    Questions about rendering applications for SketchUp
    24 Posts 11 Posters 4.0k Views 11 Watching
    • GaieusG
      This function of Twilight has saved my @ss couple of times!
      πŸ˜„
      • FrederikF
        Frederik
        One thing you didn't bring up that I personally think is important since we're talking about a render for SU is whether or not the renderer has a stand-alone "studio" software. Without such a studio, you'll have to make do without high-poly trees, cars, and furniture. Maxwell and a few other renderers do have such studios.
        Good point, Brodie... πŸ‘
        Twilight Render have it all...
        It works directly in SU, but if you need a studio, you can set everything up in TWR (materials, lights etc.) and export to a XML-file, which you can import in Kerkythea or Thea, where you can work further with advanced lightning, advanced materials, instancing of high-poly trees, grass etc... πŸ˜„
        Not sure how it works in Maxwell, but if you want to add or change something to your model/scene, you can select only these amendments/changes, export them and in KT as well as in Thea, you can use the merge option to add the amendments/changes to your scene, without the need to re-set and start all over with materials, lights etc...
        Cheers
        Kim Frederik
        • FrederikF
          Frederik
          @chippwalters said:
          I would've thought these developers would've have thought through this a bit more-- especially in such a competitive space as SU rendering. For instance, my 3D apps including SketchUp Pro, Thea, Vue 9 Infinite, KeyShot, Modo, Lightwave all allow you to install on more than one computer, as long as it's the ONLY one being used at a time. Funny how 'restrictive' and somewhat 'proud' the SU plugin renderers are-- especially when it's clear they're not even the best ones out there.
          πŸ‘Š Ouch... Not even the best ones out there... 😐
          Sorry... To me you seem to compare apples with oranges...
          The price for TWR is far lower compared to the price of any of the other applications you've mentioned...
          Nevertheless... I'll see what I can do to get the developers of TWR to re-view the license policy...
          I'm not saying that there will be any changes, cause as others already have pointed out...
          @d12dozr said:
          ...that at such a low price ($99), purchasing two licenses for two work machines is reasonable investment.
          Perhaps there's room for license policy improvements with upcomming release of TWR ver. 2...!?
          Cheers
          Kim Frederik
          • brodieB
            brodie
            I'm not sure I fully understand your explanation of the workflow but I'll explain how it works with maxwell. Within the SU plugin you setup all your materials, lighting, etc. Then you can export portions of the scene or the whole scene to an .mxs file (or you can just render directly from SU). The .mxs file is your studio file where you can further tweak materials, settings etc. I'll import my high poly objects into this scene, place them, clone them, etc. If part of my SU model changes you could just delete that part within studio, export that part from SU, and then merge that into the studio file. I personally find it easier to just delete the whole SU portion and merge the whole thing back in. The SU export doesn't take more than a minute or so even on a very large model so it's no big deal.
            Regarding the licensing, just in case Twilight wanted to take a look at how Maxwell works. You can open maxwell on as many computers as you want but if you hit render it searches the local network to see if there are any other renders running. The loophole would be if you had two computers that weren't on the same network but I think it's still a good convenient system.
            -Brodie
            • FrederikF
              Frederik
              I'm not sure I fully understand your explanation of the workflow...
              It's similar to your description... πŸ˜„
              I'm sure you'll see some nice changes to the TWR license policy in the future... πŸ˜„
              Cheers
              Kim Frederik
              • daleD
                dale
                Will there ever be a Mac version of Twilight?
                • FrederikF
                  Frederik
                  I'd say yes...
                  Can't say when, but I'd assume it to be together with release of ver. 2.0...
                  Chris have bee struggeling with a Mac version ever since TWR ver. 1.0 was released, but I believe he has a solution for ver. 2.0...
                  Cheers
                  Kim Frederik
                    So when is v2 out 😎
                    • chippwaltersC
                      chippwalters
                      A couple key thing developers need to remember about licensing, is
                      1. It should not get in the way of legitimate users.
                      2. It should not allow casual users to be able to easily give it to their friends "to try."
                      3. It should NEVER prevent a sale.
                      Keeping hard core pirates from being able to hack copy protection is for the most part useless, especially if it conflicts with number one above. We know that most, if not all true pirates will never pay for legitimate software-- so no sales revenue is lost One of the best things you can do to protect your product is to continually update it, with a notification in your app of new update available.
                      It's now very popular to consider licensing to individuals and not machines, just as Maxwell does. Good conversation.
                      Currently working with Cross-Reality technologies
                      • FrederikF
                        Frederik
                        So when is v2 out 😎
                        πŸ˜‰
                        @frederik said:
                        Can't say when...
                        Sorry...
                        Cheers
                        Kim Frederik
                          martin-art
                          I just wanted to post an update on the licensing situation in Shaderlight.
                          For Shaderlight 1.2 we incorporated a new licensing system which has made the installation process much more straight forward for our community. However, we discovered that a limitation of this new system was that we were unable to allow multiple activations on a license code or have the ability to transfer the license to another machine. We have been working to resolve this and importantly maintain the straight forward licensing.
                          Our development team concentrated on allowing multiple activations on a single code, new commercial Shaderlight activation codes can be used twice so you will be ok to activate your Shaderlight license on your office and home computer. The licensing of Shaderlight allows you to have Shaderlight installed on 2 machines, but only use 1 at a time.
                          Customers that have an existing Shaderlight license will need to contact support@artvps.com and their license code will be modified.
                          Martin
                          • chippwaltersC
                            chippwalters
                            Martin
                            That sounds great Martin. Thanks very much! 😍
                            • 2 / 2
