    [Plugin] V-Ray Tools
    238 Posts 80 Posters 295.0k Views 80 Watching
      Yes, bigger/more complex files load slower. And I get the feeling that if you open a model from an older VfSU version it adds even more load time. (Though this is a one time thing because it'd updating the project.)
        milkshark
        Awesome Plugin!!
        • focptF Offline
          focpt
          ThomThom,
          First of all, thank you for all your hard work on plugins. Really great stuff.
          I'm having trouble with V-Ray Toys. I have SU8, with the latest VfSU 1.48xxx. I did the following:
          1. Unchecked Vray from preferences.
          2. Closed SU
          3. Copied Vray toys into plugin folder.
          4. Opened SU
          5. Used Vray drop down to start VRay.
          However there is no Vray Toys tool bar anywhere. Also, when I close SU I get a bugsplat. Any ideas?
          I'm really just interested in the camer sync option right now. Is there a way to use that ruby only? Or some way to manually sync the cameras.
          Cheers,
          Nathan
          • Nathan
            http://www.focalpointstudio.net
          SU8, VRay 1.49
            The V-Ray Toys toolbar should be available before loading V-Ray. From the View > Toolbar menu.
            Did you mean the V-Ray for SketchUp toolbar? (if so - do you get errors when you try to start V-Ray?)
            Never experienced this. You don't get this without V-Ray Toys?
              There has been some issues reported when users don't have admin rights. Or full access rights to SU's folder. Could very well be it.
              Do you see a Compatibility Files button when you browse the Plugins folder?
              • focptF Offline
                focpt
                Ahhh, don't know why I didn't check the view>toolbar menu... it was late. I'll try again tonight.
                No I don't. Do I need to change permissions on my programs>google>su folder? When I copy paste plugins it asks for permissions (windows vista).
                • Nathan
                SU8, VRay 1.49
                • bagateloB Offline
                  bagatelo
                  I was wondering if it would be possible to change this plugin to control the automatic start of any other plugins such as the 1001 bit tools, or some other little tools that we don't use often. That would make the start Sketchup faster. So by default, would start with the Sketchup few essential plugins.
                  • halroachH Offline
                    halroach
                    If I wanted to remove V-Ray Toys...
                    how do I get about doing that in a way that vray will load automatically? After removing the vray toys files, vray still won't load on sketchup startup. I remember you once wrote that vray toys changes one of the file names in order to prevent vray from loading... which file was it?
                    FlexTools - Super Quick Windows, Doors, Slats...
                      What version of V-Ray do you use? (Exact version number please)
                      • halroachH Offline
                        halroach
                        I believe it is 1.49.01
                          This plugin doesn't rename any files for that version. You re-enable V-Ray from the Window > Preferences > Extension list.
                            salah
                            Hi Guys,
                            I have tried the Camera Sync. Toy on Vray for SKP 6 & 8 and didn't work? Could you please let me know how to install it? I took the 2 .rb files and copied them in the plugins file in SKP! Am i doing some thing wrong? Please let me know.
                            Txs
                              Two rb files?
                              Are you preserving the folder stucture in the zip file. sounds like you're not...v ❓
                              • V Offline
                                vipman1102
                                nice Thom, thanks alot 😎
                                • sadyoS Offline
                                  sadyo
                                  Would it possible that someday this Plugin (Camera Sync-Vray Toys) can work to other Render Software like podium? 😉
                                    hmm.. I'm not a Podium user. Don't know how it operates...
                                    • sadyoS Offline
                                      sadyo
                                      Oo, I see,
                                      Just wondering that we can use this nice plugin for any other Rendering Software, because many rendering software have the same problem with rendering output view, like VRay
                                        simrose
                                        Dear ThomTHom .. this is such an awesome plugin.. was suggested by Gaieus ... it save s so much more than 3 - 5 seconds.. now ma files open way faster!! God Bless both of u!!! 😄
                                        %(#FF00FF)[Regards,
                                        Simrose]
                                          pickprooflemon1
                                          @sadyo said:
                                          @thomthom said:
                                          @sadyo said:
                                          1. i've put "VRayToys folder" and VRayToys.rb in SU8 plugin folder "\Program Files\Google\Google SketchUp 8\Plugins"
                                          2. i open the SU8, turn off the VRay toolbar and i quit SU8
                                          3. i open the SU8 again (this way is working when i'm still SU7) and then nothing happen...
                                          Did you just close the toolbar, or did you disable VfSU from Window > Preferences > Extensions ?
                                          You need to do the latter.
                                          yes, I've done both ways...
                                          Finally, I tried to remove the VRayToys first, then put it back...
                                          Weird, VRayToys can work again like it should 😄
                                          But, when i try to Load VRay, it takes 15-20 minute to Appear 😢
                                          Is there something i done wrong? please help...
                                          I'm having the same problem...TT does tat means its not working for SU 8???? NOooooooooo......PLS HELP ME.
                                            pickprooflemon1
                                            Mr thomtom,
                                            Pls help me on my situation
                                            This is basically what i did:
                                            1.uncheck vray in the preference
                                            2. put the vray toys rb n the folder into the PLUGIN folder
                                            3. open SU 8 again, and load vray on demand. ( it loads in 40-60s)
                                            4. vray tools appear and and i open vray render option.
                                            i input the image aspect ratio into vray tools and click on 'set spect ratio'.
                                            AND NOTHINGS HAPPENS, i mean no factors r generated for me to input.
                                            "Set the V-Ray Physical Camera's Zoom property to: x.xxx'
                                            The value remain x.xxx. It wont works no matter how many times i click on it.
                                            Is this not functioning on su8? if not, is there any other way to sync the cameras.
                                            I'm using hdir and turned off physical camera and when i render it zoom out like crazy. which is why i resort to Vray toys.
                                            • 11
                                            • 12
                                            • 6 / 12
