    [Plugin]$ Keyframe Animation
    150 Posts 39 Posters 148.7k Views 39 Watching
      Regular Polygon
      @Fletch: Thanks for sharing your results. That rendering is amazing -- now I know how this looks without building it.
      I can verify that Keyframe Animation is compatible with Kerkythea. I used the plugin, su2kt.rb, by Tomasz, to export the all the tween frames. Kerkythea rendered the images in about 20 minutes. Then I used VirtualDub to stitch them together into an AVI movie.
      [flash=480,385:3esvpvna]http://www.youtube.com/v/tZm4CwkHQ4k?fs=1&hl=en_US&rel=0[/flash:3esvpvna]
      @mariocha: Interesting idea, animating the light source. It doesn't quite work when exporting to Kerkythea, so I had to settle for stationary lights. I may revise the script to add this functionality in the next update.
      My SketchUp Plugins
        diego castro
        hice algunas pruebas y desafortunadamente no es compatible con VRay.
        I don't own VRay, so I haven't tested it. Maybe someone who owns VRay could verify this, and post their results here.
        existe una version demo de VRay de 30 dias (http://software.asgvis.com/index.php?option=com_content&view=article&id=298&Itemid=233)
        podrías mirar cual es el problema de incompatibilidad y hacerlo funcionar, podría tratarse de un problema sencillo de resolver talvez.
        por si te animas a mirar el problema y nunca has manejado VRay te dejo una imagen de los lugares clave para configurar la salida de animación
        en "save file se debe especificar la carpeta en la que se guardara las imagenes
        seria muy bueno si lo logras!
        Machine traslator:
        I did some tests and it is unfortunately not compatible with VRay.
        I do not own VRay, so I have not tested it. Who Owns Maybe VRay Could someone verify this, and post Their results here.
        there is a demo version of VRay of 30 days (http://software.asgvis.com/index.php?option=com_content&view=article&id=298&Itemid=233)
        could see what the problem of inconsistency and make it work, it could be a simple problem to solve maybe.
        if you dare to look at the problem and have never managed VRay leave you a picture of where to set the output key animation
        http://j.imagehost.org/0298/Imagen1.jpg
        "save file" must specify the folder where images are saved
        would be very good if you do it!
        • mariochaM
          mariocha
          Here is a new year wish.
          KFA makes the light source move; only 2 scenes.
          Rendered with LightUp, frame by frame of the tweens files.
          http://www.dailymotion.com/video/xgnt8j_bon-ann_creation
          %(#008000)[Mario C.
            Regular Polygon
            There is an interesting mannequin model, by Chris Glasier, posted on his [plug-in] Skel_animation topic. This looks like a very useful model for testing out plugins capable of human figure animation. So, I thought I would see what Keyframe Animation could do with it. I made several key frames, and exported a movie of the animation. Here it is.
            [flash=640,505:25hp8sz8]http://www.youtube.com/v/eS4QUrALcrE?fs=1&hl=en_US&rel=0[/flash:25hp8sz8]
            The SketchUp model is attached, if you want to experiment with your own animations.
            mannequin.skp
            I did change the way the components in the mannequin are grouped. I made the hand a sub-group of the forearm, because it moves relative to the forearm. Likewise, the forearm is sub-group of the upper-arm. And the lower-leg is a sub-group of the upper-leg. It is not absolutely necessary to group objects like this, it just makes things a lot easier. It also proves that Keyframe Animation can animate sub-groups -- in this case they are three levels deep.
            The Keyframe Animation 1.0 page has more demos, documentation, a video tutorial, and the latest version to download.
            My SketchUp Plugins
              Regular Polygon
              I can see how a code-based approach would be useful in certain situations. My approach is pretty much the opposite. I am trying to give non-programmers an intuitive way to define an animation. Basically, the animation relies on the change in the orientation of the component between two key frames. It is both a math problem and programming problem, which made it extra fun to work on.
              @chrisglasier said:
              I'm not in the plug-in competition but otherwise would be very happy to collaborate in some way.
              I am not in a plugin competition either. Am I overzealous about communicating this plugin’s functionality? That is possible. 🎉
              My SketchUp Plugins
              • chrisglasierC
                chrisglasier
                Actually, the model was made by ArqDirk not me - all I did was "straighten" one of his out to make it easier for testing. There are many in the warehouse by him and others.
                By the way, my purpose was not to create yet another animation plug-in but to expose the difference between a code-based set up as Matt used in his Automatic Sketchup and a more layman's wysiwyg approach that relies on specific information - in this case physical data (hidden in component definitions and transformations), functionality (e.g. lower limb always follows upper limb), and most importantly a specific set of recognisable names that are used for control and could be used to search for alternative parts of the same type.
                This integration of information could be referred to as Object Oriented Information Technology in that physical objects have classes and methods similarly to OOPS. With this a diverse range of non-creative tasks might be automated. This is my real interest so please be aware I'm not in the plug-in competition but otherwise would be very happy to collaborate in some way.
                And good luck with your plug-in.
                • mariochaM
                  mariocha
                  ... if you want to experiment with your own animations...
                  I did, ... with my own model 😉
                  http://vimeo.com/19417552
                  %(#008000)[Mario C.
                  • chrisglasierC
                    chrisglasier
                    Well you are because it is commercial (which in itself is just fine).
                    You are not.
                    Totally misconstrued. Code-based approach is good for specific tasks that are commissioned by those that can afford them - e.g. banks, airlines and stock markets. Code-based approach is also good for paperwork type applications like Word and Excel that are essentially blank. What you and I have been doing with animation plugins is to mix code and information to offer something that can be manipulated by anyone ... and that points the way to escape the subliminal stranglehold of software "total solutions". Don't you think?
