    [Plugin]$ Keyframe Animation
    150 Posts 39 Posters 148.7k Views 39 Watching
      Regular Polygon
      @chrisglasier said:
      Totally misconstrued. Code-based approach is good for specific tasks that are commissioned by those that can afford them - e.g. banks, airlines and stock markets. Code-based approach is also good for paperwork type applications like Word and Excel that are essentially blank. What you and I have been doing with animation plugins is to mix code and information to offer something that can be manipulated by anyone ... and that points the way to escape the subliminal stranglehold of software "total solutions". Don't you think?
      I guess I am still not clear on the distinction. Why would Excel belong to the code-based camp? It is not limited to specific tasks; anyone can configure a spreadsheet to compute what they want. Is this basically a distinction between programs that rely on text-based input as opposed to applications that use a GUI? πŸ˜•
      My SketchUp Plugins
      • chrisglasierC
        chrisglasier
        Yes - more precisely selection.
        • chrisglasierC
          chrisglasier
          Sorry RP that was somewhat curt - I had to rush off to a Chinese New Year dinner. And selection is probably not quite the right word, but what I meant might be explained by comparing writing a cash cheque and using an ATM. Much of the non-creative processes are allocated to the machine (pressing buttons being creative!). But we cannot get a similar advantage with tasks that are too diverse to interest software companies, so the easiest option is to emulate paperwork. This is a terrible denial of the potential of a proper marriage of information and technology - which I think these animation plug-ins go some way to illustrate.
          • FletchF
            Fletch
            updated post above with bigger/better animation example.
            [flash=600,360:46s1ixag]http://www.youtube.com/v/fHXGUjAY8SM?fs=1&hl=en_US[/flash:46s1ixag]
            Fletch
              Regular Polygon
              I downloaded the demo, and tested things out, and it turns out that VRay is not compatible after all. The problem is that VRay doesn’t export the layer visibility properties for each scene when it renders the scenes in batch.
              I wrote customer support at V-Ray about this issue. They confirmed my suspicion, and said they plan to fix this in the future. Here is the ticket.
              So, there is no work-around for this problem, Keyframe Animation requires layers to create the animation. Each layer has objects on it at a different point the animation. Each tween has a different layer that is visible. The effect is that the objects appear to move as you flip through the tweens.
              VRay will render each tween individually OK -- just not in batch -- but that would be too tedious. πŸ˜’
              My SketchUp Plugins
              • FletchF
                Fletch
                Thanks RP - looking forward to giving it a try. πŸ˜‰
                Fletch
                • rohallorahR
                  rohallorah
                  I think this could have some greatpossibilities!! I look forward to trying it out. πŸ˜„ Thanks R P
                  Has anyone tried it yet?
                  Robert O'Halloran
                  "Interior Architect & Designer"
                  http://designermedia.ie
                  • C
                    cperkins
                    Hi! I need to start off by saying this is just fantastic work man. The hard work of persistent developers like yourself is what keeps my interest and use of SketchUp going every day.
                    Are you aware of or encountered any file size limitations when generating the tween scenes? I have this model that I previously animated with Proper and then rendered with Twilight. It's not complex at all really, but it's just over 20MB with all components included. I downloaded Keyframe and recreated what I did with Proper; ended up being 7 scenes. When I went to create the tweens I never got the dialog that asks for confirmation to create x number of scenes. However, the 'model.tweens.skp' file was created, just without any scenes included. At first I suspected there might be a limitation on the number of scenes SketchUp can create so I dialed the frame rate down from 24 to 10 and retried but got the same result. Then I tried creating a fraction of the animation with only two scenes and again got the same result. The next obvious thing to do was to try and strip the model down so I deleted the majority of the components and got rid of 15 of 20MB. The next attempt at creating the tweens was successful, as you can see in the video below, yet the focus of the animation is missing (items inside of case).
                    [flash=400,300:20oxahao]http://vimeo.com/moogaloop.swf?clip_id=22483626&server=vimeo.com&show_title=1&show_byline=1&show_portrait=1&color=00ADEF&fullscreen=1&autoplay=0&loop=0[/flash:20oxahao]
                    I would have said "oh well' but I really really want to use your plugin to get object/camera animations out of SU and into Kerkythea. Twilight is awesome but it's painfully slow due to what I'm guessing is the 32-bit architecture it relies on.
                    Any help would be greatly appreciated. Thanks!
                    • Chris
                    • T
                      tallbridgeguy
                      I have the exact same problem. I tried it with a model that is over 10MB. The tween file was created with no tweens?
                      Is the file size the problem?
                      thanks
                      s
                      Nielsen
                      http://www.tallbridgeguy.com/
                        dedmin
                        @tfdesign said:
                        A great plugin, but I think your price is a little on the steep side.
