    [Plugin] Solid Inspector
    303 Posts 99 Posters 368.4k Views 98 Watching
    • G
      GWD
      @driven said:
      @thomthom said:
      I avoided using material as I didn't want to clutter people's models.
      fair point, but what about using a 'style' set,that's purged when your done?
      @thomthom said:
      Section planes....(edit) I don't think one can even activate them via Ruby. ๐Ÿ˜ž
      it seems to me that the api lets you, but I'm no coder...
      @thomthom said:
      It should be highlighting the edges though, while the tool is active. you're not seeing that?
      sorry, it is highlighting the multi-face edges, it's the enclosed/internal (to volume) edges I was wondering about
      @thomthom said:
      (I want to make a UI for that.)
      I'm just airing ideas 'for that', I've tested/used all the pre-existing repair-aid scripts (TIG's,VW,CadSpan,etc.) and currently use bits from each, in a rather untidy workflow.
      we stop for Xmas next week and I'll try and organise my thoughts a bit better,
      I like what you've done with this so far...
      John, did you already test my new fixSolid? http://forums.sketchucation.com/viewtopic.php?f=323&t=33471
      Guy
      • E
        eliasandraos
        Lots of time saved. Thanks so much.
        • jason_marantoJ
          jason_maranto
          I just wanted to say this is the best plugin ever -- I find myself using some plugins every once in a while and a few very frequently, but this plugin instantly became something I used 20-30 times a session.
          Thank-you sooooo much for making this -- I didn't think I needed it but it has saved me dozens of hours already in just a few weeks... why they would include the solids tools in 8 without including this function I don't know but for me it is now an essential tool.
          Best,
          Jason.
            ๐Ÿ˜„ cheers!
            As I've begun to use the Solid Tools in SU8 more and more I find myself relying on it more often. And I found that I need to allow it to work within the group, component one wants to fix. As going out of the group your fixing to inspect it is just too awkward.
            • jgbJ
              jgb
              I've been using Solid Inspector for about 3 weeks now, and only a few days ago discovered the <tab> key, arrow key and <enter> functions. Never thought to look down. ๐Ÿ˜ฎ
              I use it so much I have the "S" key as a shortcut. ๐Ÿ‘
              But a most unintuitive aspect of SI is when it finds and highlights the problem(s). ๐Ÿ‘Ž
              Generally you want to delete the offender entity(s).
              The process is to toggle amongst the highlights to choose one, which is now indicated by a red circle. โ—
              Press <Enter> to zoom in on it.
              Place the white arrow cursor on the highlighted entity.
              Right click and select "Edit group". If you click "erase" here, it will delete the whole group.
              Keeping the cursor on the highlighted entity, Right Click and select "erase". That will delete the single cursor-ed entity only. Either 1 line or 1 face, but not the faces highlighted perimeter lines.
              And that leaves you in a form of limbo. ๐ŸŽ‰
              Now you have to select the "edit menu" and "close group" to get back into SI for the next problem.
              Since 99.9% of the time you want to simply delete the offending entity, why not simply;
              Place the cursor on it and just double click to delete the red highlighted entity.
              Then you toggle to the next.
              This obviates the wish for an auto-fix which is complex and where a simple deletion may not be the fix one needs to do.
              One other thing; when SI encounters a true solid (no errors) please say so, maybe a green circle around the group/comp. But do come out of the white arrow select mode.
              jgb
                Alencar
                Dear Thomthom
                is amazing how a simple program can solve such a complex issue and recurrent.
                this is brilliant
                thank you, very much.
                • jgbJ
                  jgb
                  @alencar said:
                  Dear Thomthom
                  this is brilliant
                  Believe me, Solid Inspector is not a "simple" program by a long shot. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                  TT has displayed an ongoing expertise in solving problems in SU that should have been an intrinsic part of SU from the get-go.
