    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 300.0k Views 123 Watching
    • mitcorbM
      mitcorb
      Has anyone taken this current version made for SU8 and used it in SU7 with any success?
      • Bob JamesB
        Bob James
        Crashes SU8 every time for me.
        • L
          lensman
          Oh, well, gave up on this and went back to SU7... bought Booltools and seems to work perfect.
          Glenn
          • liquid98L
            liquid98
            This is great work Thanks so much, nice tool-icons too.
            Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
              Michaelv
              Great plugin thanks.
              Could you please include a line with UI::Toolbar.restore (check and match syntax), so it keeps the status of the toolbar (displayed or not), thanks. I'd do it but since you plug in is rbs I can't.
              SU8 OS 10.5.8
              • P
                pankaj_tamore
                Hi oscarlok!
                thank u for developing such great plugin may we all see some more interesting plugins from you in near future keep it up dude take care bi
                  alexdobras
                  i have installed the plugin, and when i click on union or any other button, SU8 simply does't work anymore well, i cannot even select the solids anymore with left click , only with right click.
                  and Coolean didn't complete his job either 😐
                  does it work for you in SU8 ?
                  • T
                    trailmax
                    Hi- I'm a relative newbie to Sketchup...but I have had experience with Booleans in Form Z. I'm on a Mac using SU 8 and cannot seem to get this plug in working. I have the entire contents of the unzipped file in the plugin folder (and restarted). I don't see an OSCoolean toolbar to enable in the menus, nor do I see anything in the contextual menus. Does anyone know if this awesome sounding tool is working for SU 8 on the Mac? Is there something else I need to install as well? Thanks
                    • mitcorbM
                      mitcorb
                      Back in Sketchup Version6, this plugin has a presence in Tools. Also, right click context menu will reveal the tools in the flyout. It may be similar in version 8.
                      I have pretty much abandoned this plugin for a perceived lack of response. But, what should I expect for free?
                        all that is very curious because it works fine in SU8 free with Pc ☀
                          Schorhr
                          Hello,
                          the plugin does not appear in tools nor in the rightclick menu ❓
                          As I frequently install plugins and use them regulary- without problems.
                          I do not know what could possibly cause this problem. Help! 😎
                          To make sure it's no conflict with an installed plugin, I just installed a "clean" Sketchup 8.0.4811 (most recent version). Still, I can not get it to work.
                          • mitcorbM
                            mitcorb
                            A few posts up I had this reply:
                            Maybe this does not apply. Just trying to help.
                            The responsiveness of the author leaves a bit to be desired.
                              Schorhr
                              Thanks 😄 But as I wrote, it's neither in the menu nor right-clicking the groups does show the plugin...
                              Is there perhaps a version older then 8.0.4811 that's known to work?
                              I am using XP Home 32 Bit SP 3,
                                Jakob Hovman
                                You have to: View/Toolbars/ and select OSCoolean
                                It works when "things" are: make group, not make components.
                                Jakob.
                                • H
                                  HuglyPolo
                                  Hi everybody.
                                  I got some problem when trying to use these very interesting plug in : after choosing one of the buttons, nothing more happens, no more pointer, impossible to select the solids ... and I get this error message from the Ruby console :
                                  Error: #<NoMethodError: protected method `onMouseMove' called for #<OSCoolean:0xdfe87e0 @coolean="T">>
                                  (eval):1298
                                  What made I wrong or forgot to install ??
                                  Thank's for any help.
                                  Paul
                                  • P
                                    penumbradesign
                                    I'd love to try this plugin ( iam still on v 7.1) but it does not appear wise to install this as it might not work on ver 7?
                                      Seems it's writed for SU 8 no ? 😉
                                        sattapong
                                        good thank
                                          AcesHigh
                                          @Oscarlok:
                                          can you make OSCoolean work with faces/meshes? Like subtract a cube from a mesh/face?
                                          • irwanwrI
                                            irwanwr
                                            is this plugin has been updated recently? does it still work with the recent SU 8? not the M2 one.
                                            • 15
                                            • 16
                                            • 6 / 16
