    How to stick an object to another ?
    26 Posts 3 Posters 8.0k Views 3 Watching
    • E
      erzane
      köszi, nem is olyan bonyorult iràs de lasan irok, még gyorsan nem tudok
      a szülömmel mindig magyarul beszélunk, igy könyü
      na nem müködik ez a dolog
      nem is baj ha meg tudod magyaràzni màs hogy
      p.s. egy kicsit feljeb hagytam egy uj capturt
      • B
        Booman
        I would start by:
        1. triple-click cone shaped object
        2. right click on it
        3. select "Make Component"
        4. give the new component a name
        5. set component axis to the center of the large end
        6. rotate to desired angle
        7. select "Move" tool
        8. click on object (click a point or surface that will be in contact with the building)
        9. move mouse to a specific edge of the building
        10. click again to finalize move
        11. use "Move" tool to adjust location or copy
        12. use "Rotate" tool to rotate object to desired angle on building surface
        To copy multiple versions of the same object:
        1. select object
        2. select "Move" tool
        3. click on object or surface it will be aligned with
        4. hold "Ctrl" after the first click
        5. move mouse in direction to where the new object will be copied
        6. click again or use Keypad to type a specific distance (press Enter to finalize)
        7. type number of copies (example: 😎
        8. press "X"
        9. press Enter
        The specific object should be copied 8 times as in the example.
        Brian McCracken
        In The Red Website Design
        • B
          Booman
          sorry forgot to subscribe to this thread
          Brian McCracken
          • E
            erzane
            no prob
            • GaieusG
              OK, but in English (here). The good instructions above supported by an image.
              If it is already a component, select it in your Component browser and go to the Edit tab. There you can set it to glue to something - here I set it to glue to a vertical face but it can also be "any" from the dropdown list.
              The other important part is to properly set the gluing plane. When you create a new component, there is a button to set the component axes, here you need to right click on it and "Change axes". The gluing plane is always the red/green plane of the component and is marked with a grey rectangle (while the Z axis is "X'ed out").
              From now on, when you place a component from your component browser to a face in your model, it will automatically snap to that face and glues there so that you cannot even move it away (just on that plane) and if you use the PushPull tool to modify the face, the component will move with it.
              Note that it has to be a simple face, not a group or component (you can place components inside groups/components however).
              • E
                erzane
                ez eddig jol megy, de nem tudom hova kel clikkelni hogy pontosan a jo irànyban menyenek ezek a 6ok
                http://img718.imageshack.us/img718/4605/capture01mm.jpg
                booman, thanks
                I will notify exactely step by step and retry
                but, concerning copying, I knew it already
                concerning rotating object it's ok to
                but my prob is that I cannot succeed to glue it to the wall without using number control box
                (down right corner the screen) mm per mm
                so, more precisely I would like to know
                -how to glue it directly without trying all kinds of rotations ?
                -how to fusion 2 pots of B letter (pls see pic higher) ?
                -how to put 6 pots on the straight line of the edge of the wall ?
                http://img225.imageshack.us/img225/8432/capture01ka.jpg
                • E
                  erzane
                  thanks a lot
                  it's a really good explanation
                  I will try it now
                  will give you news as soon as I succeeded it
                  köszi 😉
                  • B
                    Booman
                    That was going to be my next tip... thanks Gaieus
                    As long as your building is perfectly flat, this should work.
                    But your AXIS has to be exactly along that flat surface you want to snap to the building.
                    I think it sound more complex than it really is.
                    Play with the move tool and rotation tool along with the snapping ablilties of Sketchup.
                    Snapping is strange at first because Sketchup always refers to any surface your mouse roll over.
                    In the background you may have horizontal and vertical surfaces and Sketchup will tend to automatically snap your object to them.
                    This will make it difficult to move and rotate objects, but at the same time, if you learn to use these background surfaces... it will help you to move objects around the 3D space.
                    One tip is: always snap objects to lines and endpoints not surfaces. Snapping will recognize surfaces, but to be more precise, using lines or endpoints is better.
                    Specially if your surface isn't perfectly flat.
