    [Plugin]$ Keyframe Animation
    150 Posts 39 Posters 127.1k Views 39 Watching
    • KrisidiousK Offline
      Krisidious
      I think $19 is more than fair... and I wonder if 3rd world citizens are charging 3rd world prices for their 3D renderings?
      By: Kristoff Rand
        Regular Polygon
        @mariocha
        Wow! 😲 Now that is what I call a professional demo. πŸ‘
        My SketchUp Plugins
          Regular Polygon
          @chrisglasier said:
          Totally misconstrued. Code-based approach is good for specific tasks that are commissioned by those that can afford them - e.g. banks, airlines and stock markets. Code-based approach is also good for paperwork type applications like Word and Excel that are essentially blank. What you and I have been doing with animation plugins is to mix code and information to offer something that can be manipulated by anyone ... and that points the way to escape the subliminal stranglehold of software "total solutions". Don't you think?
          I guess I am still not clear on the distinction. Why would Excel belong to the code-based camp? It is not limited to specific tasks; anyone can configure a spreadsheet to compute what they want. Is this basically a distinction between programs that rely on text-based input as opposed to applications that use a GUI? πŸ˜•
          My SketchUp Plugins
          • chrisglasierC Offline
            chrisglasier
            Yes - more precisely selection.
              chrisglasier
              Sorry RP that was somewhat curt - I had to rush off to a Chinese New Year dinner. And selection is probably not quite the right word, but what I meant might be explained by comparing writing a cash cheque and using an ATM. Much of the non-creative processes are allocated to the machine (pressing buttons being creative!). But we cannot get a similar advantage with tasks that are too diverse to interest software companies, so the easiest option is to emulate paperwork. This is a terrible denial of the potential of a proper marriage of information and technology - which I think these animation plug-ins go some way to illustrate.
              • F Offline
                Fletch
                updated post above with bigger/better animation example.
                [flash=600,360:46s1ixag]http://www.youtube.com/v/fHXGUjAY8SM?fs=1&hl=en_US[/flash:46s1ixag]
                Fletch
                Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                  Regular Polygon
                  I downloaded the demo, and tested things out, and it turns out that VRay is not compatible after all. The problem is that VRay doesn’t export the layer visibility properties for each scene when it renders the scenes in batch.
                  I wrote customer support at V-Ray about this issue. They confirmed my suspicion, and said they plan to fix this in the future. Here is the ticket.
                  So, there is no work-around for this problem, Keyframe Animation requires layers to create the animation. Each layer has objects on it at a different point the animation. Each tween has a different layer that is visible. The effect is that the objects appear to move as you flip through the tweens.
                  VRay will render each tween individually OK -- just not in batch -- but that would be too tedious. πŸ˜’
                  My SketchUp Plugins
                  • F Offline
                    Fletch
                    Thanks RP - looking forward to giving it a try. πŸ˜‰
                    Fletch
                    • rohallorahR Offline
                      rohallorah
                      I think this could have some greatpossibilities!! I look forward to trying it out. πŸ˜„ Thanks R P
                      Has anyone tried it yet?
                      Robert O'Halloran
                      "Interior Architect & Designer"
                      http://designermedia.ie
                        cperkins
                        Hi! I need to start off by saying this is just fantastic work man. The hard work of persistent developers like yourself is what keeps my interest and use of SketchUp going every day.
                        Are you aware of or encountered any file size limitations when generating the tween scenes? I have this model that I previously animated with Proper and then rendered with Twilight. It's not complex at all really, but it's just over 20MB with all components included. I downloaded Keyframe and recreated what I did with Proper; ended up being 7 scenes. When I went to create the tweens I never got the dialog that asks for confirmation to create x number of scenes. However, the 'model.tweens.skp' file was created, just without any scenes included. At first I suspected there might be a limitation on the number of scenes SketchUp can create so I dialed the frame rate down from 24 to 10 and retried but got the same result. Then I tried creating a fraction of the animation with only two scenes and again got the same result. The next obvious thing to do was to try and strip the model down so I deleted the majority of the components and got rid of 15 of 20MB. The next attempt at creating the tweens was successful, as you can see in the video below, yet the focus of the animation is missing (items inside of case).