                        Well, I guess the market will ultimately decide this issue. But, compared to other commercial animation plugins, I thought the price was a bargain. 😐
                        SketchUp was offered by Google to be a non-elitist app for everyone- why I imagine, it was offered for free, but for someone living in a 3rd-world country, or someone on unemployment benefit (and there is a lot of it about these days) $20 is a lot of money. Compared to say the SDS plugin, which IMO does something a lot more complex, and costs $2 more. Or how about even FredoScale, which is a dynamite plugin, but donationware. Please, don't get me wrong, and I'm sure your plugin will do very well, but again it will be richer countries like America who will be able to afford the more basic, yet essential payware plugins, leaving many in poorer nations, out (again).
                        Tom πŸ˜„
                        I'm in the worst position - living in the poorest country member of the EU, with almost European prices but with 3rd-world salaries! Average salary here 300 euro, 1 liter gasoline - 1.25 euro! But this plugin is well worth the money! Great work!
                        • T
                          tallbridgeguy
                          Thanks for fixing it! I will give it another go.
                          Update: It works great now!
                          Update: I got it to work in kerkythea.
                          Stuart
                          Nielsen
                          • C
                            cperkins
                            youdaman! 😎 Sketchup stock just jumped 10 points! Here's a quick one exported from Sketchup, animating 4 levels deep. I'll post a rendered version later on. Thanks again!
                            [flash=400,225:2kxqbjh1]http://vimeo.com/moogaloop.swf?clip_id=22511394&server=vimeo.com&show_title=1&show_byline=1&show_portrait=1&color=00ADEF&fullscreen=1&autoplay=0&loop=0[/flash:2kxqbjh1]
                              dtrarch
                              Hello tfdesign
                              On the price please.
                              We are all conditioned to the generousity of our friends here on the Forum and perhaps just expect everything to be for free.
                              Keyframe Animation is offered as a commercial plugin and if it is to be used as tool for professional work and profit the price seems more than fair.
                              It the use is just for fun then one must just accept that it is a pay to play deal and affordability is moot.
                              Perhaps a fair rule for use is to either pay if asked for or at least thank the authors for those plugins that one actually uses.
                              There really is no such thing as the proverbial free lunch.
                              What a treasure this SuperForum is.
                              My most personal thanks from to all who share their creative skills and generous good help here on this Forum.
                              We all know who you are. πŸ‘
                              dtr
                                Regular Polygon
                                I am glad that solved the problem. Thanks for the update. πŸ‘
                                That animation is great! 😲 ❗
                                It is a good example of nested animated components. Thanks for sharing your work. πŸ‘
                                My SketchUp Plugins
                                • T
                                  tallbridgeguy
                                  Hi is the download link broken for windows?
                                  s
                                  Nielsen
                                    Regular Polygon
                                    Well, that is strange. Firefox downloads the installer just fine. But IE claims the file is not found. πŸ˜•
                                    OK, the link on the Download page should work for either browser now. I zipped up the installer, and IE seems to be content.
                                    @tallbridgeguy:
                                    Thanks for that. πŸ‘
                                    My SketchUp Plugins
                                    • T
                                      tallbridgeguy
                                      No problem, I have been playing with the plugin. It works great!
                                      Nielsen
                                      • T
                                        tallbridgeguy
                                        Here is a quick tutorial I made showing what I am doing.
                                        If you watch it full screen at 720p it is tolerable....
                                        YouTube - tallbridgeguy-keyframe animation Tutorial
                                        [flash=853,510:2nvj5w9m]http://www.youtube.com/v/UxUMMdSJTgs?fs=1&hl=en_US[/flash:2nvj5w9m]
                                        Nielsen
                                          Regular Polygon
                                          Thanks for the tutorial. I learned some things about using Kerkythea. β˜€
                                          The plugin to export the animation to Kerkythea is su2kt.rb by Tomasz. It works great, but you still have to stitch together the images generated by Kerkythea to make a movie, which is one more step.
                                          If rendering is not required, there is a quick way to export your animation directly from SketchUp. Just create the tween scenes using the Keyframe Animation plugin. Then export the tweens to a movie using the SketchUp utility, File > Export > Animation.
                                          My SketchUp Plugins
                                          • C
                                            cperkins
                                            nice tutorial tbg. I've been editing the actual .xml file to change max iterations on progressive settings.. your way is much easier πŸ‘
                                            Have your tried exporting to Kerky after creating the .tweens file? I used su2kt's batch scene export and got it over fine but the resolution doesn't hold. It ends up being about 200x200 every time. Maybe it's something I overlooked. I'm pretty sure I've been choosing the 'match scene resolution' option from the export dialog.
                                            • 3 / 8