                    Brian McCracken
                    • E
                      erzane
                      ok I see
                      thanks for those additional tips booman
                      p.s. Gaieus, I uploaded the file we spoke about before
                      here is
                      • GaieusG
                        Now save this file to somewhere then go back to your model, right click on that component and "Reload". Navigate to this file and reload your old component with this one.
                        The existing instances already inserted into your model will not work but if you insert a new instance from the component browser, it will already glue to any face you place it on.
                        Oops; remembered to save it down to SU 6 format. Is there any reason you are not using SU 8?
                        (Also cleaned up a little bit and reduced unnecessary poly count)
                        RadioButton.skp
                        • E
                          erzane
                          gaieus
                          thanks for your explanations
                          I succeeded to make it but it was difficult
                          difficult to put axes in the right place
                          here is the result
                          I putted transparent view like this you can see difference between component and the old ones not glued but putted inside wall with classic method
                          http://img828.imageshack.us/img828/4381/capture01zf.jpg
                          booman
                          -I see now why you said it's difficult because set the axis right is not very easy
                          I think I had luck this time
                          I hope other time I can study it more
                          gaieus
                          -btw, I charged my own component
                          -perhaps I didnt understood but did you wanted that I charge yours ?
                          (radio button file) ?
                          p.s. I dont think I need to use 8 format, 6 is enough for what I need to do
                          but if one day I see that 6 is not enough I will change it to 8
                          so, thanks a lot for your help to both
                          I really appreciated it
                          I have only 2 questions left
                          pls can you do something for me for those two last ones ?
                          -how to fusion 2 pots togheter ?
                          -how to put all pots in the right straight line with a 'help point' for be 100% straight to the wall edges (100% parallele)
                          p.s. the other ones arent components (is it ok ? )
                          p.s. perhaps I will reply you tomorrow only if I sleep
                          • B
                            Booman
                            Awesome! Glad you could get the component worked out.
                            I'll try to answer your two questions...
                            • Now that your pots are components you can weld them together by making them snap together according to the surfaces/angles you want welded. Then you have to explode both components and re-component them together again. After that, double-click the welded component and deleted the inside face that was joined in the middle. You could also delete that face before they were exploded, either way works.
                              I would use Sketchup 8 and try the "Outer Shell" tool which does the exact same thing. Welds two solids together. Its kinda finiky because both objects have to be absolute solid which means no lines or faces inside them, but then you select both and click the "Outer Shell" tool.
                            I explained it earlier in my step-by-step instructions how to copy with the "Move" tool, just make sure your building/wall is perfectly straight according to the Red or Green axis and Ctrl+M then type the distance on the numpad & hit Enter. Immediately after that type the number of copied objects, Press "X" and then "Enter" again. Sketchup should copy all of them in a straight line.
                            I use this all the time and it works great!
                            Brian McCracken
                            • GaieusG
                              Aligning the axes is not that very difficult if you have a little routine. Ideally I always make the component in a very early stage - when it is only 2D so axis alignment is pretty easy (the gluing plane is already given).
                              You could have used my component but it's better that you made (could make) yours as learning the how-to's is the most important.
                              I do not really understand what you mean by fusing the components together (unless it is what Booman understands).
                              You will need to learn linear arrays as he says. Basically you can do it in two ways; Copy-Moving the second component to the place where the next should be and typing x5 (for instance) to add four more than that first copy or copy-moving the component to the place of the last button first and typing /5 to do the same.
                              http://sketchup.google.com/support/bin/answer.py?answer=94867
                              you can do the same with the rotate tool to make radial arrays:
                              http://sketchup.google.com/support/bin/answer.py?answer=94896
                              Here is what can be entered into the Measurement box (or "VCB"):
                              http://sketchup.google.com/support/bin/answer.py?answer=151558
                              • B
                                Booman
                                Ah, linear arrays... thats what I meant.
                                I thought you had to do the number first then the "x"
                                or maybe it works both ways.
                                Brian McCracken
                                • GaieusG
                                  I think it works both ways (and also with the * character instead of the x)
                                  • E
                                    erzane
                                    ok, thanks for all your complete explanations and infos
                                    I will try all that and reask you question if I have some
                                    see you later
                                    thanks again ; )
                                    • B
                                      Booman
                                      Not a problem. Thank you for coming back!
                                      Brian McCracken
