and they would probably work...but I was trying to avoid spending $20 for CloseOpens.
                  Curviloft by Fredo 6 seems perfect for that! πŸ˜‰
                  Select all lines then Call the plug πŸ˜‰
                  Re-order if necessary (you never find a plug who makes a magic order selection from a randomly number of lines in any positions as many ways are possible) πŸ˜’
                  Apply regulates
                  For face as group you must use some Special Selection Selection Toy by Thomthom
                  Then call Face(s) to group(s) by Bentleyfrog
                  Not a big deal πŸ˜„
                    MartinK
                    Pilou, Thanks, which method of Curviloft do I use? I tried Loft by Spline, but it locks up the model. Do I use Skin Contours? Thanks again.
                    • jeff hammondJ Offline
                      Use the first icon in the toolbar (on a phone and can't remember what it's called πŸ˜„ )
                      Set the segments to 1
                      Done
                      (edit. Just saw pilou's image. Do that)
                        Done
                        That's dedication
                          Done
                          That's dedication
                          What? From a phone?
                          Nah, I'm sitting in my girlfriends illegally parked car til 10. Only 35 more minutes to go πŸ˜„
                            Seems I had drawn an arrow on the face's tool? πŸ˜‰
                              MartinK
                              Thanks everyone. I got Loft by Spline to work. That's exactly what I needed. I appreciate all the help. πŸ‘
