    Hazy light
    renderpluginsextensions
    5 Posts 3 Posters 1.0k Views 3 Watching
    • arail1A Offline
      arail1
      I'm getting a kind of hazy light and I wonder if anyone can make suggestions about sharpening up the image, making it a bit crisper.
      Thanks in advance.
      Oh, Vray 1.49 (I think - I'm on a 30 demo. Not sure where you get that info)
        ledisnomad
        Two suggestions: light source and antialiasing.
        Are you using the Sun as a light source? If so, then you should check that the sun size is 1.0. The bigger it gets, the softer the edges of the shadow. If you are using a light source, then it depends... what is your light source?
        As for antialiasing, check what antialiasing filter you are in the Image Sampler options. By default is it Area with a size of 1.5. Try Catmull Rom at 1.5. If you still want more crisp edges, then bump up the size to 2 or 2.5. You could try 3 but that is probably overkill. Increasing the size will increase render time, so it's good to find the smallest size that makes you happy.
        Hope that helps!
        • V Offline
          valerostudio
          Definately change the sun size to 1 for starters. This is under your Environment tab, then click the M next to GI Color, then change the Size under General.
          Next, I would enable Ambient Occulsion (under Indirect Illum)check on and set the amount to .5 and maybe a radius of 8.0. This will help add punch and detail to those nooks.
          • arail1A Offline
            arail1
            Thanks for both of your replies.
            I just purchased a VRay license and deleted the demo version I was using. I did that before I read these posts so I'm not sure what settings I was using.
            Later today I'll open the scene again and experiment with the settings you each suggested and see what happens.
            • arail1A Offline
              arail1
              I finally got back to this work and started with the Catmull Clark advice. That made a tremendous difference - it made everything very crisp and clear, like taking gauze off the picture. Now I'm going to systematically try the other suggestions.
              I'll report back later but I wanted to stop in and say thanks - that was a real help.
