    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 306.8k Views 123 Watching
    • L
      lensman
      @notareal said:
      Maybe you need enable OSCoolean toolbar? If I recall right, OSCoolean toolbar is not automatically enabled.
      btw great plugin, thanks for update.
      Does this OSCoolean boolean plug-in require the toolbar mentioned above? I cannot find it and it is not mentioned in the first post as a requirement.
      I am not even SEEING the plug-in as an option in SU8. I downloaded SU8 SPECIFICALLY to let me use this plug-in. This is extremely frustrating. I am NOT a new SU user; I have SU7 with various plug-ins.
      I'm using Win7 and my SU8 plugins folder has the Oscar folder and OSCoolean.rbs file. The latter is dated 2nd Oct 2010, downloaded today 21DEC10.
      What am I doing wrong? Has anyone else encountered this? (Yes, I am restarting SU after installing plug-in).
      Glenn
      • mitcorbM
        mitcorb
        Has anyone taken this current version made for SU8 and used it in SU7 with any success?
        • Bob JamesB
          Bob James
          Crashes SU8 every time for me.
          • L
            lensman
            Oh, well, gave up on this and went back to SU7... bought Booltools and seems to work perfect.
            Glenn
            • liquid98L
              liquid98
              This is great work Thanks so much, nice tool-icons too.
              Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
                Michaelv
                Great plugin thanks.
                Could you please include a line with UI::Toolbar.restore (check and match syntax), so it keeps the status of the toolbar (displayed or not), thanks. I'd do it but since you plug in is rbs I can't.
                SU8 OS 10.5.8
                • P
                  pankaj_tamore
                  Hi oscarlok!
                  thank u for developing such great plugin may we all see some more interesting plugins from you in near future keep it up dude take care bi
                    alexdobras
                    i have installed the plugin, and when i click on union or any other button, SU8 simply does't work anymore well, i cannot even select the solids anymore with left click , only with right click.
                    and Coolean didn't complete his job either 😐
                    does it work for you in SU8 ?
                    • T
                      trailmax
                      Hi- I'm a relative newbie to Sketchup...but I have had experience with Booleans in Form Z. I'm on a Mac using SU 8 and cannot seem to get this plug in working. I have the entire contents of the unzipped file in the plugin folder (and restarted). I don't see an OSCoolean toolbar to enable in the menus, nor do I see anything in the contextual menus. Does anyone know if this awesome sounding tool is working for SU 8 on the Mac? Is there something else I need to install as well? Thanks
                      • mitcorbM
                        mitcorb
                        Back in Sketchup Version6, this plugin has a presence in Tools. Also, right click context menu will reveal the tools in the flyout. It may be similar in version 8.
                        I have pretty much abandoned this plugin for a perceived lack of response. But, what should I expect for free?
                          all that is very curious because it works fine in SU8 free with Pc ☀
                            Schorhr
                            Hello,
                            the plugin does not appear in tools nor in the rightclick menu ❓
                            As I frequently install plugins and use them regulary- without problems.
                            I do not know what could possibly cause this problem. Help! 😎
                            To make sure it's no conflict with an installed plugin, I just installed a "clean" Sketchup 8.0.4811 (most recent version). Still, I can not get it to work.
                            • mitcorbM
                              mitcorb
                              A few posts up I had this reply:
                              Maybe this does not apply. Just trying to help.
                              The responsiveness of the author leaves a bit to be desired.
                                Schorhr
                                Thanks 😄 But as I wrote, it's neither in the menu nor right-clicking the groups does show the plugin...
                                Is there perhaps a version older then 8.0.4811 that's known to work?
                                I am using XP Home 32 Bit SP 3,
                                  Jakob Hovman
                                  You have to: View/Toolbars/ and select OSCoolean
                                  It works when "things" are: make group, not make components.
                                  Jakob.
                                  • H
                                    HuglyPolo
                                    Hi everybody.
                                    I got some problem when trying to use these very interesting plug in : after choosing one of the buttons, nothing more happens, no more pointer, impossible to select the solids ... and I get this error message from the Ruby console :
                                    Error: #<NoMethodError: protected method `onMouseMove' called for #<OSCoolean:0xdfe87e0 @coolean="T">>
                                    (eval):1298
                                    What made I wrong or forgot to install ??
                                    Thank's for any help.
                                    Paul
                                    • P
                                      penumbradesign
                                      I'd love to try this plugin ( iam still on v 7.1) but it does not appear wise to install this as it might not work on ver 7?
                                        Seems it's writed for SU 8 no ? 😉
                                          sattapong
                                          good thank
                                            AcesHigh
                                            @Oscarlok:
                                            can you make OSCoolean work with faces/meshes? Like subtract a cube from a mesh/face?
                                            • 15
                                            • 16
                                            • 5 / 16