                    • KrisidiousK
                      Krisidious
                      I think $19 is more than fair... and I wonder if 3rd world citizens are charging 3rd world prices for their 3D renderings?
                      By: Kristoff Rand
                        Regular Polygon
                        @mariocha
                        Wow! 😲 Now that is what I call a professional demo. 👍
                        My SketchUp Plugins
                          Regular Polygon
                          I guess I am still not clear on the distinction. Why would Excel belong to the code-based camp? It is not limited to specific tasks; anyone can configure a spreadsheet to compute what they want. Is this basically a distinction between programs that rely on text-based input as opposed to applications that use a GUI? 😕
                          My SketchUp Plugins
                          • chrisglasierC
                            chrisglasier
                            Yes - more precisely selection.
                            • chrisglasierC
                              chrisglasier
                              Sorry RP that was somewhat curt - I had to rush off to a Chinese New Year dinner. And selection is probably not quite the right word, but what I meant might be explained by comparing writing a cash cheque and using an ATM. Much of the non-creative processes are allocated to the machine (pressing buttons being creative!). But we cannot get a similar advantage with tasks that are too diverse to interest software companies, so the easiest option is to emulate paperwork. This is a terrible denial of the potential of a proper marriage of information and technology - which I think these animation plug-ins go some way to illustrate.
                              • FletchF
                                Fletch
                                updated post above with bigger/better animation example.
                                [flash=600,360:46s1ixag]http://www.youtube.com/v/fHXGUjAY8SM?fs=1&hl=en_US[/flash:46s1ixag]
                                Fletch
                                  Regular Polygon
                                  I downloaded the demo, and tested things out, and it turns out that VRay is not compatible after all. The problem is that VRay doesn’t export the layer visibility properties for each scene when it renders the scenes in batch.
                                  I wrote customer support at V-Ray about this issue. They confirmed my suspicion, and said they plan to fix this in the future. Here is the ticket.
                                  So, there is no work-around for this problem, Keyframe Animation requires layers to create the animation. Each layer has objects on it at a different point the animation. Each tween has a different layer that is visible. The effect is that the objects appear to move as you flip through the tweens.
                                  VRay will render each tween individually OK -- just not in batch -- but that would be too tedious. 😒
                                  My SketchUp Plugins
                                  • FletchF
                                    Fletch
                                    Thanks RP - looking forward to giving it a try. 😉
                                    Fletch
                                    • rohallorahR
                                      rohallorah
                                      I think this could have some greatpossibilities!! I look forward to trying it out. 😄 Thanks R P
                                      Has anyone tried it yet?
                                      Robert O'Halloran
                                      "Interior Architect & Designer"
                                      http://designermedia.ie
                                      • C
                                        cperkins
                                        Hi! I need to start off by saying this is just fantastic work man. The hard work of persistent developers like yourself is what keeps my interest and use of SketchUp going every day.
                                        Are you aware of or encountered any file size limitations when generating the tween scenes? I have this model that I previously animated with Proper and then rendered with Twilight. It's not complex at all really, but it's just over 20MB with all components included. I downloaded Keyframe and recreated what I did with Proper; ended up being 7 scenes. When I went to create the tweens I never got the dialog that asks for confirmation to create x number of scenes. However, the 'model.tweens.skp' file was created, just without any scenes included. At first I suspected there might be a limitation on the number of scenes SketchUp can create so I dialed the frame rate down from 24 to 10 and retried but got the same result. Then I tried creating a fraction of the animation with only two scenes and again got the same result. The next obvious thing to do was to try and strip the model down so I deleted the majority of the components and got rid of 15 of 20MB. The next attempt at creating the tweens was successful, as you can see in the video below, yet the focus of the animation is missing (items inside of case).
                                        [flash=400,300:20oxahao]http://vimeo.com/moogaloop.swf?clip_id=22483626&server=vimeo.com&show_title=1&show_byline=1&show_portrait=1&color=00ADEF&fullscreen=1&autoplay=0&loop=0[/flash:20oxahao]
                                        I would have said "oh well' but I really really want to use your plugin to get object/camera animations out of SU and into Kerkythea. Twilight is awesome but it's painfully slow due to what I'm guessing is the 32-bit architecture it relies on.
                                        Any help would be greatly appreciated. Thanks!
                                        • Chris
                                        • T
                                          tallbridgeguy
                                          I have the exact same problem. I tried it with a model that is over 10MB. The tween file was created with no tweens?
                                          Is the file size the problem?
                                          thanks
                                          s
                                          Nielsen
                                          http://www.tallbridgeguy.com/
                                            dedmin
                                            @tfdesign said:
                                            A great plugin, but I think your price is a little on the steep side.
                                            Well, I guess the market will ultimately decide this issue. But, compared to other commercial animation plugins, I thought the price was a bargain. 😐
                                            SketchUp was offered by Google to be a non-elitist app for everyone- why I imagine, it was offered for free, but for someone living in a 3rd-world country, or someone on unemployment benefit (and there is a lot of it about these days) $20 is a lot of money. Compared to say the SDS plugin, which IMO does something a lot more complex, and costs $2 more. Or how about even FredoScale, which is a dynamite plugin, but donationware. Please, don't get me wrong, and I'm sure your plugin will do very well, but again it will be richer countries like America who will be able to afford the more basic, yet essential payware plugins, leaving many in poorer nations, out (again).
                                            Tom 😄
                                            I'm in the worst position - living in the poorest country member of the EU, with almost European prices but with 3rd-world salaries! Average salary here 300 euro, 1 liter gasoline - 1.25 euro! But this plugin is well worth the money! Great work!
                                            • 3 / 8
