๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Sketchup to cad
6 Posts 5 Posters 342 Views 5 Watching
  • E Offline
    ethip
    Is there a way to convert Sketchup file to CAD files?
      SketchUpNoobie
      Maybe this? ๐Ÿ˜• I'm not sure, I don't use CAD. It's pretty expensive for what it does. Maybe someone with more experience can help you out more than I can though. There is a ten day trial you could try.
      SketchUpNoobie: the complete noob in all things SketchUp.
      • H Offline
        honoluludesktop
        Here is a Obj , and a Dxf exporter. As I recall, the Dxf exporter will not do blocks, layers, and materials. But all the geometry will export. Also look here for comparison.
          Anssi
          If by "CAD" is meant AutoCad, the only relevant 3D file formats that AutoCad can import are FBX, 3DS and AutoCad's own DWG and DXF formats. SketchUp Pro can export to all of these, but for the Free version you must find an intermediary application. It seems Blender might be the one (it's free) as according to their website it supports collada (the format exported by SU Free), FBX, 3DS and DXF.
          Sorry about the alphabet soup... ๐Ÿ˜„
          Anssi
            Sketchup exports/imports Collada files [KMZ/DAE] and SKP [obviously], and of course various image formats in/out too.
            There are several extra file formats supported only by Pro
            Export OBJ, DWG/DXF [2d/3d versions], 3DS, FBX etc
            Import DWG/DXF, 3DS, DEM/DDF, WRL, XSI etc
            There are also some additional 3rd party importers available for all versions like OBJ, DXF, DXFtext etc...
            There are also other [often free] applications [like Blender] that can convert other file formats into something suitable for importing into Sketchup...
            It depends what you want to do !?
            • E Offline
              ethip
              Thanks everyone!!!
              I was looking at "Save as" not "Exporting"...problem solved.
              Many thanks again!!!!
              ethip