                  Using SI as a prime example; SU's attempt at being a solid modeler is commendable, however, to allow the tiniest errant fragment to prevent a solid from "forming" and NOT TELLING YOU WHY is amateurish at the least. ๐Ÿ‘Š
                  TT gets an A++++ for that fix.
                  jgb
                    Alencar
                    dear Thomthom
                    when I said "simple" I wanted to say that it was an easy program
                    to use, no less important.
                    "simplicity is characteristic of that is good"
                    sorry if not properly expressed
                    (I can not praise what is done well)
                    your plugin is fantastic.
                    Thanks.
                      I have plans (desire) to make the inspector work inside the active group/component instead of outside. That would improve usability.
                      • jgbJ
                        jgb
                        Thomthom said "I have plans (desire) to......"
                        I know THAT feeling all too well. ๐Ÿ˜†
                        jgb
                        • mariochaM
                          mariocha
                          That would sure be a great improvement
                          on an already so useful plugin! ๐Ÿ‘ ๐Ÿ‘ (icon of your username)
                          Now youv'e made me eager .
                          %(#008000)[Mario C.
                          • majidM
                            majid
                            this was realllllly handy to me .... nowadays I was modeling a chair part , to be produced by plastic, and need to be a solid, and it was really handy.
                            thanx a bunch.
                            • E
                              ericschimel
                              Nice work Thomas! I am going to check this out. I really hate trying to find small holes in groups!
                              -Eric
                              http://plugin.sketchthis.net
                              Sketchup Kitchen Design Plugin
                              Custom Models
                              • K
                                Kev_Ov
                                Thank you so much!!!
                                Leaks had been bugging me for days!
                                • E
                                  emartingr
                                  Defects in solids are sometimes produced by carrying out SU boolean operations, and these are very difficult to find. SI is a most welcome tool. Thanks a lot!!
                                    d12dozr
                                    Thomthom, I use this plugin ALL the time...how do I send you a cookie?
                                    http://goo.gl/f7ooYh
                                      Marcus. I'll send one with yours. ๐Ÿ˜‰
                                        Cookies!!! ๐Ÿ˜„
                                        • mariochaM
                                          mariocha
                                          Cookies!!! โ˜€
                                          %(#008000)[Mario C.
                                          • jgbJ
                                            jgb
                                            Can't tell you TT how ecstatic I am with SI.
                                            Although I have some suggestions for improvement, it still amazes me how it can find tiny random elements that SU says are "~0 in" in length that prevent a solid from forming, that would be simply impossible to find without SI.
                                            When Google upgraded SU to form solids, something like SI should have been a native function, far more important and useful than merging solids that are only available with Pro. But Google has always displayed excellent software for internally identifying errors, but rate a serious ๐Ÿ‘Ž ๐Ÿ‘Ž ๐Ÿ‘Ž ๐Ÿ‘Ž for telling us exactly what the error is and where to find it to fix.
                                            My only suggestions to improve SI are;
                                            1- allow it to function INSIDE the group/comp. Right now it is a repetitive set of operations to
                                            ** select the group/comp,
                                            • call-up SI (which is my "S" key shortcut),
                                            • hit <return> to locate the next error,
                                            • zero in on it and place the cursor on the red highlighted object,
                                            • press <spacebar> to exit SI,
                                            • enter EDIT mode and
                                            • select the offender and then
                                            • delete it, which is 99.999% of the time the required fix.
                                            • Then, exit edit mode,
                                            • reselect the group/comp and, IF the solid has not formed (Entity Info box),
                                            • do it all over again.* This gets tedious. ๐ŸŽ‰
                                            If SI worked INSIDE the group/comp, you would only need to
                                            • call-up SI,
                                            • then hit <enter> to select the first offender,
                                            • then <delete> to fix it,
                                            • <enter><delete> <enter><delete>* etc.
                                              โžก I would not want SI to automatically delete offenders, as in rare cases this is not the desired fix.
                                            2- If the group/comp is already or finally a valid solid, paint a green circle around it, and if in edit mode, exit the solid.
                                            jgb
                                            • 15
                                            • 16
                                            • 3 / 16