                        [flash=400,300:20oxahao]http://vimeo.com/moogaloop.swf?clip_id=22483626&server=vimeo.com&show_title=1&show_byline=1&show_portrait=1&color=00ADEF&fullscreen=1&autoplay=0&loop=0[/flash:20oxahao]
                        I would have said "oh well' but I really really want to use your plugin to get object/camera animations out of SU and into Kerkythea. Twilight is awesome but it's painfully slow due to what I'm guessing is the 32-bit architecture it relies on.
                        Any help would be greatly appreciated. Thanks!
                        • Chris
                          tallbridgeguy
                          I have the exact same problem. I tried it with a model that is over 10MB. The tween file was created with no tweens?
                          Is the file size the problem?
                          thanks
                          s
                          Nielsen
                          http://www.tallbridgeguy.com/
                            dedmin
                            @tfdesign said:
                            A great plugin, but I think your price is a little on the steep side.
                            Well, I guess the market will ultimately decide this issue. But, compared to other commercial animation plugins, I thought the price was a bargain. 😐
                            SketchUp was offered by Google to be a non-elitist app for everyone- why I imagine, it was offered for free, but for someone living in a 3rd-world country, or someone on unemployment benefit (and there is a lot of it about these days) $20 is a lot of money. Compared to say the SDS plugin, which IMO does something a lot more complex, and costs $2 more. Or how about even FredoScale, which is a dynamite plugin, but donationware. Please, don't get me wrong, and I'm sure your plugin will do very well, but again it will be richer countries like America who will be able to afford the more basic, yet essential payware plugins, leaving many in poorer nations, out (again).
                            Tom πŸ˜„
                            I'm in the worst position - living in the poorest country member of the EU, with almost European prices but with 3rd-world salaries! Average salary here 300 euro, 1 liter gasoline - 1.25 euro! But this plugin is well worth the money! Great work!
                              tallbridgeguy
                              Thanks for fixing it! I will give it another go.
                              Update: It works great now!
                              Update: I got it to work in kerkythea.
                              Stuart
                              Nielsen
                                cperkins
                                youdaman! 😎 Sketchup stock just jumped 10 points! Here's a quick one exported from Sketchup, animating 4 levels deep. I'll post a rendered version later on. Thanks again!
                                [flash=400,225:2kxqbjh1]http://vimeo.com/moogaloop.swf?clip_id=22511394&server=vimeo.com&show_title=1&show_byline=1&show_portrait=1&color=00ADEF&fullscreen=1&autoplay=0&loop=0[/flash:2kxqbjh1]
                                  dtrarch
                                  Hello tfdesign
                                  On the price please.
                                  We are all conditioned to the generousity of our friends here on the Forum and perhaps just expect everything to be for free.
                                  Keyframe Animation is offered as a commercial plugin and if it is to be used as tool for professional work and profit the price seems more than fair.
                                  It the use is just for fun then one must just accept that it is a pay to play deal and affordability is moot.
                                  Perhaps a fair rule for use is to either pay if asked for or at least thank the authors for those plugins that one actually uses.
                                  There really is no such thing as the proverbial free lunch.
                                  What a treasure this SuperForum is.
                                  My most personal thanks from to all who share their creative skills and generous good help here on this Forum.
                                  We all know who you are. πŸ‘
                                  dtr
                                    Regular Polygon
                                    I am glad that solved the problem. Thanks for the update. πŸ‘
                                    That animation is great! 😲 ❗
                                    It is a good example of nested animated components. Thanks for sharing your work. πŸ‘
                                    My SketchUp Plugins
                                      tallbridgeguy
                                      Hi is the download link broken for windows?
                                      s
                                      Nielsen
                                        Regular Polygon
                                        Well, that is strange. Firefox downloads the installer just fine. But IE claims the file is not found. πŸ˜•
                                        OK, the link on the Download page should work for either browser now. I zipped up the installer, and IE seems to be content.
                                        @tallbridgeguy:
                                        Thanks for that. πŸ‘
                                        My SketchUp Plugins
                                          tallbridgeguy
                                          No problem, I have been playing with the plugin. It works great!
                                          Nielsen
                                            tallbridgeguy
                                            Here is a quick tutorial I made showing what I am doing.
                                            If you watch it full screen at 720p it is tolerable....
                                            YouTube - tallbridgeguy-keyframe animation Tutorial
                                            [flash=853,510:2nvj5w9m]http://www.youtube.com/v/UxUMMdSJTgs?fs=1&hl=en_US[/flash:2nvj5w9m]
                                            Nielsen
                                            • 3 / 8
